  3. Voxl - Snapdragon model and supported camera configurations
voxl
4 Posts 2 Posters 1.3k Views 2 Watching
  • R Offline
    R Offline
    rgsmith
    I'm trying to find some more detail on a few Voxl specs.
    • The overview here specifies that the Voxl uses a Snapdragon 821, but the links point at a Snapdragon 820E. Do both these identifiers refer to the same Snapdragon?
    • I'm interested in setting up a camera configuration that is not listed here. I would like to use two stereo pairs + one HiRes - is such a configuration possible? I still don't have a strong understanding of what the MIPI CSI physical layer or Qualcomm Spectra Image Signal Processor can support.
      • This might not be the right Qualcomm Spectra ISP, but it seems to imply that only three simultaneous cameras can be used. Given that the voxel supports a HiRes + Stereo + Tracking configuration though, does that mean something special is going on with the two stereo cameras?
    Many thanks!
    ~Russ
    • Chad SweetC Online
      Chad SweetC Online
      The Snapdragon 821 is a speed grade version of Snapdragon 820. The Snapdragon 820E was the version Qualcomm sent to distribution, they're all fundamentally the same. Maybe +/- 5% on max clock speeds
      The MIPI-CSI configuration for stereo is a special use case, only supported on a few Qualcomm robotics chipsets. It is not very flexible and only works in the configurations we advertise as supported.
      • R Offline
        R Offline
        rgsmith
        Hey Chad,
        Perfect thanks, thats exactly what I was looking for regarding the Snapdragon model.
        So if I understand correctly, the specialized stereo configuration is a hardware limitation inherent to the Snapdragon? I'm trying to understand if this is a case of 'Qualcomm only supports this configuration' or 'ModalAI only supports this configuration'. Your comment leads me to believe that the former is true, and ModalAI's supported configurations are a result of Qualcomm limitations. I just want to be totally sure I've understood your comment correctly, can you confirm that?
        ~Russ
          Chad SweetC Online
          Your understanding is correct, ModalAI's supported configurations are a result of Qualcomm limitations
