  3. Dual IMX412 connected to VOXL 2
Scheduled Pinned Locked Moved VOXL 2 and VOXL 2 Mini
voxl-2
21 Posts 6 Posters 6.4k Views 3 Watching
  • ? Offline
    Mentioned here:
    Your camera server configuration file /etc/modalai/voxl-camera-server.conf for only two imx412 sensors connected would look as such:
    You'll need to customize your camera server config file manually because this is not a standard supported arrangement.
    If these are the only 2 cameras plugged in then they will be ID 0 and 1
    • V Offline
      V Offline
      vipul.kadam
      @Alex-Gardner Thank you for the clarification, pls refer following screenshot of the updated voxl-camera-serve.conf file from the VOXL2 module.
              "version":      0.1,
              "cameras":      [{
                              "name": "hires1",
                              "enabled":      true,
                              "frame_rate":   30,
                              "type": "imx214",
                              "camera_id":    0,
                              "preview_width":        640,
                              "preview_height":       480,
                              "snapshot_width":       640,
                              "snapshot_height":      480
                              "name": "hires2",
                              "enabled":      true,
                              "frame_rate":   30,
                              "type": "imx214",
                              "camera_id":    1,
      Once the above file as updated we carried out the suggested steps by providing the command
      voxl-configure-cameras, as stated in my earlier post there are variety of options which pop-up once the command is executed, can you please let us know which is the appropriate configuration id to be selected from the following drop down:
      available camera configurations are as follows:
      0  None
      1  Tracking + Stereo(OV7251)
      2  Tracking Only
      3  Hires + Stereo(OV7251) + Tracking
      4  Hires + Tracking
      5  TOF + Tracking
      6  Hires + TOF + Tracking
      7  TOF + Stereo(OV7251) + Tracking
      8  Hires Only
      9  TOF Only
      10 Stereo(OV7251) only
      11 Tracking + Hires + Dual Stereo(OV7251) Pairs
      12 Stereo(OV9782) only
      13 Hires + Stereo(OV7251)
      We have already tried out the following all camera configurations option so far and only in camera configuration id 8 we are able to get video but the video is only from 1 IMX412 sensor.
      • V Offline
        V Offline
        vipul.kadam
        To add to the above point the voxl-camera-server.conf file goes back to the default setting once the module is power cycled, refer following snapshot of the same file post power cycling.
        voxl2:/etc/modalai$ cat voxl-camera-server.conf
                "version":      0.1,
                "cameras":      [{
                                "name": "tracking",
                                "enabled":      true,
                                "frame_rate":   30,
                                "type": "ov7251",
                                "camera_id":    2,
                                "ae_desired_msv":       60,
                                "ae_filter_alpha":      0.600000023841858,
                                "ae_ignore_fraction":   0.20000000298023224,
                                "ae_slope":     0.05000000074505806,
                                "ae_exposure_period":   1,
                                "ae_gain_period":       1
                                "name": "hires",
                                "enabled":      true,
                                "frame_rate":   30,
                                "type": "imx214",
                                "camera_id":    3,
                                "snapshot_width":       3840,
                                "snapshot_height":      2160
                                "name": "stereo_front",
                                "enabled":      true,
                                "frame_rate":   30,
                                "type": "ov7251",
                                "camera_id":    0,
                                "camera_id_second":     1,
                                "independent_exposure": false,
                                "ae_gain_period":       1
                                "name": "stereo_rear",
                                "enabled":      true,
                                "frame_rate":   30,
                                "type": "ov7251",
                                "camera_id":    5,
                                "camera_id_second":     4,
                                "ae_gain_period":       1
        • V Offline
          V Offline
          vipul.kadam
          Hi @Alex-Gardner I guess the voxl-configure-camera was overwriting the voxl-camera-server file, bypassing that allowed us to get streams from both the IMX412 camera via the voxl-portal command.
          Refer Following image:
          0a9b0915-8b9e-4c82-bc13-377c048102a9-image.png ![alt text](image url)
          The required part of getting two parallel streams from 2 IMX412 camera onthe VOXL2 board seem to be achieved. I case of any further doubts on this activity will open a new thread. Thanks for your support.
          • V Offline
            V Offline
            vipul.kadam
            @Hector-Nevarez @Chad-Sweet @Alex-Gardner by editing the voxl-camera-server.conf file we were able to get a video stream from 640X480 @ 30fps up to (1920X1080) FHD @ 30 fps resolution for both the IMX412 camera, as seen from the datasheet the IMX412 sensor is a 12.3 Megapixel sensor and we would like to acquire highest possible resolution video stream from the sensor at 30fps as well as 60fps. Can you please let us know how this can be achieved.
            P.S. In the above mentioned conf file if we provide any resolution over and above 1920X1080 the video pile line crashes.
            • modaltbM Offline
              modaltbM Offline
              modaltb
              @vipul-kadam ,
              OK starting off with FPS, I perhaps stumbled into a fix that was preventing higher FPS from being used in the camera pipeline... I've tested this on a single imx412 only (what I have with me at the moment to try) but I'm able to get 1920x1080 at 60FPS after this mod:
              Can you add a new line with this:
              defaultMaxFPS=120
              at the end of this file?
              /vendor/etc/camera/camxoverridesettings.txt
              I believe this will allow higher FPS.
              • V Offline
                V Offline
                vipul.kadam
                Hi @modaltb by doing so the voxl-camera-serve and the voxl-portal pumps data over ethernet but on the web portal we are not able to see any vide0 from the IMX412 camera, pls note we are using the same voxl-camera-server.conf file which @Alex-Gardner have suggested to use.
                • modaltbM Offline
                  modaltbM Offline
                  modaltb
                  OK thanks for the info, we've not tested portal much with this new tweak above so it will take a little time to propagate the updates to support these, we'll update as it becomes available.
                  • V Offline
                    V Offline
                    vipul.kadam
                    @modaltb meanwhile the update becomes available, is there any other method to get a video streamed at FHD@60fps from the voxl2 module over the ethernet interface?
                    • modaltbM Offline
                      modaltbM Offline
                      modaltb
                      Have you tried voxl-streamer instead of trying to visualize using voxl-portal? I've not tried this myself but I would next try voxl-streamer.
