  3. Microhard RSSI/SNR logs
4 Posts 2 Posters 950 Views 1 Watching
  • E Offline
    E Offline
    Eli Pollack
    Is there a way to log RSSI and SNR data for the microhard modem board that is specifically contained on the voxl? Using a third party application I am able to log the information on the ground station modem, but having logs for the drones microhard as well would be extremely useful.
    • tomT Offline
      wrote on last edited by tom
      @Eli-Pollack Have you accessed the Microhard modems' web servers at all?
      If not, in order to access them:
      • Make sure your ground station is connected to your Microhard network
      • Open a browser
      • Navigate to the IP address of one of the modems (default master modem IP = 192.168.168.1, default slave = 192.168.168.2)
      If the connection is valid you'll see the modem's web server. There is a lot in there that you can play with (settings, logs, etc.) so you may be able to find what you're looking for there.
      • E Offline
        E Offline
        Eli Pollack
        Hi Tom,
        We have accessed those servers, but we are looking to get the data in real time. Unfortunately the web servers only update these values every 20-40 seconds or so. Is there a way to get this data in real time through voxl?
        Eli
        • tomT Offline
          @Eli-Pollack It's not something we've tried ourselves. I would recommend reaching out to Microhard. If they have suggestions, I may be able to help with figuring out implementation.
