    Running QVIO on a hires camera
    GPS-denied Navigation (VIO)
    • Rowan DempsterR
      Rowan Dempster
      Hi Modal team,
      Has anyone tried to run QVIO on one of the MPA pipes produced by a hires camera (either IMX214 or 412 I suppose)? Wondering if that's feasible, or if the rolling shutter on those sensors makes feature tracking quite impossible under dynamic movements. Happy to try it out myself if the answer is "unsure"!
      Rowan (Cleo Robotics)
        Alex Kushleyev ModalAI Team @Rowan Dempster
        @Rowan-Dempster ,
        We have not tried this recently, but it should work. Here are some tips:
        • Use IMX412 camera (M0161 or similar) because it has great image quality and the fastest readout speed of all of our cameras (IMX214 is not recommended for this, it is an old and "slow" camera sensor)
          • faster readout = less rolling shutter skew
        • use the latest camera drivers, which max out the camera operating speed in all modes : https://storage.googleapis.com/modalai_public/temp/imx412_test_bins/20250919/imx412_fpv_eis_20250919_drivers.zip
        • The readout times are documented here for all modes : https://docs.modalai.com/camera-video/low-latency-video-streaming/#imx412-operating-modes
        • for example 1996x1520 (2x2 binned) mode has about 5.5ms readout time, which is pretty short
        • QVIO (mvVISLAM.h) has a parameter "readout time", which suggests that it supports rolling shutter. I have not tried it myself, but i heard that it does work.
        mvVISLAM_Initialize(...float32_t readoutTime ..)
        @param readoutTime
              Frame readout time (seconds). n times row readout time. Set to 0 for
              global shutter camera.  Frame readout time should be (close to) but
              smaller than the rolling shutter camera frame period.
        Here is where this param is currently set to 0 in voxl-qvio-server : https://gitlab.com/voxl-public/voxl-sdk/services/voxl-qvio-server/-/blob/master/server/main.cpp?ref_type=heads#L371
        • in order to correctly use the readout time, you have to ensure that the camera pipeline indeed selects the correct camera mode (for which there is the corresponding readout time) : https://docs.modalai.com/camera-video/low-latency-video-streaming/#how-to-confirm-which-camera-resolution-was-selected-by-the-pipeline
          • also, readout time is printed out by voxl-camera-server when you run it in -d mode (readout time in nanoseconds here):
        VERBOSE: Received metadata for frame 86 from camera imx412
        VERBOSE: 	Timestamp: 69237313613
        VERBOSE: 	Gain: 1575
        VERBOSE: 	Exposure: 22769384
        VERBOSE: 	Readout Time: 16328284
        • keep the exposure low to avoid motion blur (IMX412 has quite a high analog gain, up to 22x and 16x digital gain). If you want to prioritize gain vs exposure, would need to tweak the auto exposure params in camera server (when you get to that point, i can help you)..
        • it would be interesting to compare performance against QVIO with AR0144 - that would probably require collecting images from AR0144 and IMX412 (side by side) + IMU data and running QVIO offline with each camera.
        Good luck if you try it! let me know if you have any other questions. Please keep in mind that QVIO is based on a closed-source library from Qualcomm and our support of QVIO is limited.
        Rowan DempsterR 1 Reply Last reply Reply Quote 0
        • Rowan DempsterR
          Rowan Dempster @Alex Kushleyev
          @Alex-Kushleyev Glad to hear you are optimistic about this! And thank you, as always, for the tips to get us started. I will hopefully dive into experimenting with this in the next week or so. Do you have a suggestion for which of the hires camera pipes we should use?
            @Rowan-Dempster , you should use a monochrome stream (_grey), since QVIO needs a RAW8 image.
            If you are not using MISP on hires cameras, that is fine, you can start off using the output of the ISP.
            You should calibrate the camera using whatever resolution you decide to try. This is to avoid any confusion, since if you using ISP pipeline, the camera pipeline may select a higher resolution and downscale + crop. So whenever you are changing resolutions, it is always good to do a quick camera calibration to confirm the camera parameters.
            When using MISP, we have more control over which camera mode is selected, because MISP gets the RAW data, not processed by the ISP, so we know the exact dimensions of the image sent from camera.
