  3. ov7251 tracking camera not being initialized with unsupported preview config
voxl-2
17 Posts 2 Posters 2.1k Views 2 Watching
    @brianaustin, M0135 should work for this application. I just thought you were using a different Y flex cable plugged into J7.
    Also, it does look like you have the cameras plugged in correctly.
    Please follow my suggestion in previous post and swap ov7251 and imx214 places (taking note of pin 1 orientations) and see if ov7251 can be successfully probed in slot 3 and imx214 in slot 2.
    B Offline
    B Offline
    brianaustin
    wrote on last edited by brianaustin
    I followed your instructions above and here is the output of the camera-server command
    voxl2:/$ voxl-camera-server -l
    DEBUG:   Cam idx: 0, Cam slot: 0, Slave Address: 0x00E2, Sensor Id: 0x7750
    DEBUG:   Cam idx: 1, Cam slot: 1, Slave Address: 0x00E4, Sensor Id: 0x7750
    DEBUG:   Number of cameras: 2
    Stats for camera: 0
     640 x  480
     640 x  480 HAL_PIXEL_FORMAT_RAW10
     640 x  480 HAL_PIXEL_FORMAT_RAW12
     640 x  480 HAL_PIXEL_FORMAT_RAW16
     640 x  480 HAL_PIXEL_FORMAT_RAW_OPAQUE
    	min = 54
    	max = 3451
    	3451
    	min = 0ns
    	max = 1266732525ns
    Stats for camera: 1
     640 x  480
    	min = 54
    	max = 3451
    	3451
    	min = 0ns
    	max = 1266732525ns
    Number of cameras detected: 2
    the portal only shows Mulit-View but there are no streams shown and only a checkbox that I can select but no images. The Stereo Sensor does not work now either
    It looks like some I2C bus errors in dmesg
    [   16.550375] CAM_ERR: CAM-CCI: cam_cci_irq: 238 Base:        pK-error, M0_Q1 NACK ERROR: 0x10000000
    [   16.550450] CAM_ERR: CAM-CCI: cam_cci_read: 1329 ERROR with Slave 0x20:
    [   16.550460] CAM_ERR: CAM-CCI: cam_cci_read_bytes: 1613 failed to read rc:-22
    [   16.550467] CAM_ERR: CAM-SENSOR: cam_cci_i2c_read: 35 rc = -22
    [   16.550476] CAM_WARN: CAM-SENSOR: cam_sensor_match_id: 707 read id: 0x0 expected id 0x214:
    [   16.550600] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Dropping the link to regulator.79
    [   16.554341] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Dropping the link to regulator.60
    [   16.554478] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Dropping the link to regulator.55
    [   16.554597] qcom,camera ac50000.qcom,cci:qcom,cam-sensor2: Dropping the link to regulator.59
    [   16.583851] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.59
    [   16.586402] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.55
    [   16.588680] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.60
    [   16.588811] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Linked as a consumer to regulator.79
    [   16.613251] CAM_INFO: CAM-SENSOR: cam_sensor_set_alt_id: 731 [Applying Alternative Address] : Sensor Index   : 391368884
    [   16.613261] CAM_INFO: CAM-SENSOR: cam_sensor_set_alt_id: 732 [Applying Alternative Address] : Slave Address  : 0xE2
    [   16.613269] CAM_INFO: CAM-SENSOR: cam_sensor_set_alt_id: 733 [Applying Alternative Address] : Slave sensor id: 0x7750
    [   16.613276] CAM_INFO: CAM-SENSOR: cam_sensor_set_alt_id: 734 [Applying Alternative Address] : cci_client sid : 0x71
    [   16.613447] CAM_ERR: CAM-CCI: cam_cci_irq: 258 Base:        pK-error, M1_Q0 NACK ERROR: 0x20000000
    [   16.613507] CAM_ERR: CAM-CCI: cam_cci_wait: 270 failed rc -22
    [   16.613514] CAM_ERR: CAM-CCI: cam_cci_transfer_end: 345 failed rc -22
    [   16.613522] CAM_ERR: CAM-CCI: cam_cci_data_queue: 870 Slave: 0xe0 failed rc -22
    [   16.613529] CAM_ERR: CAM-CCI: cam_cci_i2c_write: 1450 failed rc: -22
    [   16.613536] CAM_ERR: CAM-SENSOR: cam_cci_i2c_write_table_cmd: 123 Failed rc = -22
    [   16.613545] CAM_ERR: CAM-SENSOR: cam_sensor_set_alt_id: 768 [Applying Alternative Address] : Probe : camera_io_dev_write failed: rc=-22
    [   16.613699] CAM_ERR: CAM-CCI: cam_cci_irq: 264 Base:        pK-error, M1_Q1 NACK ERROR: 0x40000000
    [   16.613881] CAM_ERR: CAM-CCI: cam_cci_read: 1329 ERROR with Slave 0xe0:
    [   16.613892] CAM_ERR: CAM-CCI: cam_cci_read_bytes: 1613 failed to read rc:-22
    [   16.613899] CAM_ERR: CAM-SENSOR: cam_cci_i2c_read: 35 rc = -22
    [   16.613908] CAM_WARN: CAM-SENSOR: cam_sensor_match_id: 707 read id: 0x0 expected id 0x7750:
    [   16.614039] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.79
    [   16.627984] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.60
    [   16.628331] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.55
    [   16.628548] qcom,camera ac50000.qcom,cci:qcom,cam-sensor3: Dropping the link to regulator.59
    [   16.686142] CAM_WARN: CAM-CRM: cam_req_mgr_close: 160 release invoked associated userspace process has died
    • B brianaustin
      Stats for camera: 0
       640 x  480
      	min = 54
      	max = 3451
      	3451
      	min = 0ns
      	max = 1266732525ns
      Stats for camera: 1
       640 x  480
      	min = 54
      	max = 3451
      	3451
      	min = 0ns
      	max = 1266732525ns
      @brianaustin , thank you for running the test. The results are not conclusive. Let's try one more thing.
      • Please list sensormodule files of /usr/lib/camera right now, just to double check:
      ls /usr/lib/camera/*sensormodule*
      at this point you should have the following, which will support either configuration of ov7251 and imx214 (either slot 2 or 3). It is OK that there are more sensormodule files than cameras - for the ones that are not valid for the given configuration, the camera pipeline will try to probe the camera, will not find it, and will move on to the next sensormodlue.
      com.qti.sensormodule.imx214_2.bin
      com.qti.sensormodule.imx214_3.bin
      com.qti.sensormodule.ov7251_2.bin
      com.qti.sensormodule.ov7251_3.bin
      com.qti.sensormodule.ov7251_combo_0.bin
      com.qti.sensormodule.ov7251_combo_1.bin
      • disconnect OV7251 completely and test camera scan again (double check IMX214 is plugged in correctly, with flex cable pointing towards the center of the M0135 board). please let me know if IMX214 is detected
      • keep OV7251 disconnected and plug IMX214 back into slot 3 and do the scan again to make sure IMX214 is detected in the slot 3, which was working before.
      If you have another M0135 or ov7251 (fisheye) to try, you could do that to help figure what is not working properly, M0135 or the ov7251 camera.
      B 1 Reply Last reply
        B Offline
        B Offline
        brianaustin
        @Alex-Kushleyev said in ov7251 tracking camera not being initialized with unsupported preview config:
        ls /usr/lib/camera/sensormodule
        voxl2:/$ ls -l /usr/lib/camera/*sensormodule*
        -rw-r--r-- 1 root root 149272 Mar  4 14:48 /usr/lib/camera/com.qti.sensormodule.imx214_2.bin
        -rw-r--r-- 1 root root 149272 Feb 27 21:14 /usr/lib/camera/com.qti.sensormodule.imx214_3.bin
        -rw-r--r-- 1 root root 142472 Feb 27 21:14 /usr/lib/camera/com.qti.sensormodule.ov7251_2.bin
        -rw-r--r-- 1 root root 142472 Mar  4 14:49 /usr/lib/camera/com.qti.sensormodule.ov7251_3.bin
        -rw-r--r-- 1 root root  56280 Feb 27 21:14 /usr/lib/camera/com.qti.sensormodule.ov7251_combo_0.bin
        -rw-r--r-- 1 root root  56280 Feb 27 21:14 /usr/lib/camera/com.qti.sensormodule.ov7251_combo_1.bin
        "disconnect OV7251 completely and test camera scan again (double check IMX214 is plugged in correctly, with flex cable pointing towards the center of the M0135 board). please let me know if IMX214 is detected"
        Not detected
        "keep OV7251 disconnected and plug IMX214 back into slot 3 and do the scan again to make sure IMX214 is detected in the slot 3, which was working before."
        Detected
        I don't have any other sensors to test out. Should I order the other sensor cable referenced in the picture you posted earlier?
        • B brianaustin
          Not detected
          Detected
          @brianaustin ,
          Thanks for running those tests. Since plugging in IMX214 into slot 2 (J7L) did not result in successful detection of the camera, it is likely that M0135 adapter is faulty.
          However, since IMX214 does work in slot 3 (J7U), my expectation was that ov7251 would work in slot 3 as well, but that was not the case.
          Another thing to try is to see if the single OV7251 camera can be detected in slot 0:
          • unplug the stereo flex from J6 and just leave the small interposer M0076 in J6
          • connect the single tracking camera ov7251 where the stereo pair was connected. Note that when tracking ov7251 is correctly plugged into VOXL2 J6 via M0076, the tracking camera flex will point away from the voxl2 board, see image below
          • you dont need to change any sensormodules because you already had the stereo set up and for detection purposes, the combo driver for ov7251 will be able to detect the camera.
          • since we know that M0076 is working (stereo is working), this test will tell us if the tracking ov7251 is working or not.
            @brianaustin ,
            B Offline
            B Offline
            brianaustin
            Thanks! That worked
            DEBUG:   Number of cameras: 1
            Stats for camera: 0
             640 x  480
            	min = 54
            	max = 3451
            	3451
            	min = 0ns
            	max = 1266732525ns
            Number of cameras detected: 1
            Looks like I need to get a new dual connector or the other cable yeah?
            • B brianaustin
              Thanks! That worked
              Stats for camera: 0
               640 x  480
              	min = 54
              	max = 3451
              	3451
              	min = 0ns
              	max = 1266732525ns
              #13
              @brianaustin , great!
              Now, one more test 🙂
              Take the M0076 with the tracking OV7251 from J6 and plug into J7. You already have the sensormodule for slot 2 in place for J7L, so detection should work. Hopefully this works and this would confirm that J7L camera path is working.
              BTW you should be able to actually test the feed from the camera using the M0076 connection to J6 and J7 (just turn off other cameras in config, or maybe even leaving them enabled will work because camera server will just skip the undetected cameras).
              Then you would need a new M0135 interposer (you can submit RMA request at https://www.modalai.com/rma)
                B Offline
                B Offline
                brianaustin
                DEBUG:   Cam idx: 0, Cam slot: 2, Slave Address: 0x00E2, Sensor Id: 0x7750
                Stats for camera: 0
                 640 x  480
                 640 x  480
                 640 x  480
                	min = 54
                	max = 3451
                	3451
                	min = 0ns
                	max = 1266732525ns
                I reconfigured and the tracking camera works! that was a first and thank you for that!
                OK, I guess NOW we have determined the dual sensor connector board is defective?
                • B brianaustin
                  Stats for camera: 0
                   640 x  480
                   640 x  480
                   640 x  480
                  	min = 54
                  	max = 3451
                  	3451
                  	min = 0ns
                  	max = 1266732525ns
                  #15
                  @brianaustin , YES!
                  Please submit and RMA form to request a replacement M0135 board. If you need a replacement more urgently, you way want to buy another M0135 and you will have another one as a back up (and future expansion).
                    @brianaustin , YES!
                    B Offline
                    B Offline
                    brianaustin
                    Received the new connector and everything now works! All cameras are operational and looking fantastic.
                    Thank you!
                    • B brianaustin
                      Thank you!
                      @brianaustin great to hear, thanks for the update!
