Would an Frsky 32 Channel RC bind with the m500's Spektrum Transmitter?
No, only a Spektrum transmitter will bind with a Spektrum receiver. You need a FrSky receiver connected to the Flight Core to bind to an FrSky transmitter.
This is the type of receiver that might work (need to check compatibility with your transmitter) https://www.amazon.com/FrSky-Taranis-Compatible-Receiver-8-Channel/dp/B00RCAHHFM/ref=sr_1_3?keywords=rc+sbus+receiver&qid=1582226969&sr=8-3
You'll need to remove the Spektrum and install the Frsky receiver at J004 https://docs.modalai.com/voxl-flight-datasheet-connectors/#j1004---rc-input--spektrumsbususart6-connector
Little more detail, we've validated with FrSky X8R reciever and Taranis X7 transmitter with the following setup:
We have a new cable about to come out to assist with this wiring as well:
https://docs.modalai.com/cable-datasheets/#mcbl-00018
