    VOXL2 Mini Not Detected via ADB/Fastboot – QDL Mode Behavior and Flashing Issues
    • P
      Piyush Singh
      Hello Modal AI Team,
      I am facing an issue with my VOXL2 Mini and would appreciate your assistance. Below are my detailed observations and the steps I’ve taken so far:
      Observation 1: ADB and Fastboot Detection Failure
      • Initially, when the VOXL2 Mini is powered with SW2 in the OFF position, the device does not appear when running adb devices or adb shell.
      • It is also not detected in lsusb.
      • When I turn ON the SW2 switch, the device shows up in QDL mode in the lsusb output.
      • At this point, I attempted to reflash the image using the Flash Flat Build method, but the process failed (see attached screenshots).
      • I also tried using the install.sh script to flash the image, but it couldn’t detect the VOXL2 Mini—neither through adb nor fastboot.
      Observation 2: Delayed QDL Mode Detection
      When SW2 is OFF and the board is powered:
      • Only the D1 LED turns on initially.
      • Nothing is detected in lsusb.
      • However, after 7–8 minutes, the DS2 LED turns on, and now the device appears in QDL mode in lsusb—even though SW2 remains OFF.
        Additional Info:
        Screenshots of the QDL detection and flash errors are attached for your reference.
      I would like help understanding:
      1. Why ADB/Fastboot modes are not accessible.
      2. Why the board defaults or switches to QDL mode after some delay even when SW2 is OFF.
      3. How to properly recover or reflash the VOXL2 Mini in this state.
        Alex Kushleyev ModalAI Team @Piyush Singh
        @tom , would you be able to help?
        • Z
          ZuraNeb
          check the folder inside qdl/qfill_app/modalai/voxl2-mini_SDK......
          Make sure that the ufc folder is present inside (occasionally after downloading the Flat Build and unzipping there might be voxl2-mini_SDL/voxl-2_mini_SDK). Make sure the path is qdl/qfill_app/modalai/voxl2-mini_SDK....../ufs
          Edit: Also, you have the wrong download for the flat build. You are currently using the SDK instead of the flat build file. We will send you the correct link to the folder in a few minutes
          P 1 Reply Last reply Reply Quote 0
          • P
            Piyush Singh @ZuraNeb
            @ZuraNeb Please provide the correct link.
