  2. VOXL SDK and Software
  3. voxl-tflite-server forward compatibility ?
mpa
20 Posts 4 Posters 4.7k Views 2 Watching
  • Philemon BennerP Offline
    Philemon Benner
    @Matt-Turi btw why is voxl-emulator architecture armv7l if we have aarch64 on actual voxl? Will this be a problem when compiling in emulator?
    • ? Offline
      #12
      • Philemon BennerP Philemon Benner
        @Philemon-Benner Voxl is 64 bit and the OS is 64 bit. However, Qualcomm provides many of their packages for the device as 32 bit and, consequently, anything that has a dependency on these packages must also be 32 bit. That is why you can build 64 bit applications and have them run successfully on Voxl. It just means that that application had no 32 bit dependencies.
          Philemon Benner
          Okey thanks for explaining
            Philemon Benner
            wrote on last edited by Philemon Benner
            #15
            @Matt-Turi
            I know it's not really related to the voxl but if include directorys in cmake like that:
            include_directories(/home/root/third_party/AWS/wrkspace/lib)
            the compiler should find the packages located in there or?
            [100%] Linking CXX executable Process
            /usr/lib/gcc-cross/aarch64-linux-gnu/7/../../../../aarch64-linux-gnu/bin/ld: cannot find -lDiscovery-cpp
            /usr/lib/gcc-cross/aarch64-linux-gnu/7/../../../../aarch64-linux-gnu/bin/ld: cannot find -lEventstreamRpc-cpp
            but the linked library is located there:
            voxl-cross:~(master)$ ls /home/root/third_party/AWS/wrkspace/lib | grep Discovery-cpp
            Discovery-cpp
            libDiscovery-cpp.a
              Not totally sure what you're asking, but try looking into target_link_libraries in the cmake documentation
                Philemon Benner
                @Matt-Turi Ok so i got it working with CXX17, it's working in voxl-emulator:
                voxl-emulator:~$ file program
                voxl-mission-logic: ELF 64-bit LSB executable, ARM aarch64, version 1 (GNU/Linux), statically linked, BuildID[sha1]=somekey , for GNU/Linux 5.4.0, not stripped
                voxl-emulator:~$ ./program --arg someArg
                [2022-03-22 12:23:14.804] [info] someText
                [2022-03-22 12:23:14.807] [info] someText
                [2022-03-22 12:23:15.279] [info] someText
                But on actual voxl it's not working:
                voxl:/data$ ./program --arg someArg
                FATAL: kernel too old
                Aborted
                Kernel Versions in voxl-emulator and voxl_platform_3-3-0-0.5.0-a system image are actually different:
                emulator kernel version: 5.13.0-35-generic
                voxl kernel version: 3.18.71-perf
                Shouldn't voxl emulator have the same kernel version as the voxl?
                in the docs it says:
                • voxl-emulator simulates the VOXL system image and is built alongside the base system image
                  Philemon Benner
                  Upgrading to newest system image didn't work either
                    @Philemon-Benner voxl-emulator is a Docker image, not a complete Virtual Machine, so it uses the same kernel as the machine you run it on.
                    Philemon BennerP 1 Reply Last reply
                      Philemon Benner
                      @Eric-Katzfey Ok thanks for the fast answer.
