  2. VOXL SDK and Software
  3. Boson 640 MIPI M0153 16-bit
camera
18 Posts 2 Posters 3.5k Views 1 Watching
    Also, a quick update.. after some additional testing, we are actually able to communicate with Boson via the CCI connection directly from VOXL2. Hopefully we will be able to enable (partial) Boson configuration from VOXL2 directly, avoiding the use of the USB connection for simple configuration change.
    Here is a sample script that can be used to test triggering FFC. The script uses cci-direct library which allows to communicate to cameras while they are running (in camera server).
    Before running this script, make sure the camera server is running and it is configured to enable Boson camera (and take note of the camera id (sw id, not slot)), which is needed by cci-direct and the script. This is also abit of a hack since we are writing part of the payload as the the address in addressed write (as it is common in i2c transactions), but Boson's i2c interface does not support addressing.
    #!/bin/bash
    if [ "$#" -eq 0 ]; then
    	echo "Error: No arguments provided."
    	echo "Usage: $0 <boson camera id>"
    	exit 1
    fi
    cam_id=$1
    #command to trigger FFC
    #(extra two 00's at the end to make it a multiple of 3, since we are sending 3 bytes at a time in this test)
    data="8E A1 00 0C 00 00 00 FC 00 05 00 07 FF FF FF FF 00 00"
    IFS=' ' read -r -a words <<< "$data"
    for (( i=0; i<${#words[@]}; i+=3 )); do
    	echo "${words[i]} ${words[i+1]} ${words[i+2]}"
    	voxl-cci-direct -c ${cam_id} -w 0x${words[i]}${words[i+1]} 0x${words[i+2]}
    done
    M Offline
    M Offline
    mkriesel
    @Alex-Kushleyev Cool, follow up then the Boson has an external sync pin, does the mipi board support this still?
    • M mkriesel
      @mkriesel , our M0153 / M0201 adapter does have an option to connect Boson to the common sync line that is used for synchronizing AR0144 tracking cameras (GPIO 109). This line is typically driven at 30Hz, but the frequency is adjustable.
      There is a resistor pad on M0153 / M0201 adapter which is DNI by default, so a 0-ohm resistor would need to be installed to enable this functionality. However, we have not verified that it works.
      It is on our to-do list to verify the Boson sync. Once we confirm that it works, I can provide instructions for installing the resistor if you wanted to enable that functionality. Boson's configuration will also need to be updated to enable the sync input, but it's not a big change.
      Let me get back to you next week..
        @mkriesel ,
        I did a basic test of configuring Boson for external sync using bosonSetExtSyncMode(FLR_BOSON_EXT_SYNC_MODE_E.FLR_BOSON_EXT_SYNC_SLAVE_MODE) in the FLIR python API.
        If the sync signal is absent, then Boson just stops sending frames (as expected). Once I installed the missing resistor on the ModalAI Boson adapter to patch the common 30FPS camera sync signal from VOXL2 to Boson, I started receiving frames from Boson at 30FPS. Adjusting the sync signal from 30 to 60FPS resulted in some FPS instability (as well as some minor flickering artifacts) in Boson frames due to the fact that the sync signal coming out of voxl2 has some jitter. Boson timing at 60FPS is very tight, so sync signal coming in too early can cut off the previous frame, so i believe that was happening.
        I also noticed that when the sync signal was at 30FPS, the FFC would take twice as long, which is interesting. I wonder if Boson indeed expects 60FPS sync signal and perhaps something may not work properly otherwise. will need to check Boson documentation..
        Also keep in mind that the tracking cameras (AR0144) cannot operate at 60FPS in sync'ed mode (different story). So, if you are using sync'ed AR0144 tracking cameras and would like to use 60FPS sync'ed Boson, this may not be possible with the same sync line.
        I will need to experiment with this some more. Can you please elaborate on the use of Boson sync in your application (and whether you need VOXL2 to generate the sync signal or you have your own sync signal)?
        M 1 Reply Last reply
          @mkriesel ,
          M Offline
          M Offline
          mkriesel
          Thanks for looking into this. At the moment there aren't any plans using the sync pin but we are trying to see if this is something worth looking into.
          Back to testing, I recently got the boson board in and am trying to test it but have run into an issue with trying to get the camera-server installed.
          I'm getting
          voxl-camera-server depends on libmodal-pipe (>= 2.14.0); however:
          Version of libmodal-pipe on system is 2.13.2.
          Then for libmodal-pipe 2.14.0
          dpkg: regarding libmodal-pipe_2.14.0_arm64.deb containing libmodal-pipe:
          libmodal-pipe conflicts with voxl-cpu-monitor (<< 0.7.0)
          voxl-cpu-monitor (version 0.6.0) is present and installed.
          Bu voxl-cpu-monitor 0.7.0
          dpkg: regarding voxl-cpu-monitor_0.7.0_arm64.deb containing voxl-cpu-monitor:
          voxl-cpu-monitor conflicts with libmodal-pipe (<< 2.14.0)
          libmodal-pipe (version 2.13.2) is present and installed.
          So I'm stuck in a bit of a circle with the libmodal-pipe if you could help out
          • M mkriesel
            I'm getting
            @mkriesel , oh yeah, i now that dpkg stuck issue..
            use dpkg --force-all -i <package.deb> , you can install voxl-cpu-monitor and libmodal-pipe together or separately.
              M Offline
              M Offline
              mkriesel
              Alright, I've tried a few things and I can't see to get things to work.
              voxl2-mini:~$ voxl-camera-server
              Setting MISP AWB to Auto
              MISP channels enabled in defaults : 0
              MISP channels enabled in config file: 0
              configuration for 1 cameras:
              cam #0
              type: boson-fpv
              bayer_type: 0
              enabled: 1
              camera_id: 0
              camera_id_second: -1
              fps: 30
              en_rotate: 0
              en_rotate2: 0
              en_preview:          1
              en_raw_preview:      1
              preview_width:       640
              preview_height:      512
              en_misp:             1
              misp_width:          640
              misp_height:         512
              en_small_video:      0
              small_video_width:   640
              small_video_height:  512
              en_large_video:      0
              large_video_width:   -1
              large_video_height:  -1
              en_snapshot:         0
              snap_width:          -1
              snap_height:         -1
              exif_focal_length:   0.000000
              exif_focal_len_35mm_format:0
              exif_fnumber:        0.000000
              ae_mode:             lme_msv
              msv_exposure_min_us: 20
              msv_exposure_max_us: 33000
              gain_min           : 54
              gain_max           : 8000
              standby_enabled:     0
              decimator:           1
              independent_exposure:0
              fsync_en: 0
              fsync_gpio: 109
              connected to mavlink pipe
              Starting Camera: boson (id #0)
              Opened GBM fd
              Created GBM device
              MISP Initializing for camera boson
              Detected 1 platform(s)
              Detected 1 GPU device(s)
              Estimated imu dt = 0.000977s
              Got unsupported format in getUVStartFromFmt, returning nullptr
              WARNING: OMX SetTargetBitrate: H265 CBR requires bps >= 3.0Mbit (2000000 bps provided). Using FPS hack. scale = 1.500000
              ------ voxl-camera-server: Started 1 of 1 cameras
              ERROR: Received "Result" error from camera: boson
              ERROR: Received "Buffer" error from camera: boson
              ERROR: Received "Request" error from camera: boson
              | Pipe Name | bytes | wide | hgt |exp(ms)| gain | frame id |latency(ms)| fps | mbps | format
              | boson |
              | boson_bayer |
              | boson_color |
              | boson_misp_encoded |
              I copied the drivers into /usr/lib/camera/ and both the 8 bit and 14 bit drivers you provided gave the same error running various combinations of the set and read python scripts you sent.
              (base) ➜ boson python3 boson_set_14bit.py
              C serial FSLP load
              Serial port open
              Software Version: 4 0 27141
              camera SN: 322022
              dvoSetOutputFormat:
              dvoSetType:
              dvoSetOutputIr16Format:
              roicSetFrameSkip:
              Apply Custom Settings:
              Save Settings To Flash:
              Reboot
              Closing com port and freeing serial port instance.
              Serial port close
              (base) ➜ boson python3 boson_read.py
              C serial FSLP load
              Serial port open
              camera SN: 322022
              dvoGetType:
              dvoGetOutputFormat:
              dvoGetOutputIr16Format:
              dvoGetLCDConfig:
              ClockInfo:
              27.0
              16
              Let me know if it seemed like I did something wrong, I tried both the J6 and J7 ports on the voxl 2 mini with the corresponding numbered driver.
              • M mkriesel
                cam #0
                type: boson-fpv
                bayer_type: 0
                enabled: 1
                camera_id: 0
                fps: 30
                en_rotate: 0
                en_rotate2: 0
                en_preview:          1
                en_raw_preview:      1
                preview_width:       640
                preview_height:      512
                en_misp:             1
                misp_width:          640
                misp_height:         512
                en_small_video:      0
                en_large_video:      0
                en_snapshot:         0
                snap_width:          -1
                snap_height:         -1
                ae_mode:             lme_msv
                gain_min           : 54
                gain_max           : 8000
                standby_enabled:     0
                decimator:           1
                fsync_en: 0
                fsync_gpio: 109
                Opened GBM fd
                Created GBM device
                | boson |
                | boson_bayer |
                | boson_color |
                C serial FSLP load
                Serial port open
                camera SN: 322022
                dvoSetOutputFormat:
                dvoSetType:
                roicSetFrameSkip:
                Reboot
                Serial port close
                C serial FSLP load
                Serial port open
                camera SN: 322022
                dvoGetType:
                dvoGetOutputFormat:
                dvoGetLCDConfig:
                ClockInfo:
                27.0
                16
                @mkriesel
                Please make sure that you only have one sensormodule file for boson for the given configuration in /usr/lib/camera/.
                One thing to check is to see if the Boson is in active mipi state by default. You can add this to your boson_read.py file :
                print('dvoGetMipiStartState: ')
                result, mipi_start_state = myCam.dvoGetMipiStartState()
                print(result)
                print(mipi_start_state)
                print('dvoGetMipiState: ')
                result, mipi_state = myCam.dvoGetMipiState()
                print(result)
                print(mipi_state)
                My output is:
                FLR_RESULT.R_SUCCESS
                FLR_DVO_MIPI_STATE_E.FLR_DVO_MIPI_STATE_ACTIVE
                dvoGetMipiState:
                FLR_DVO_MIPI_STATE_ACTIVE is 2, FLR_DVO_MIPI_STATE_OFF is 0
                If your sensor does not show active start state, then it may need to be set using the following:
                myCam.dvoSetMipiStartState(FLR_DVO_MIPI_STATE_E.FLR_DVO_MIPI_STATE_ACTIVE)
                If this still does not work, it is possible that my script does not do the full setup for mipi output, so you may want to try using the FLIR GUI for the initial setup (for 8 bit post AGC and use the default 8 bit sensormodule): https://docs.modalai.com/M0153/#boson-software-setup
                  @mkriesel
                  print(result)
                  print(result)
                  print(mipi_state)
                  My output is:
                  dvoGetMipiState:
                  #13
                  @mkriesel , I have updated the boson configuration and read scripts (boson_read.py, boson_set_8bit.py, etc) to include configuring additional settings like mipi start state, dvo output interface, etc. Please download them again (from links earlier in this thread) and try again. Also, just to confirm that the original Boson setup instruction using the FLIR GUI should work for 8 bit format.
                  Just one note, even though I set myCam.dvoSetOutputFormat(FLR_DVO_OUTPUT_FORMAT_E.FLR_DVO_IR16), where FLR_DVO_IR16 = 3, when i read back the configuration, i get the default format (2) : FLR_DVO_OUTPUT_FORMAT_E.FLR_DVO_DEFAULT_FORMAT = 2 . It seems that in your output the ouput format is set to 3 - i am not sure why, there could be some minor quirks in the boson firmware.
                  In any case, please try the GUI and updated scripts and let me know how it goes!
                    M Offline
                    M Offline
                    mkriesel
                    @Alex-Kushleyev It seems to be working now, I'll do more testing but this looks correct
                    | boson | 327680 | 640 | 512 | 0.00 | 799 | 163 | 21.6 | 60.0 | 157.3 | RAW8
                    | boson_bayer | 655360 | 640 | 512 | 0.00 | 0 | 163 | 20.0 | 60.0 | 314.6 | RAW16
                    | boson_color | 983040 | 640 | 512 | 0.00 | 799 | 163 | 22.7 | 60.0 | 471.9 | RGB
                    | boson_misp_encoded | 8826 | 640 | 512 | 0.00 | 799 | 163 | 25.5 | 60.0 | 4.1 | H265 (P)
                    Thanks for the help! Also, what version of the bosonSDK are you using for your python scripts? My version (3.0) doesn't have the dvoSetMipiStartState and a few other functions and I can't find a higher version on their website?
                    • M mkriesel
                      @mkriesel , I am glad that you got it working! You should also be able to view the boson output in voxl-portal -- for the 14 bit case, there is a very simple re-scaling done from 14 to 8 bit, just for testing (WIP).
                      I am using SDK4.0_Boson_Plus_SDK. You should probably contact Flir to get access to it, since we can't distribute it.
                        M Offline
                        M Offline
                        mkriesel
                        I'm trying to pull the images off and they seem to be corrupted somewhat. It almost seems like I'm getting the 16 bit image but in an 8 bit format. I'm subscribing to the boson_bayer and the image I'm getting seems to be the correct size and length but when I save its not correct. The RAW 8 stream I get on the voxl-portal looks the same, which I would expect for testing.
                        Heres what I'm getting for reference
                        https://drive.google.com/file/d/1fG5XEPM-b1NbC6H9R4jWSvZTDxm-a6Y_/view?usp=sharing
                        And then code I'm using to save it
                        static void _frame_cb(__attribute__((unused)) int ch, camera_image_metadata_t meta, char* frame, void* context)
                            CameraInterface* interface = (CameraInterface*)context;
                            if (interface->GetState() != ST_RUNNING) {
                                return;
                            if (interface->ShouldSkip()) {
                                return;
                            if (meta.format == IMAGE_FORMAT_NV12) {
                            else if (meta.format == IMAGE_FORMAT_RAW8) {
                            else if (meta.format == IMAGE_FORMAT_RAW10) {
                            else if (meta.format == IMAGE_FORMAT_RAW16) {
                                std::cout << "16 bit image " << meta.size_bytes << " stride " << meta.stride << std::endl;
                                int input_height = meta.height;
                                int input_width  = meta.width;
                                size_t frame_size = input_width * input_height * 2;
                                char outname[100];
                                std::string image_folder_name = "/data/pgm_frames";
                                // uint16_t* frame_data = reinterpret_cast<uint16_t*>(frame);
                                sprintf(outname, "%s/frame_%06lu.pgm", image_folder_name.c_str(), meta.timestamp_ns);
                                printf("Output filename: %s\n", outname);
                                // out_image.write(reinterpret_cast<char*>(pixels), IMAGE_PIXELS * sizeof(uint16_t));
                                std::ofstream out_image(outname, std::ios::binary | std::ios::out);
                                out_image << "P5\n640 512 65535\n";
                                out_image.write(frame, frame_size);
                            else {
                                // Not implemented
                                std::cout << "other" << std::endl;
                        Any thoughts?
                        • M mkriesel
                                  return;
                                  return;
                                  char outname[100];
                              else {
                                  // Not implemented
                          Any thoughts?
                          @mkriesel , it looks like potentially an little vs big endian issue when using PGM - can you try to swap the byte order?
                            #18
                            save image on voxl:
                            voxl-record-raw-image boson640_bayer -n 1 -d ./
                            display image using python3:
                            import cv2
                            import numpy as np
                            WIDTH  = 640
                            HEIGHT = 512
                            FILENAME = "boson640_bayer_640x512.gray"
                            # read 16-bit file
                            img = np.fromfile(FILENAME, dtype=np.uint16).reshape(HEIGHT, WIDTH)
                            # simple normalize
                            vmin     = np.min(img)
                            vmax     = np.max(img)
                            img_8bit = cv2.convertScaleAbs(img-vmin, alpha=255.0/(vmax-vmin))
                            # show image
                            cv2.imshow("Normalized Image", img_8bit)
                            cv2.waitKey(3000)
                            cv2.destroyAllWindows()
