  3. How to install and configure OpenVPN?
37 Posts 2 Posters 11.2k Views 1 Watching
    @Djalma-Ribeiro Okay from the rb5-modem service it looks like you are connecting via. LTE just fine.
    The rb5-flight-modem service you're looking for has since been renamed to rb5-modem so that's why you're not seeing it.
    Can you do a ping test to verify that the internet is working? i.e. ping google.com
    D 1 Reply Last reply
      D Offline
      D Offline
      Djalma Ribeiro
      sh-4.4# ping google.com
      PING google.com (142.250.79.238): 56 data bytes
      64 bytes from 142.250.79.238: icmp_seq=0 ttl=114 time=63.395 ms
      64 bytes from 142.250.79.238: icmp_seq=1 ttl=114 time=63.037 ms
      64 bytes from 142.250.79.238: icmp_seq=2 ttl=114 time=62.547 ms
      64 bytes from 142.250.79.238: icmp_seq=3 ttl=114 time=66.664 ms
      64 bytes from 142.250.79.238: icmp_seq=4 ttl=114 time=63.391 ms
      64 bytes from 142.250.79.238: icmp_seq=5 ttl=114 time=64.499 ms
      64 bytes from 142.250.79.238: icmp_seq=6 ttl=114 time=68.028 ms
      64 bytes from 142.250.79.238: icmp_seq=7 ttl=114 time=75.665 ms
      ^C--- google.com ping statistics ---
      8 packets transmitted, 8 packets received, 0% packet loss
      round-trip min/avg/max/stddev = 62.547/65.903/75.665/4.099 ms
        @Djalma-Ribeiro Okay perfect, now what is the output when you attempt to connect to the VPN with openvpn --script-security 2 --config myfile.ovpn
          D Offline
          D Offline
          Djalma Ribeiro
          Options error: In [CMD-LINE]:1: Error opening configuration file: /etc/openvpn/connector01_sao_paulo.ovpn
            @Djalma-Ribeiro Looks like your path is wrong, you're in /etc/openvpn/openvpn
              D Offline
              D Offline
              Djalma Ribeiro
              @tom Hmm!!! Very well observed. I thought that was normal.
              I copied the files to the openvpn folder and ran the command. Result:
              /connector01_sao_paulo.ovpnpn# openvpn --script-security 2 --config /etc/openvpn/
              Wed May  4 19:14:41 2022 OpenVPN 2.4.6 [git:HEAD/b3a7f452206607fb] aarch64-unknown-linux-gnu [SSL (OpenSSL)] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on May  3 2022
              Wed May  4 19:14:41 2022 library versions: OpenSSL 1.1.1  11 Sep 2018
              Wed May  4 19:14:41 2022 Outgoing Control Channel Authentication: Using 256 bit message hash 'SHA256' for HMAC authentication
              Wed May  4 19:14:41 2022 Incoming Control Channel Authentication: Using 256 bit message hash 'SHA256' for HMAC authentication
              Wed May  4 19:14:49 2022 TCP/UDP: Preserving recently used remote address: [AF_INET]209.14.3.200:1194
              Wed May  4 19:14:49 2022 Socket Buffers: R=[1048576->1048576] S=[1048576->1048576]
              Wed May  4 19:14:49 2022 NOTE: setsockopt TCP_NODELAY=1 failed
              Wed May  4 19:14:49 2022 UDP link local: (not bound)
              Wed May  4 19:14:49 2022 UDP link remote: [AF_INET]209.14.3.200:1194
              Wed May  4 19:14:49 2022 TLS: Initial packet from [AF_INET]209.14.3.200:1194, sid=02821386 53542aca
              Wed May  4 19:14:50 2022 VERIFY OK: depth=1, CN=CloudVPN Prod CA
              Wed May  4 19:14:50 2022 VERIFY KU OK
              Wed May  4 19:14:50 2022 Validating certificate extended key usage
              Wed May  4 19:14:50 2022 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
              Wed May  4 19:14:50 2022 VERIFY EKU OK
              Wed May  4 19:14:50 2022 VERIFY OK: depth=0, CN=br-gru-dc2-b1.cloud.openvpn.net
              Wed May  4 19:14:50 2022 Control Channel: TLSv1.3, cipher TLSv1.3 TLS_AES_256_GCM_SHA384, 2048 bit RSA
              Wed May  4 19:14:50 2022 [br-gru-dc2-b1.cloud.openvpn.net] Peer Connection Initiated with [AF_INET]209.14.3.200:1194
              Wed May  4 19:14:51 2022 SENT CONTROL [br-gru-dc2-b1.cloud.openvpn.net]: 'PUSH_REQUEST' (status=1)
              Wed May  4 19:14:51 2022 PUSH: Received control message: 'PUSH_REPLY,route-gateway 100.96.1.33,ifconfig 100.96.1.34 255.255.255.240,ifconfig-ipv6 fd:0:0:8102::2/64 fd:0:0:8102::1,client-ip 200.173.248.124,ping 8,ping-restart 40,reneg-sec 3600,cipher AES-256-GCM,compress stub-v2,peer-id 71,topology subnet,explicit-exit-notify,remote-cache-lifetime 86400,block-outside-dns,route 100.96.0.0 255.224.0.0,route-ipv6 fd:0:0:8000::/49,route 100.80.0.0 255.240.0.0,route-ipv6 fd:0:0:4000::/50,dhcp-option DNS 100.96.1.33,auth-tokenSESS_ID,auth-token-user b25lc29sdmUvY29ubmVjdG9yL2I5YzdiMDVhLTY2ODUtNDNlMS05NTU5LTFkNTdhZWFjYzM4Nl9kY2M3ODY2Ny1hNDFkLTRiNWYtYWE1Ni02MGEwZjE3NzNiYjI='
              Wed May  4 19:14:51 2022 Options error: Unrecognized option or missing or extra parameter(s) in [PUSH-OPTIONS]:4: client-ip (2.4.6)
              Wed May  4 19:14:51 2022 Options error: option 'reneg-sec' cannot be used in this context ([PUSH-OPTIONS])
              Wed May  4 19:14:51 2022 Options error: Unrecognized option or missing or extra parameter(s) in [PUSH-OPTIONS]:13: remote-cache-lifetime (2.4.6)
              Wed May  4 19:14:51 2022 Options error: Unrecognized option or missing or extra parameter(s) in [PUSH-OPTIONS]:14: block-outside-dns (2.4.6)
              Wed May  4 19:14:51 2022 Options error: Unrecognized option or missing or extra parameter(s) in [PUSH-OPTIONS]:21: auth-token-user (2.4.6)
              Wed May  4 19:14:51 2022 OPTIONS IMPORT: timers and/or timeouts modified
              Wed May  4 19:14:51 2022 OPTIONS IMPORT: explicit notify parm(s) modified
              Wed May  4 19:14:51 2022 OPTIONS IMPORT: compression parms modified
              Wed May  4 19:14:51 2022 OPTIONS IMPORT: --ifconfig/up options modified
              Wed May  4 19:14:51 2022 OPTIONS IMPORT: route options modified
              Wed May  4 19:14:51 2022 OPTIONS IMPORT: route-related options modified
              Wed May  4 19:14:51 2022 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
              Wed May  4 19:14:51 2022 OPTIONS IMPORT: peer-id set
              Wed May  4 19:14:51 2022 OPTIONS IMPORT: adjusting link_mtu to 1624
              Wed May  4 19:14:51 2022 OPTIONS IMPORT: data channel crypto options modified
              Wed May  4 19:14:51 2022 Data Channel: using negotiated cipher 'AES-256-GCM'
              Wed May  4 19:14:51 2022 Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
              Wed May  4 19:14:51 2022 Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
              Wed May  4 19:14:51 2022 ROUTE_GATEWAY 10.46.46.117/255.255.255.248 IFACE=wwan0 HWADDR=00:00:00:00:00:00
              Wed May  4 19:14:51 2022 GDG6: remote_host_ipv6=n/a
              Wed May  4 19:14:51 2022 ROUTE6_GATEWAY fe80::6802:b8ff:fede:bb0a IFACE=wlan0
              Wed May  4 19:14:51 2022 TUN/TAP device tun0 opened
              Wed May  4 19:14:51 2022 TUN/TAP TX queue length set to 100
              Wed May  4 19:14:51 2022 do_ifconfig, tt->did_ifconfig_ipv6_setup=1
              Wed May  4 19:14:51 2022 /sbin/ifconfig tun0 100.96.1.34 netmask 255.255.255.240 mtu 1500 broadcast 100.96.1.47
              Wed May  4 19:14:51 2022 /sbin/ifconfig tun0 add fd:0:0:8102::2/64
              Wed May  4 19:14:51 2022 /sbin/route add -net 100.96.0.0 netmask 255.224.0.0 gw 100.96.1.33
              Wed May  4 19:14:51 2022 /sbin/route add -net 100.80.0.0 netmask 255.240.0.0 gw 100.96.1.33
              Wed May  4 19:14:51 2022 add_route_ipv6(fd:0:0:8000::/49 -> fd:0:0:8102::1 metric -1) dev tun0
              Wed May  4 19:14:51 2022 /sbin/route -A inet6 add fd:0:0:8000::/49 dev tun0
              Wed May  4 19:14:51 2022 add_route_ipv6(fd:0:0:4000::/50 -> fd:0:0:8102::1 metric -1) dev tun0
              Wed May  4 19:14:51 2022 /sbin/route -A inet6 add fd:0:0:4000::/50 dev tun0
              Wed May  4 19:14:51 2022 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
              Wed May  4 19:14:51 2022 Initialization Sequence Completed
                @Djalma-Ribeiro That looks promising! If you do an ifconfig in another terminal do you see a tun0 network interface? If so then you're all connected.
                  D Offline
                  D Offline
                  Djalma Ribeiro
                  tun0: flags=4305<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST>  mtu 1500
                          inet 100.96.1.34  netmask 255.255.255.240  destination 100.96.1.34
                          inet6 fd:0:0:8102::2  prefixlen 64  scopeid 0x0<global>
                          inet6 fe80::da89:cbe9:b217:1ed7  prefixlen 64  scopeid 0x20<link>
                          unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00  txqueuelen 100  (UNSPEC)
                          RX packets 0  bytes 0 (0.0 B)
                          TX packets 7  bytes 336 (336.0 B)
                  But shouldn't I see the drone in the device list on the OpenVPN website?
                  • D Offline
                    D Offline
                    Djalma Ribeiro
                    What else do I need to do to complete the OpenVPN setup? Do I need to send any certificate for the drone?
                    I also couldn't find how to connect the QGC to the drone using VPN. How to find the address to use etc.
                      @Djalma-Ribeiro So the .ovpn file you used is the certificate that your drone is now using to connect to the VPN. You will also need to connect to the VPN with a different certificate using your ground control station that is running QGC.
                        @Djalma-Ribeiro By looking at the tun0 interface you can see that the IP of your drone on the VPN is now 100.96.1.34
                        When you connect using your ground control station / PC you will also receive an IP there and those are the IPs you will use to communicate via. the VPN server
                        D 2 Replies Last reply
                          D Offline
                          D Offline
                          Djalma Ribeiro
                            D Offline
                            D Offline
                            Djalma Ribeiro
                              wrote on last edited by tom
                              #18
                              @Djalma-Ribeiro The fact that the IP is the same on that OpenVPN screenshot makes me think that you're attempting to use the same key file here as you are on your drone. If that's true, it won't work and the devices will keep kicking each other off the network. You need to use a unique key for each device.
                              The first test before you try to connect to QGC would be to connect both devices to the VPN with their unique keys and then attempt to ping from the drone to your pc or from pc to drone. That way you can ensure the two can communicate with each other before you try getting PX4 / QGC involved.
                              Once you have the pinging working, you can set the IP of the ground station on your drone in /etc/modalai/qgc-ip.cfg(file name may be slightly different)
                              • D Offline
                                D Offline
                                Djalma Ribeiro
                                Now I understand a little more! By the way, thank you very much for your help.
                                I have both the pc and the drone online on OpenVPN:
                                But neither can find the other by ping.
                                Is there anything else I'm forgetting?
                                  @Djalma-Ribeiro Are you using a windows machine? All of our devices use Ubuntu 18.04 so I don't have much experience with it.
                                  However on Windows, I know that some of our customers have had to disable all their firewalls in order to allow the traffic to come through.
                                    D Offline
                                    D Offline
                                    Djalma Ribeiro
                                    @tom I managed to make the ping work by putting the drone in host and the pc in network.
                                    Do I have to use UDP or TCP to connect to the QGC?
                                      @Djalma-Ribeiro By default it'll use UDP. See this page for the next steps: https://docs.modalai.com/Qualcomm-Flight-RB5-user-guide-px4/
                                      You will have to modify the rb5-net-check service and change the line ExecStart=/usr/bin/rb5-net-check wlan0 192.168 to ExecStart=/usr/bin/rb5-net-check tun0 100.96 in order to tell the drone to wait for the VPN network interface to come up before sending out PX4 packets.
                                      Then you will have to modify the previously mentioned /etc/modalai/qgc-ip.cfg and adding the IP of your PC on the VPN in order to tell PX4 where to send packets.
                                      You can also look at : /etc/modalai/full-m0052.config in order to see the PX4 startup config
                                        D Offline
                                        D Offline
                                        Djalma Ribeiro
                                        @tom I didn't find the file /etc/modalai/qgc-ip.cfg
                                          @Djalma-Ribeiro Okay you may have a slightly older version of the SDK. Go ahead and download the latest SDK from: https://developer.modalai.com/asset/4
                                          and then follow the instructions here to install:
                                          https://docs.modalai.com/Qualcomm-Flight-RB5-sdk-installation/
                                          This way we know you're using the latest SDK. This qgc-ip file was added in a later release
