    Starling2 :One motor fails when changing power from AC/DC adapter to battery
    Starling & Starling 2
    • H
      HsinSWT
      Hello, I’ve recently encountered a problem.
      When operating in Position Mode, all motors work correctly after arming when powered by an AC/DC adapter. However, after switching to battery power, one of the four motors does not spin after arming.
      I have two videos show this issue.
      Using battery
      Using Adaptor
      I made some simple observations:
      1. I have two batteries, so I also tried replacing the other battery for testing, but the problem remained regardless of which battery I used.
      2. I visually inspected the motor and found no loose wiring or other issues. The LED indicator lights are shown in the image below.
      However, one component on the ESC board appears to be rusty; I'm unsure if this has any impact. Please see the attached image below.
      The device and software version I used:
      Drone: Starling2 Indoor SLAM Development Drone
      SDK: voxl2_SDK_1.5.0
      Battery: 2S amprius silicon anode modalai battery
      Voxl_inspect_services:
      Voxl_version:
        Alex Kushleyev ModalAI Team @HsinSWT
        Hello, @HsinSWT ,
        I am assuming your are using a 12V AC/DC adapter, which is higher voltage than the 2S battery used with Starling 2. Using 12V bench testing is OK, so that should not be an issue.
        The ESC should already have the correct parameters loaded for the Starling 2 Motors and the correct battery voltage (2S). Inability to start at the nominal voltage, but success when using 12V is likely a symptom of a motor damage. Even though the ESC does have voltage compensation, it is limited (on purpose, for safety) and if you apply higher voltage, like 12V instead of 7-8V, the ESC will actually output higher power during the spin-up phase.
        Also please make sure you are using the latest ESC firmware, there are a lot of tips here : https://docs.modalai.com/voxl-escs/faq/
        Once you start using voxl-esc tools, you can also spin one motor at a time (or all 4 at a time) and get real-time RPM feedback. You could use your 12V supply and spin the motors at 10% power and see what RPMs they actually spin at. A faulty motor would spin slower. Please be careful while testing, since the drone could fly up if you send a wrong command, you could also test without propellers, the motor issue should be observable in unloaded motor RPMs as well.
        Another typical issue with motors not spinning up is damage of motor windings due to mounting screws going into the windings (which could happen if the landing gear is removed, but the same screws are used to attach the motors). I am not saying this is the case here, but worth inspecting the motor windings on the under side, right where the motor mounting screws could make contact with the windings if the screws were too long.
        If you do have a milli-ohm meter accessible to you, you could actually measure the motor winding resistance (while the drone is powered off, but motors can remain soldered to the ESC). You can compare the milli-ohm readings from working motors vs non-working (check all phases pair-wise).
        The rust on the inductor is only cosmetic. We are aware of this "issue", but it's really not an issue (rust on a iron case of an inductor - the case does not really affect the inductor itself).
        Hopefully this helps!
        H 1 Reply Last reply Reply Quote 0
        • H
          HsinSWT @Alex Kushleyev
          Thank you for your reply ,@Alex-Kushleyev .
          I am indeed using a 12V AC/DC adapter.
          I inspected the problematic motor and found that its mounting screws did not appear to be screwed into the windings, as shown in the picture below.
          Here are the results of voxl-esc_spin tests using two different power supplies:
          • The 12V AC/DC adapter appears to be working fine (adapter_voxl-esc_spin_test_video) (adapter_voxl-esc_spin_test_result.txt
          • However, the battery power test results show:
          1. Motor ID 0 is not working. (battery_voxl-esc_spin_test_video)
          2. The Average RPMs of Motor ID 0 detected by the voxl-esc tools is significantly lower than the other three motors. The image below is a partial screenshot of the data. Please click the link for the complete data.(battery_voxl-esc_spin_test_result.txt)
          Screenshot from 2025-12-22 17-32-26.png )
          Based on the above supplementary data, would you recommend that I send it for repair?
          Thank you very much!
            Hello @HsinSWT ,
            When i see results like this, i would say there is probably 90% chance that the motor is bad. Unfortunately, there is a chance that the ESC is bad as well, and there is no good way to check the ESC without a known good motor (however the ESC failure is unlikely).
            As I mentioned in the previous post, if you had a milli-ohm meter, you could test the motor winding resistance to confirm whether the motor is good or bad. A tool like that measures resistance with high precision (similar to a regular Ohm meter). However, if you don't have one, it may not be worth buying it..
            You will not be able to measure the winding resistance of these motors correctly with a regular Ohm meter. However, you will be able to detect a complete open circuit (which could be the case, maybe worth trying). If testing resistance using a regular Ohm meter, any two connections between the 3 motor phases will read 0 ohm (or close to that). If a wire is broken, then you can detect it.
            The Starling 2 motor (3000kV) has around 0.360 - 0.370 Ohm phase-to-phase winding resistance.
            In order to confirm that the ESC is working properly, you could temporarily connect one of the working motors to the ESC Channel 0 and do the same spin test (using voxl-esc tools), just to confirm that the ESC Channel 0 is working fine.
            In order to fix the issue, you could order a new motor and replace it yourself (will be a lot cheaper): https://www.modalai.com/products/starling-2-replacement-parts?variant=49707605393712
            You could also send the whole drone back for repair (https://www.modalai.com/rma)
