  3. GPS never published
GPS never published
5 Posts 3 Posters 798 Views 1 Watching
  • groupoG Offline
    groupoG Offline
    groupo
    A while ago I posted about having a lower number of satellites in one of my sentinels (7-13) compared to my other one (20). Today the latter sentinel's GPS stopped working. I have clicked through a few forums and tried some qshell commands to no avail. I saw some other posts about the diagnostic work differing with the addition of a 5G modem, which I have. What should I do?
    groupoG 1 Reply Last reply
    • groupoG groupo
      groupoG Offline
      groupoG Offline
      groupo
      @groupo Any traction?
      ben grocholskyB 1 Reply Last reply
      • groupoG groupo
        ben grocholskyB Offline
        ben grocholsky
        @groupo From the description it's hard to tell if the GPS stopped communicating or stopped getting a usable solution. L1 GPS is very easily degraded by RF interference from high speed signals on wires or communications devices. Look at the jamming_indicator field in the sensor_gps uorb to get a better sense of if you have a RF interference issue. Value much above 40 indicate too much interference. Grounding and shielding the wires from the voxl2 to the GPS can improve this.
        There is a bit more confusion in that px4 health checks by default need > 7 satellites in use to say system has GPS (==> GPS working but not good enough), or EKF2 can reject good GPS and report no global position in situations where vibration or magnetic interference is the underlying problem.
        I'd recommend sharing more details from the sensor_gps output or a ulg file so folk can help further.
        • ben grocholskyB ben grocholsky
          @ben-grocholsky Thanks Ben! Yes, having a look at some log files would definitely help in troubleshooting.
            groupoG Offline
            groupoG Offline
            groupo
            Thank you @ben-grocholsky! I should be more clear, when I ran px4-listener sensor_gps I received something along the lines of "GPS never published". I just went to go get the verbatim output but everything seems to be working. I do indeed see the uorb now. Puzzling
