    VOXL Connection to MAVLINK server failed using pymavlink
    • S
      svempati
      Hello, I am trying to read mavlink messages like the pressure and altitude from the VOXL 2 sensors using pymavlink. I wanted to make sure that the udpin to the mavlink connection is correct?
      I am having trouble connecting to the mavlink server. I set the port number to 14557 based on the first diagram in this page: (https://docs.modalai.com/mavlink/).
      When I use localhost as the port, . When I use localhost, I get an error that says OSError: [Errno 98] Address already in use, and when I use the IP address 192.168.8.10 it gives an error that says OSError: [Errno 99] Cannot assign requested address.
      If that is not the correct IP address, how can I find the IP address for my specific VOXL? It is worth noting that my VOXL isn't connected to the internet, but is physically connected to the flight controller by wire.
      Thanks for your help!
      # MAVLINK Common Message Set: https://mavlink.io/en/messages/common.html
      from pymavlink import mavutil
      the_connection = mavutil.mavlink_connection('udpin:192.168.8.10:14557')
      the_connection.wait_heartbeat()
      print("Heartbeat from system (system %u component %u)" % (the_connection.target_system, the_connection.target_component))
      while True:
          try:
              # local xyz position
              msg_pos = the_connection.recv_match(type='LOCAL_POSITION_NED', blocking=True)
              print(msg_pos.x, msg_pos.y, msg_pos.z)
              # altitude
              msg_altitude = the_connection.recv_match(type='ALTITUDE', blocking=True)
              print(msg_altitude.altitude_local, msg_altitude.altitude_relative)
              # pressure
              msg_pressure = the_connection.recv_match(type='SCALED_PRESSURE', blocking=True)
              print(msg_pressure.press_abs)
          except KeyboardInterrupt:
              print('Terminating mavlink...')
              break
        tom admin @svempati
        @svempati You can run ifconfig to view the IP addresses for your various network interfaces on voxl2, if you're using wifi then you'll want to look at wlan0
        • S
          svempati @tom
          @tom I ran ifconfig on voxl2, but I haven't found anything on wlan0. This is the output I get after running that command:
          bond0: flags=5123<UP,BROADCAST,MASTER,MULTICAST>  mtu 1500
                  ether fe:ca:d2:74:91:69  txqueuelen 1000  (Ethernet)
                  RX packets 0  bytes 0 (0.0 B)
                  TX packets 0  bytes 0 (0.0 B)
          dummy0: flags=195<UP,BROADCAST,RUNNING,NOARP>  mtu 1500
                  inet6 fe80::e2a:ce35:6c11:d803  prefixlen 64  scopeid 0x20<link>
                  ether de:92:20:5e:07:c9  txqueuelen 1000  (Ethernet)
                  TX packets 25  bytes 7462 (7.4 KB)
                  RX packets 368130  bytes 35420354 (35.4 MB)
                  TX packets 368130  bytes 35420354 (35.4 MB)
          would any of these help with finding the voxl's ip address?
            tom admin @svempati
            @svempati Do you have a wifi dongle connected to VOXL2?
            • S
              svempati @tom
              @tom No I don't have a wifi dongle connected.
                tom admin @svempati
                @svempati Are you trying to access the mavlink data from VOXL 2 itself or from an offboard computer / ground station?
