  3. Unable to connect to host PC using adb shell & SSH
19 Posts 4 Posters 2.6k Views 2 Watching
  • Mohammad Saeid AnwarM Offline
    @tom I have a little confusion here. As I said earlier, the ADB shell has not been working. So how can I install your specified system image using the ADB pull command?
    like these commands:
    adb pull /data/modalai/opencv_tracking_intrinsics.yml
    adb pull /data/modalai/opencv_stereo_intrinsics.yml
    adb pull /data/modalai/opencv_stereo_rear_intrinsics.yml
    adb pull /data/modalai/opencv_stereo_extrinsics.yml
    adb pull /data/modalai/opencv_stereo_rear_extrinsics.yml
    • ? Offline
      Those adb pull commands are backing up config files on the drone, if it's only accessible through fastboot you'll have to skip those steps and reflash the drone. By default the data partition on the board is not reflashed, so as long as that partition wasn't corrupted the data will still be there.
        @Mohammad-Saeid-Anwar If you end up flashing and the cam cal files are still missing we can likely provide you with them on request as we back them up before shipping out a drone.
          I tried to flash your latest platform release (0.9). But I have faced the same issue. No ADB shell connection. Please take a look.
          Mohammad Saeid AnwarM 1 Reply Last reply
          • Mohammad Saeid AnwarM Mohammad Saeid Anwar
            @tom @Alex-Gardner
              @Mohammad-Saeid-Anwar It seems your device is stuck in fastboot mode so don't worry about trying to pull off the cam cal files. What happens when you run the platform release install script?
                Hello @tom This happened when I ran the platform release install script.
                  @Mohammad-Saeid-Anwar Can you run the following commands on your host PC back to back and post the output here:
                  lsusb
                  adb devices
                  fastboot devices
                    @tom said in Unable to connect to host PC using adb shell & SSH:
                    fastboot devices
                    hey @tom this is the output.
                      @Mohammad-Saeid-Anwar Hmm try the following:
                      adb kill-server
                      adb start-server
                      adb devices
                        wrote on last edited by Mohammad Saeid Anwar
                        #17
                        @tom It's still same!!
                          @Mohammad-Saeid-Anwar Do you have any other VOXLs that you are able to connect to via. ADB in order to determine that ADB was configured properly on your machine?
                            No. I don't have any other voxl.
                            Yes, it's properly installed. I had previously worked with the same ADB installation. Suddenly, it stopped responding. I also tried with two other machines with proper ADB installations. It showed the same problem (no device found).
