  3. modifying voxl-mapper
23 Posts 4 Posters 7.9k Views 1 Watching
  • H Offline
    H Offline
    howard
    Hello team,
    We wanted to modify the source code of voxl-mapper to send z coordinate. We have changed the code and now we would like to build it. We tried building it using voxl-cross but we got the following error
    CMakeFiles/Makefile2:340: recipe for target 'server/voxblox_loco_planner/CMakeFiles/voxblox_loco_planner.dir/all' failed
    make[1]: *** [server/voxblox_loco_planner/CMakeFiles/voxblox_loco_planner.dir/all] Error 2
    Makefile:135: recipe for target 'all' failed
    make: *** [all] Error 2
    Do we need to use voxl-emulator or something?can you please help us with this.
    thank you
      Hi Howard,
      The error occurs further up in the text. Without it I'm not sure what the issue is. Please could you post a more complete image of the error?
      H 2 Replies Last reply
      • ? A Former User
        Hi Howard,
        H Offline
        H Offline
        howard
        • H Offline
          H Offline
          howard
          • ? A Former User
            Hi Howard,
            H Offline
            H Offline
            howard
            @Matthew-Booker
            Sorry for being late, we were trying to build the package again on voxl cross,
            We got the following error,
            https://docs.google.com/document/d/1C1fZl-i5CzY3OUXER0KUOl3I6TGEhlw1XSsiebbMCr4/edit?usp=drivesdk
            After analysis we felt that ceres server package was missing hence we installed it using the instructions provided on the ceres server page. https://ceres-solver.org/installation.html
            We even customised the build by using tye command
            cmake -DCMAKE_CXX_FLAGS="-march=native" /home/root/ceres-solver
            After running make install as seen in above link
            We noticed that the libceres.a file was in /usr/local/bin and not in /usr/lib64
            Hence we copied libceres.a file to usr/lib64 but we ended up getting the following error, '/usr/lib64/libceres.a: error adding symbols: file in wrong format'
            The scenario can be seen in the below document.
            https://docs.google.com/document/d/1Q_5aam02v79-E3MosS6sw1BJ_0q3x1HUCCt_twu33Ao/edit?usp=drivesdk
            Please help us in solving the error
              Hi Howard,
              So the issue here is you've built ceres-solver for the native architecture which would mean that if you are running voxl-cross on your own desktop it built ceres-solver for your desktops architecture. In any case we have our own ceres-solver which you can install. Could you post the results of running cat /etc/opkg/opkg.conf on your VOXL?
              Also just a heads up that I should have mentioned earlier. In about a week or two there will be a major update to voxl-mapper which should bring a lot of improvements but will change a lot of things.
              H 1 Reply Last reply
              • ? A Former User
                Hi Howard,
                H Offline
                H Offline
                howard
                This is the output on voxl cross.but on voxl2 we couldn't run the command for opkg.
                Can you please tell the equivalent command for voxl 2 ?
                    #9
                    Can I double check. Did you run ./install_build_deps.sh before trying to build?
                    If building for a VOXL 2 the full command would be ./install_build_deps.sh qrb5165 stable
                    • N Offline
                      N Offline
                      Nishkala
                      wrote on last edited by Nishkala
                      #10
                      If we are building it for voxlcam, what should be used?
                      If we use ./install_build_deps.sh apq8096 stable, we get the error,
                      '-- Configuring done
                      -- Generating done
                      -- Build files have been written to: /home/root/voxlcam_mapper/voxl-mapper/build64
                      Consolidate compiler generated dependencies of target mav_trajectory_generation
                      [ 25%] Built target mav_trajectory_generation
                      Consolidate compiler generated dependencies of target mav_planning_common
                      [ 36%] Built target mav_planning_common
                      Consolidate compiler generated dependencies of target voxblox_planning_common
                      Consolidate compiler generated dependencies of target mav_path_smoothing
                      [ 44%] Built target voxblox_planning_common
                      [ 58%] Built target mav_path_smoothing
                      Consolidate compiler generated dependencies of target voxblox_loco_planner
                      [ 69%] Built target voxblox_loco_planner
                      Consolidate compiler generated dependencies of target mav_local_planner
                      [ 77%] Built target mav_local_planner
                      Consolidate compiler generated dependencies of target voxl-mapper
                      [ 80%] Building CXX object server/voxl-mapper/CMakeFiles/voxl-mapper.dir/voxl_mapper.cc.o
                      /home/root/voxlcam_mapper/voxl-mapper/server/voxl-mapper/voxl_mapper.cc: In member function 'virtual bool voxblox::TsdfServer::loadMap(std::string, std::string)':
                      /home/root/voxlcam_mapper/voxl-mapper/server/voxl-mapper/voxl_mapper.cc:1164:54: error: 'class voxblox::Layervoxblox::TsdfVoxel' has no member named 'loadBlocksFromFile'
                      bool tsdf_loaded = tsdf_map_->getTsdfLayerPtr()->loadBlocksFromFile(
                      /home/root/voxlcam_mapper/voxl-mapper/server/voxl-mapper/voxl_mapper.cc:1172:54: error: 'class voxblox::Layervoxblox::EsdfVoxel' has no member named 'loadBlocksFromFile'
                      bool esdf_loaded = esdf_map_->getEsdfLayerPtr()->loadBlocksFromFile(
                      server/voxl-mapper/CMakeFiles/voxl-mapper.dir/build.make:159: recipe for target 'server/voxl-mapper/CMakeFiles/voxl-mapper.dir/voxl_mapper.cc.o' failed
                      make[2]: *** [server/voxl-mapper/CMakeFiles/voxl-mapper.dir/voxl_mapper.cc.o] Error 1
                      CMakeFiles/Makefile2:398: recipe for target 'server/voxl-mapper/CMakeFiles/voxl-mapper.dir/all' failed
                      make[1]: *** [server/voxl-mapper/CMakeFiles/voxl-mapper.dir/all] Error 2
                        @Nishkala you can instead use ./install_build_deps.sh apq8096 sdk-0.8
                        Arjun JainA 3 Replies Last reply
                        • ? A Former User
                          Arjun JainA Offline
                          Arjun JainA Offline
                          Arjun Jain
                          Arjun JainA 1 Reply Last reply
                          • Arjun JainA Arjun Jain
                            [[topic:post-is-deleted]]
                            Arjun JainA Offline
                            Arjun JainA Offline
                            Arjun Jain
                            • ? A Former User
                              Arjun JainA Offline
                              Arjun JainA Offline
                              Arjun Jain
                              @Matthew-Booker Thanks a lot!
                              What works for me is:
                              voxl-cross:~/voxl-mapper(master)(0.0.7)$ ./install_build_deps.sh apq8096 sdk-0.8
                              voxl-cross:~/voxl-mapper(master)(0.0.7)$ ./build.sh apq8096
                              voxl-cross:~/voxl-mapper(master)(0.0.7)$ ./make_package.sh ipk
                              scp voxl-mapper_0.0.7.ipk root@10.0.1.10:
                              On voxl 1 board, I added arm64 7 to /etc/opkg/arch.conf
                              voxl:~$ voxl-configure-opkg dev
                              opkg install --force-reinstall --force-downgrade --force-depends --force-overwrite voxl-mapper_0.0.7.ipk
                              Then everything seems to work so far!
                              N 2 Replies Last reply
                              • ? A Former User
                                Arjun JainA Offline
                                Arjun JainA Offline
                                Arjun Jain
                                @Matthew-Booker However, when I try to save the mesh from the portal, in my compiled version, I get this symbol not found error. Any ideas why it can not find this function and how to fix it? Many thanks in advance.
                                skipped 2 point clouds
                                WARNING bytes left in tof point cloud pipe
                                skipped 3 point clouds
                                skipped 1 point clouds
                                voxl-mapper: symbol lookup error: voxl-mapper: undefined symbol: _ZNK7voxblox5LayerINS_9TsdfVoxelEE10saveToFileESsb
                                Fault address: 0x7f60053888
                                Access to this address is not allowed.
                                Segmentation fault
                                  @Arjun-Jain Looks like a mismatch in the voxl-voxblox version. Since you've already configured opkg you should just be able to run opkg install voxl-voxblox and it should work.
                                    N Offline
                                    N Offline
                                    Nishkala
                                    #17
                                    @Matthew-Booker How to do the same on voxl2
                                    I tried the below commands
                                    voxl-cross:~/voxl-mapper(master)(0.0.7)$ ./deploy_to_voxl.sh
                                    On the voxl2 board
                                    voxl2:/$ voxl-configure-pkg-manager
                                    Chose sdk 0.8
                                    voxl2:/$ apt update
                                    voxl2:/$ voxl-mapper
                                    I got the below error
                                    Loading our own config file
                                    Loading extrinsics config file
                                    Trying to init tsdf server
                                    terminate called after throwing an instance of 'std::bad_alloc'
                                    what(): std::bad_alloc
                                    Aborted
                                    ? 1 Reply Last reply
                                    • N Nishkala
                                      On the voxl2 board
                                      Chose sdk 0.8
                                      voxl2:/$ apt update
                                      Aborted
                                      @Nishkala When you build for voxl2 you need to use qrb5165 not apq8096 so the full command would be:
                                      ./install_build_deps.sh qrb5165 sdk-0.8
                                      ./build.sh qrb5165
                                      ./make_package.sh
                                        N Offline
                                        N Offline
                                        Nishkala
                                        @Matthew-Booker
                                        I ran the below commands on voxl cross:
                                        ./build.sh qrb5165
                                        ./make_package.sh
                                        ./deploy_to_voxl.sh
                                        I ran voxl-mapper after this on the board and got the error 'voxl-mapper: symbol lookup error: voxl-mapper: undefined symbol: _ZNK7voxblox5LayerINS_9EsdfVoxelEE10saveToFileENSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEb
                                        I wanted to add arm64 to /etc/opkg/arch.conf but voxl2 uses apt. How to solve the above issue?
                                          That error occurs when theres a voxl-voxblox version mismatch. The version of voxl-voxblox on your voxl2 is older. On your voxl2 if you run the following it should update
                                          apt install voxl-voxblox
