  3. voxl-send-command not working to manually set exposure, gain on hires on flight deck
flight-deck
7 Posts 4 Posters 1.4k Views 2 Watching
  • M Offline
    M Offline
    m1baldwin
    I've been testing the voxl-send-command utility to see if I can tune the camera settings manually for the environment I plan to deploy the voxl flight deck into. I've configured the camera server to use the "modalai" auto_exposure_mode setting, and after I restarted the camera-server I expected to be able to control the exposure and gain of the hires camera. However, when I send the command to adjust those settings, I do not see a change in the image quality. The tool returns that it was successful to send the command to the /run/hires/mpa/control, but nothing happens.
    Here is my entry in the voxl-camera-server.conf for the hires camera:
    "version": 0.2,
    "port_J2": {
    "name": "hires",
    "enabled": true,
    "type": "hires",
    "api": "hal3",
    "frame_rate": 10,
    "override_id": -1,
    "auto_exposure_mode": "modalai",
    "modal_ae_gain_min": 0,
    "modal_ae_gain_max": 1000,
    "modal_ae_gain_period": 2,
    "modal_ae_exposure_min_us": 100,
    "modal_ae_exposure_max_us": 33000,
    "modal_ae_exposure_period": 1,
    "modal_ae_exposure_offset": 8000,
    "modal_ae_desired_msv": 58,
    "modal_ae_k_p_ns": 32000,
    "modal_ae_k_i_ns": 20,
    "modal_ae_max_i": 250,
    "modal_ae_good_thresh": 3,
    "modal_ae_display_debug": false,
    "preview": {
    "enabled": true,
    "width": 1920,
    "height": 1080,
    "format": "nv21"
    "video": {
    "enabled": false,
    "width": 1024,
    "height": 768,
    "format": "h265"
    "snapshot": {
    "enabled": false,
    "width": 1024,
    "height": 768,
    "format": "jpg"
    Here are various screen shots trying to set the exposure and gain to different values; you will notice the image show in vlc doesn't change at all
    Ed SutterE 1 Reply Last reply
    • M Offline
      M Offline
      m1baldwin
      @Eric-Katzfey Do you possibly have any ideas on this?
        This was a known bug when running the camera with the ISP's Auto exposure, it's been fixed in the latest camera server that we're preparing to release.
        M 1 Reply Last reply
        • ? A Former User
          M Offline
          M Offline
          m1baldwin
          @Alex-Gardner Thanks; you mention that is is the case when running the auto exposure through the ISP. I had configured it not to use it - I thought by using the "modalai" keyword for the auto_exposure_mode param - but maybe this is not working?
          Is there perchance a public backlog that people can check on to see if issues like this are known and being worked?
            Camera Server is in a bit of a funny place because we recently rewrote significant portions of it and fixed the bugs in that new repo, but generally speaking you can look at the changelog on the dev branch of each of our projects to see what we've been fixing recently (for example: camera server)
            • ? A Former User
              Tamas Pal 0T Offline
              Tamas Pal 0
              @Alex-Gardner I am using stable branch currently and unable to fly a quad because of qvio NOT STATIONARY issue while taking off. any suggestion.. which branch should I use ?
              • M m1baldwin
                "version": 0.2,
                "port_J2": {
                "name": "hires",
                "enabled": true,
                "type": "hires",
                "api": "hal3",
                "frame_rate": 10,
                "override_id": -1,
                "preview": {
                "enabled": true,
                "width": 1920,
                "height": 1080,
                "format": "nv21"
                "video": {
                "enabled": false,
                "width": 1024,
                "height": 768,
                "format": "h265"
                "snapshot": {
                "enabled": false,
                "width": 1024,
                "height": 768,
                "format": "jpg"
                Ed SutterE Offline
                Ed SutterE Offline
                Ed Sutter
                @m1baldwin I think things will work as you expect if you first run voxl-send_command hires stop_ae. You may also need an update to the voxl-camera-server code, refer to this post.
