    Pre-arm check error “Avionics power is 4.7v” in QGroundControl
    • S
      shlee853
      I set done for all my flight configuration for indoor flight.
      But, I got a message from QGC as “Avionics power is 4.7v”. So, I denied armming.
      My battery is fully charged with 4s lipo.
      Could you please let me know how to check to release this message?
      • modaltbM
        modaltb ModalAI Team
        Hi @shlee853 ,
        What's your power setup look like? PX4 reads the input voltage (out of the power module). If the gauge of the wire is thin you could get some voltage drop perhaps.
        What's your other hardware setup like (anything plugged into USB?)
        • modaltbM
          If you have a volt meter, could you read the output of the power module as well?
          • S
            shlee853 @modaltb
            @modaltb My flight is flight deck with similar m500 frame.
            I also used power module provided by modalai.
            I tested my manual flight before downgrade sw.
            Yesterday, I downgraded system s/w version 0.3.2 to test VOA feature.
            In this case, I cannot pass pre-arm check in QGC.
            What does that mean avionics power? Is that VOXL input power?
            • modaltbM
              The Flight Deck has the two main components (VOXL and FlightCore). They share a 5VDC rail that is fed by the Power Module on the M500.
              The FlightCore portion of the board is a little STM32 microprocessor running PX4. PX4 reads that 5VDC from an ADC.
              Depending on your toolset, it could be easy to probe that voltage: https://docs.modalai.com/voxl-flight-datasheet-connectors/#j1013---5v-dc-power-input-i2c3-to-power-cable-apm
              When you did the manual flight you had no issues?
