  3. Error in HITL "Tx queue overflow" in VOXL-CAM.
voxl-cam
5 Posts 2 Posters 1.4k Views
  • A Offline
    Anubhav
    I was trying to run HITL in voxl-cam in VIO mode in gazebo using command from here https://forum.modalai.com/topic/1121/connecting-voxl-cam-and-pixhawk-cube?_=1661157872724 as told by @Zachary-Lowell. But I am getting message in terminal saying "Tx queue overflow" as soon as I am arming the vehicle through transmitter.
    can you tell me how to fix this problem?
    anubhav@anubhav-GF63-Thin-9SC:~/Gazebo_N/gazebo$ make px4_sitl_default gazebo_iris_vision
    -- PX4 version: v1.4.12-modalai-rb5-flight-alpha-6-gaf80dd159a
    -- PX4 config file: /home/anubhav/Gazebo_N/gazebo/boards/px4/sitl/default.cmake
    -- PX4 config: px4_sitl_default
    -- PX4 platform: posix
    -- PX4 lockstep: enabled
    -- cmake build type: RelWithDebInfo
    -- Building for code coverage
    -- ccache enabled (export CCACHE_DISABLE=1 to disable)
    -- build type is RelWithDebInfo
    -- PX4 ECL: Very lightweight Estimation & Control Library v1.9.0-rc1-509-gb919f3d
    -- ROMFS: px4fmu_common
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /home/anubhav/Gazebo_N/gazebo/build/px4_sitl_default
    [0/4] Performing build step for 'sitl_gazebo'
    ninja: no work to do.
    [3/4] cd /home/anubhav/Gazebo_N/gazebo/build/px4_...me/anubhav/Gazebo_N/gazebo/build/px4_sitl_default
    SITL ARGS
    sitl_bin: /home/anubhav/Gazebo_N/gazebo/build/px4_sitl_default/bin/px4
    debugger: none
    program: gazebo
    model: iris_vision
    world: none
    src_path: /home/anubhav/Gazebo_N/gazebo
    build_path: /home/anubhav/Gazebo_N/gazebo/build/px4_sitl_default
    GAZEBO_PLUGIN_PATH :/home/anubhav/firmware/build/px4_sitl_default/build_gazebo:/home/anubhav/firmware/build/px4_sitl_default/build_gazebo:/home/anubhav/Gazebo_N/gazebo/build/px4_sitl_default/build_gazebo
    GAZEBO_MODEL_PATH :/home/anubhav/firmware/Tools/sitl_gazebo/models:/home/anubhav/firmware/Tools/sitl_gazebo/models:/home/anubhav/Gazebo_N/gazebo/Tools/sitl_gazebo/models
    LD_LIBRARY_PATH /opt/ros/noetic/lib:/home/anubhav/firmware/build/px4_sitl_default/build_gazebo:/home/anubhav/firmware/build/px4_sitl_default/build_gazebo:/home/anubhav/Gazebo_N/gazebo/build/px4_sitl_default/build_gazebo
    empty world, setting empty.world as default
    Using: /home/anubhav/firmware/Tools/sitl_gazebo/models/iris_vision/iris_vision.sdf
    Warning [parser.cc:833] XML Attribute[version] in element[sdf] not defined in SDF, ignoring.
    Opened serial device /dev/ttyACM0
    SITL COMMAND: "/home/anubhav/Gazebo_N/gazebo/build/px4_sitl_default/bin/px4" "/home/anubhav/Gazebo_N/gazebo/build/px4_sitl_default"/etc -s etc/init.d-posix/rcS -t "/home/anubhav/Gazebo_N/gazebo"/test_data
    Creating symlink /home/anubhav/Gazebo_N/gazebo/build/px4_sitl_default/etc -> /home/anubhav/Gazebo_N/gazebo/build/px4_si
    _____  __   __    ___
    | ___ \ \ \ / /   /   |
    | |_/ /  \ V /   / /| |
    |  __/   /   \  / /_| |
    | |     / /^\ \ \___  |
    \_|     \/   \/     |_/
    px4 starting.
    INFO  [px4] Calling startup script: /bin/sh etc/init.d-posix/rcS 0
    INFO  [init] found model autostart file as SYS_AUTOSTART=1013
    INFO  [param] selected parameter default file eeprom/parameters_1013
    INFO  [init] parameter file not found, creating eeprom/parameters_1013
      SYS_AUTOCONFIG: curr: 0 -> new: 1
      SYS_AUTOSTART: curr: 0 -> new: 1013
      BAT_N_CELLS: curr: 0 -> new: 4
      CAL_ACC0_ID: curr: 0 -> new: 1310988
      CAL_ACC1_ID: curr: 0 -> new: 1310996
      CAL_ACC2_ID: curr: 0 -> new: 1311004
      CAL_GYRO0_ID: curr: 0 -> new: 1310988
      CAL_GYRO1_ID: curr: 0 -> new: 1310996
      CAL_GYRO2_ID: curr: 0 -> new: 1311004
      CAL_MAG0_ID: curr: 0 -> new: 197388
      CAL_MAG1_ID: curr: 0 -> new: 197644
      CBRK_SUPPLY_CHK: curr: 0 -> new: 894281
      COM_RC_IN_MODE: curr: 0 -> new: 1
      EKF2_REQ_GPS_H: curr: 10.0000 -> new: 0.5000
      EKF2_MULTI_IMU: curr: 0 -> new: 3
      SENS_IMU_MODE: curr: 1 -> new: 0
      EKF2_MULTI_MAG: curr: 0 -> new: 2
      SENS_MAG_MODE: curr: 1 -> new: 0
      SDLOG_MODE: curr: 0 -> new: 1
      SDLOG_PROFILE: curr: 1 -> new: 131
      SDLOG_DIRS_MAX: curr: 0 -> new: 7
      SENS_BOARD_X_OFF: curr: 0.0000 -> new: 0.0000
      SENS_DPRES_OFF: curr: 0.0000 -> new: 0.0010
      TRIG_INTERFACE: curr: 4 -> new: 3
      COM_CPU_MAX: curr: 90.0000 -> new: -1.0000
      IMU_INTEG_RATE: curr: 200 -> new: 250
      NAV_ACC_RAD: curr: 10.0000 -> new: 2.0000
      RTL_RETURN_ALT: curr: 60.0000 -> new: 30.0000
      RTL_DESCEND_ALT: curr: 30.0000 -> new: 10.0000
    ERROR [param] Parameter PWM_MAIN_MAX not found.
    ERROR [param] Parameter PWM_MAIN_MIN not found.
    ERROR [param] Parameter PWM_MAIN_RATE not found.
      GPS_UBX_DYNMODEL: curr: 7 -> new: 6
      EKF2_AID_MASK: curr: 1 -> new: 24
      EKF2_EV_DELAY: curr: 175.0000 -> new: 5.0000
      LPE_FUSION: curr: 145 -> new: 132
      ATT_EXT_HDG_M: curr: 0 -> new: 1
    * SYS_AUTOCONFIG: curr: 1 -> new: 0
    INFO  [dataman] Unknown restart, data manager file './dataman' size is 11798680 bytes
    INFO  [simulator] Waiting for simulator to accept connection on TCP port 4560
    Gazebo multi-robot simulator, version 11.11.0
    Copyright (C) 2012 Open Source Robotics Foundation.
    Released under the Apache 2 License.
    http://gazebosim.org
    [Msg] Waiting for master.
    [Msg] Connected to gazebo master @ http://127.0.0.1:11345
    [Msg] Publicized address: 192.168.199.33
    [Wrn] [Event.cc:61] Warning: Deleting a connection right after creation. Make sure to save the ConnectionPtr from a Connect call
    Tx queue overflow
    Tx queue overflow
    Tx queue overflow
    • Zachary LowellZ Offline
      Zachary Lowell
      Hi Anubhav - the reason why this is not working is because you are running your code in SITL mode and not HITL mode right now - the teller is that you ran make XXX in your executable. To run HITL, run the following:
      1. Change the line in hitl_iris.world: <uri>model://iris_hitl</uri> --> <uri>model://iris_vision</uri>
      2. Ensure that the iris_vision.sdf file is pointing to the iris_hitl model.
      3. Proceed to run:
      source Tools/setup_gazebo.bash $(pwd) $(pwd)/build/px4_sitl_default
      `gazebo Tools/sitl_gazebo/worlds/hitl_iris.world
      • A Offline
        Anubhav
        Hi @Zachary-Lowell,
        I have implemented the above changes and the drone was able to use vio in simulation.
        But the problem of "TX queue overflow" still persists. Here is the link of video showing HITL of MAVSDK example, where some times simulation works fine but some time it give error of "TX queue overflow".
        Same happens when HITL is done through QGC, here is the link.
        Here is the link where it's working fine.
        Note: QGC was opened after opening Gazebo simulator in all cases.
        How can I solve this problem?
        Anubhav
          Zachary Lowell
          @Anubhav looks like the links to your videos are private so I am unable to view. USUALLY TX queue overflow occurs when your autopilot is trying to communicate to both QGC and the simulation at the same time and the bandwidth going over the serial connection cannot be split. The solution although simple tends to work - just have gazebo open first - connect to the drone and run PX4 on the VOXL2. Once the serial connection between gazebo and the voxl2 have been established - THEN open QGC and that will connect over UDP and not leverage the serial connection.
          • A Offline
            Anubhav
            @Zachary-Lowell, I am sorry for video part. I have linked them respectively again below,
            1, 2, and 3, I hope you can see them now.
            I am using voxl-cam, and the error still arises when I don't open QGC. As you can see in first case, I was not using QGC to implement the MAVSDK example but the error still came.
