  3. multiple rtsp stream using voxl-streamer on same port ?
12 Posts 2 Posters 1.8k Views 1 Watching
  • Vaibhav UsapkarV Offline
    Vaibhav Usapkar
    @Chad-Sweet @modaltb @Alex-Gardner
    I have streamed 2 HiRes (IMX 412) video at 3840x2160 using voxl-streamer on 2 different URLs "rtsp://169.254.4.1:8900/live" & "rtsp://169.254.4.1:8901/live".
    Is it possible to stream 2 videos on same port say 8900 and just change /live1 and /live2 extension ?
    e.g stream 1=> rtsp://169.254.4.1:8900/live1
    stream 2=> rtsp://169.254.4.1:8900/live2
    • Vaibhav UsapkarV Vaibhav Usapkar
      @Vaibhav-Usapkar You would need to modify the voxl-streamer source code but should be fairly straightforward.
      Vaibhav UsapkarV 1 Reply Last reply
        Vaibhav Usapkar
        @Eric-Katzfey @Chad-Sweet @modaltb I tried to build the voxl-streamer code with some edits, However I am having some package locating errors encountered while building it as shown in below pic
        I tried to locate the packages as shown below, but unable to locate it
        Could you suggest what could be done here.
          @Vaibhav-Usapkar You need to do all that in the build docker, not in the host environment.
            @Vaibhav-Usapkar https://gitlab.com/voxl-public/voxl-sdk/services/voxl-streamer/-/tree/dev#prerequisites has some instructions. I have a feeling they are not complete but should be good enough to get you going. Let us know if there are any obvious problems with the documentation.
              Vaibhav Usapkar
              @Eric-Katzfey Yes I have followed the instructions on that link but still the same error persists
                @Vaibhav-Usapkar Please run the command to install the build dependencies before trying the build. For example ./install_build_deps.sh qrb5165 stable. The documentation left that step out so I'll update the documentation. Sorry for the confusion.
                  Vaibhav Usapkar
                  Hi @Eric-Katzfey, even after running "./install_build_deps.sh" command the issue persists.
                  Do i need to change any paths or install these libraries what do you think ?
                    @Vaibhav-Usapkar Looks like there is something wrong with your emulator. How are you launching the docker? Are you using voxl-docker -i qrb5165-emulator?
                      Vaibhav Usapkar
                      @Eric-Katzfey launching with the command
                      voxl-docker -i voxl-emulator
                        @Vaibhav-Usapkar Yeah, that is the voxl emulator for VOXL. You need to launch the qrb5165-emulator for VOXL2.
                          Vaibhav Usapkar
