  2. VOXL SDK and Software
  3. voxl-camera-server segmentation fault
camera
4 Posts 2 Posters 1.1k Views 1 Watching
  • P Offline
    P Offline
    psafi
    I am seeing a pattern which voxl-camera-server will crash every time I have an image sensor plugged into a specific port (J6) on my VOXL. Could I have accidentally damaged hardware by plugging in the adapter board the wrong way?
    P 1 Reply Last reply
    • P psafi
      P Offline
      P Offline
      psafi
      @psafi with debug turned on:
      VERBOSE: cci-direct: using voxl_platform_mod config 1 and 2 layout
      DEBUG:   Cam idx: 0, Cam slot: 0, Slave Address: 0x0030, Sensor Id: 0x0356
      DEBUG:   Cam idx: 1, Cam slot: 2, Slave Address: 0x0030, Sensor Id: 0x0356
      connected to mavlink pipe
      Connected to cpu-monitor
      DEBUG:
      ------ voxl-camera-server: Starting IMU manager
      DEBUG:   ------ voxl-camera-server: Starting 2 cameras
      Starting Camera: tracking_front (id #0)
      DEBUG:   Checking Gain limits for Camera: tracking_front
      DEBUG:   Using gain limits min: 54 max: 1596
      DEBUG:   cam ID 0 checking for fmt:   38  w: 1280 h:  800 o:   0
      DEBUG:   	==> option   0: format= 34 width=1280 height= 800 is_input=0
      DEBUG:   	==> option   4: format= 34 width=1280 height= 800 is_input=1
      DEBUG:   	==> option   8: format= 35 width=1280 height= 800 is_input=0
      DEBUG:   	==> option  12: format= 35 width=1280 height= 800 is_input=1
      DEBUG:   	==> option  16: format= 33 width=1280 height= 800 is_input=0
      DEBUG:   	==> option  20: format= 34 width=1280 height= 768 is_input=0
      DEBUG:   	==> option  24: format= 34 width=1280 height= 768 is_input=1
      DEBUG:   	==> option  28: format= 35 width=1280 height= 768 is_input=0
      DEBUG:   	==> option  32: format= 35 width=1280 height= 768 is_input=1
      DEBUG:   	==> option  36: format= 33 width=1280 height= 768 is_input=0
      DEBUG:   	==> option  40: format= 34 width=1280 height= 720 is_input=0
      DEBUG:   	==> option  44: format= 34 width=1280 height= 720 is_input=1
      DEBUG:   	==> option  48: format= 35 width=1280 height= 720 is_input=0
      DEBUG:   	==> option  52: format= 35 width=1280 height= 720 is_input=1
      DEBUG:   	==> option  56: format= 33 width=1280 height= 720 is_input=0
      DEBUG:   	==> option  60: format= 34 width=1024 height= 738 is_input=0
      DEBUG:   	==> option  64: format= 34 width=1024 height= 738 is_input=1
      DEBUG:   	==> option  68: format= 35 width=1024 height= 738 is_input=0
      DEBUG:   	==> option  72: format= 35 width=1024 height= 738 is_input=1
      DEBUG:   	==> option  76: format= 33 width=1024 height= 738 is_input=0
      DEBUG:   	==> option  80: format= 34 width=1024 height= 768 is_input=0
      DEBUG:   	==> option  84: format= 34 width=1024 height= 768 is_input=1
      DEBUG:   	==> option  88: format= 35 width=1024 height= 768 is_input=0
      DEBUG:   	==> option  92: format= 35 width=1024 height= 768 is_input=1
      DEBUG:   	==> option  96: format= 33 width=1024 height= 768 is_input=0
      DEBUG:   	==> option 100: format= 34 width= 864 height= 480 is_input=0
      DEBUG:   	==> option 104: format= 34 width= 864 height= 480 is_input=1
      DEBUG:   	==> option 108: format= 35 width= 864 height= 480 is_input=0
      DEBUG:   	==> option 112: format= 35 width= 864 height= 480 is_input=1
      DEBUG:   	==> option 116: format= 33 width= 864 height= 480 is_input=0
      DEBUG:   	==> option 120: format= 34 width= 800 height= 600 is_input=0
      DEBUG:   	==> option 124: format= 34 width= 800 height= 600 is_input=1
      DEBUG:   	==> option 128: format= 35 width= 800 height= 600 is_input=0
      DEBUG:   	==> option 132: format= 35 width= 800 height= 600 is_input=1
      DEBUG:   	==> option 136: format= 33 width= 800 height= 600 is_input=0
      DEBUG:   	==> option 140: format= 34 width= 800 height= 480 is_input=0
      DEBUG:   	==> option 144: format= 34 width= 800 height= 480 is_input=1
      DEBUG:   	==> option 148: format= 35 width= 800 height= 480 is_input=0
      DEBUG:   	==> option 152: format= 35 width= 800 height= 480 is_input=1
      DEBUG:   	==> option 156: format= 33 width= 800 height= 480 is_input=0
      DEBUG:   	==> option 160: format= 34 width= 720 height= 480 is_input=0
      DEBUG:   	==> option 164: format= 34 width= 720 height= 480 is_input=1
      DEBUG:   	==> option 168: format= 35 width= 720 height= 480 is_input=0
      DEBUG:   	==> option 172: format= 35 width= 720 height= 480 is_input=1
      DEBUG:   	==> option 176: format= 33 width= 720 height= 480 is_input=0
      DEBUG:   	==> option 180: format= 34 width= 640 height= 512 is_input=0
      DEBUG:   	==> option 184: format= 34 width= 640 height= 512 is_input=1
      DEBUG:   	==> option 188: format= 35 width= 640 height= 512 is_input=0
      DEBUG:   	==> option 192: format= 35 width= 640 height= 512 is_input=1
      DEBUG:   	==> option 196: format= 33 width= 640 height= 512 is_input=0
      DEBUG:   	==> option 200: format= 34 width= 640 height= 480 is_input=0
      DEBUG:   	==> option 204: format= 34 width= 640 height= 480 is_input=1
      DEBUG:   	==> option 208: format= 35 width= 640 height= 480 is_input=0
      DEBUG:   	==> option 212: format= 35 width= 640 height= 480 is_input=1
      DEBUG:   	==> option 216: format= 33 width= 640 height= 480 is_input=0
      DEBUG:   	==> option 220: format= 34 width= 640 height= 400 is_input=0
      DEBUG:   	==> option 224: format= 34 width= 640 height= 400 is_input=1
      DEBUG:   	==> option 228: format= 35 width= 640 height= 400 is_input=0
      DEBUG:   	==> option 232: format= 35 width= 640 height= 400 is_input=1
      DEBUG:   	==> option 236: format= 33 width= 640 height= 400 is_input=0
      DEBUG:   	==> option 240: format= 34 width= 640 height= 360 is_input=0
      DEBUG:   	==> option 244: format= 34 width= 640 height= 360 is_input=1
      DEBUG:   	==> option 248: format= 35 width= 640 height= 360 is_input=0
      DEBUG:   	==> option 252: format= 35 width= 640 height= 360 is_input=1
      DEBUG:   	==> option 256: format= 33 width= 640 height= 360 is_input=0
      DEBUG:   	==> option 260: format= 34 width= 352 height= 288 is_input=0
      DEBUG:   	==> option 264: format= 34 width= 352 height= 288 is_input=1
      DEBUG:   	==> option 268: format= 35 width= 352 height= 288 is_input=0
      DEBUG:   	==> option 272: format= 35 width= 352 height= 288 is_input=1
      DEBUG:   	==> option 276: format= 33 width= 352 height= 288 is_input=0
      DEBUG:   	==> option 280: format= 34 width= 320 height= 240 is_input=0
      DEBUG:   	==> option 284: format= 34 width= 320 height= 240 is_input=1
      DEBUG:   	==> option 288: format= 35 width= 320 height= 240 is_input=0
      DEBUG:   	==> option 292: format= 35 width= 320 height= 240 is_input=1
      DEBUG:   	==> option 296: format= 33 width= 320 height= 240 is_input=0
      DEBUG:   	==> option 300: format= 34 width= 240 height= 320 is_input=0
      DEBUG:   	==> option 304: format= 34 width= 240 height= 320 is_input=1
      DEBUG:   	==> option 308: format= 35 width= 240 height= 320 is_input=0
      DEBUG:   	==> option 312: format= 35 width= 240 height= 320 is_input=1
      DEBUG:   	==> option 316: format= 33 width= 240 height= 320 is_input=0
      DEBUG:   	==> option 320: format= 34 width= 176 height= 144 is_input=0
      DEBUG:   	==> option 324: format= 34 width= 176 height= 144 is_input=1
      DEBUG:   	==> option 328: format= 35 width= 176 height= 144 is_input=0
      DEBUG:   	==> option 332: format= 35 width= 176 height= 144 is_input=1
      DEBUG:   	==> option 336: format= 33 width= 176 height= 144 is_input=0
      DEBUG:   	==> option 340: format= 37 width=1280 height= 800 is_input=0
      DEBUG:   	==> option 344: format= 38 width=1280 height= 800 is_input=0
      DEBUG:   	==> option 348: format= 32 width=1280 height= 800 is_input=0
      DEBUG:   	==> option 352: format= 36 width=1280 height= 800 is_input=0
      VERBOSE: Successfully found configuration match for camera 0: 1280x800
      MISP Initializing for camera tracking_front
       Detected 1 platform(s)
       Detected 1 GPU device(s)
      Estimated imu dt = 0.000976s
      DEBUG:   Entering pitmode
      DEBUG:   Value of pitmode_active is: 1
      Segmentation fault:
      Fault thread: voxl-camera-ser(tid: 2486)
      Segmentation fault
      • P psafi
        DEBUG:
        Segmentation fault:
        Segmentation fault
        P Offline
        P Offline
        psafi
        wrote on last edited by psafi
        @psafi UPDATE: I re-flashed the SDK and it fixed it. voxl-camera-server is running and cameras are working. I am setting up VIO for a custom system. I believe a change I made along the way for VIO set up process could have caused this.
        • P psafi
          @psafi ,
          There was a libmodal-pipe library update earlier this week, so if you have updated that library on your VOXL2, then any other library or app (which uses libmodal-pipe) that you deploy to that VOXL2 needs to be built against the same version of libmodal-pipe.
          So if you want use the latest dev version, you would update the drone.
          make sure you are using dev for apt sources:
          in /etc/apt/sources.list.d/modalai.list:
          deb [trusted=yes] http://voxl-packages.modalai.com/ ./dists/qrb5165/dev/binary-arm64/
          then update libmodal-pipe on VOXL2, this should also update any other packages that depend on it.
          apt update
          apt install libmodal-pipe
          When building your application using voxl-cross docker, make sure you run the following in order to get the latest deps from dev:
          ./install_build_deps.sh qrb5165 dev
          Most of the time you can get away not doing this, but this time there was an interface change in libmodal-pipe, so a mismatch occurred.
