  2. VOXL SDK and Software
  3. RPM control
RPM control
voxl-sdk
23 Posts 5 Posters 7.0k Views 1 Watching
    @nbobbili , when you send rpm control packet, this also requests feedback from ESCs, so each ESC will send some data back to VOXL2 (one ESC id at a time).
    If you do not read from the same serial port that you are writing to, the data coming back from ESCs will fill the RX buffer (in slpi-cpu bridge) and you will get this message of ring buffer full.
    If you do not wish to parse the ESC feedback data, just read and discard all bytes right after you write the RPM commands.
    J Offline
    J Offline
    jenyeom
    @Alex-Kushleyev going back to getting RPM control working on ROS2 and SDK 1.1+...
    Our current findings:
    ROS2 Humble with SDK 0.8 and the old library (installed with voxl-slpi-uart-bridge_1.0.0-202303130921_arm64.deb) is working well without any issues.
    ROS2 Humble with SDK 1.1+ and the new library libvoxl_io.so and new interface (uart.h) has high frequency oscillations when flying the drone.
    We've tried many things to incldue:
    1. Updating the crc16.h/c and qc_esc_packet.h/c and other dependent code from:
      [https://github.com/modalai/px4-firmware/blob/main/src/drivers/actuators/voxl_esc]
    2. Exhaustive gain tuing 😞
    3. Delay time analysis within our control stack
    4. Experiments with different baudrates
    None of which solved the issue or clarified why we are currently having this issue on SDK 1.1+ with the new SLPI library.
    Of note, we are using the functions:
    voxl_uart_init(SLPI_QUP2_UART, 250000, 0.1, 0, 1, 0); to initialize the UART,
    int32_t packet_length = qc_esc_create_rpm_packet4_fb(rpm0, rpm1, rpm2, rpm3, led, led, led, led, cntr, tx_buf, sizeof(tx_buf), 0); to create packets,
    and int ret2 = voxl_uart_write(SLPI_QUP2_UART, tx_buf, packet_length); to actually send the rpms.
    Additionally we are using voxl_uart_flush(SLPI_QUP2_UART); because we were having issues with the ring buffer overflow.
    We are running everything in ROS2 at 500Hz.
    Do you have any thoughts on this?
    Any ideas on what we might try next?
    Thanks in advance.
    • J jenyeom
      Thanks in advance.
      @jenyeom,
      I would recommend somehow logging the timestamps right before and after sensing our the uart packet to the uart bridge. This will give you two things: you can analyze how regular the rpm updates are coming from ROS, and if for some reason the write call takes too long. Also check how long uart flush is taking!
      If you dont want any esc to send feedback, you can set the esc feedback id to -1, i believe, then you dont need to do uart flush. It should be documented in the packet api source code
      J 1 Reply Last reply
        @jenyeom,
        J Offline
        J Offline
        jenyeom
        @Alex-Kushleyev thanks for the suggestions!
        I did some testing logging timestamps today and here is what I've found.
        There was definitely some additional delay when using the voxl_uart_read_bytes function, so currently I am exclusively running the qc_esc_create_rpm_packet4_fb and voxl_uart_write functions.
        With those two functions, we are still experiencing high frequency oscillations.
        Here is what the time differences (dt) look like when sending rpms to the esc:
        The dt goes up to greater than 0.003 sec every now and then, which is why I think we have oscillation issues as we trying to send rpm commands at 500 Hz.
        Are these 'spikes' in time something you would expect?
        We are not currently running any other functions in the rpm callback, only the creation of the packets and writing to the uart.
        Thanks for your help, Alex.
        • J jenyeom
          @jenyeom , you are running your application on the CPU, so there are no real time guarantees. You should set the cpu into perf mode if you are not already doing that (voxl-set-cpu-mode perf). Additionally, if you can increase cpu priority of your ros node, do that. Finally, i would suggest updating the baud rate of the esc to 2Mbit (2000000) from 250k. This will further reduce actuator latency. Change the param in esc params first and then update your ros node to use 2mbit. Finally, it can help, if you have an oscilloscope, to look at tx line from voxl2 to see if there are 500hz on average packets going out or are there frequent gaps that would suggest dropped outgoing packets (for whatever reason).
          Jeffrey MaoJ 1 Reply Last reply
            Jeffrey MaoJ Offline
            Jeffrey Mao
            wrote on last edited by Jeffrey Mao
            #16
            By the way Alex to add on to this would it be possible for us to acquire a version of the libqrb5165-io that does NOT contain the slpi_uart_bridge portion?
            https://gitlab.com/voxl-public/voxl-sdk/core-libs/libqrb5165-io/-/tree/master?ref_type=heads
            Or we can have a version that allows us to to old voxl-slpi-uart-bridge_1.0.0-202303130921_arm64.deb on the newest SDK?
            I don't believe it is a CPU performance issue because our drone is always in performance mode and has a very high baud rate as recommended and the osccilations in flight. The only way to remove those oscillations is to downgrade the SDK 0.8 and use this library voxl-slpi-uart-bridge_1.0.0-202303130921_arm64.deb to send RPM.
            Since the hardware and our own software stack hasn't changed between these runs. I think the problem lies somewhere inside the SDK and the library. If we could simply install the older SDK Uart bridge then I believe that should show where the problem is.
            Jeff
            • Jeffrey MaoJ Jeffrey Mao
              Jeff
              #17
              @Jeffrey-Mao,
              It should be possible. You would need an older slpi firmware image that goes with the older uart bridge. I will check with @Eric-Katzfey . Since you dont use px4 on slpi, i think we may be able to downgrade the slpi image without affecting anything else.
              I am curious why you are having performance issues with the latest bridge. I will be back to office on Wednesday and can run some tests using our python and c++ api for the uart bridge.
                @Jeffrey-Mao,
                J Offline
                J Offline
                jenyeom
                Just a quick update on this journey...
                We completed a full downgrade to SDK 0.8 and still experienced oscillations - so it doesn't seem to be an SDK issue.
                The last thing that I can think could be an issue is the updated firmware of the ESC (39) that automatically happens when you update the SDK to 1.1+
                Or maybe it was an ESC issue all along..? its hard to say at this point.
                In order to track this down, I attempted to downgrade our current ESC to version 36 and had some issues with the baud rate not updating (it seemed to be stuck at a baud rate of 57600). And while updating and checking firmware/parameters, I lost all communication with the ESC.
                Here is my post on the ESC page about it:
                (https://forum.modalai.com/topic/3310/escs-not-found-esc-bricked)
                • J jenyeom
                  #19
                  @jenyeom , there have not been any performance-related changes in the ESC firmware since version 36. The only main change was a change in param structure, if you wanted to use that firmware, you would have to use voxl-esc tools and params from this branch : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/tree/params-v1/voxl-esc-tools.
                  What could have happened, if you were running older firmware / params before, after the SDK install, the firmware was updated and params as well, and it is possible that ESC params that were installed are not what you needed - that would definitely mess things up.
                  At this point, i would suggest finding the old ESC params that you were using (i am assuming that you have a custom motor / propeller and you performed the ESC calibration). I can help you updating these params to be compatible with latest firmware (easy).
                  To recover the ESC to latest firmware, use:
                  • latest voxl-esc tools from dev branch : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/tree/dev/voxl-esc-tools
                  • perform voxl-esc-scan.py, it should find all 4 ESCs, potentially running at different uart baud rates
                  • upgrade firmware to latest using ./voxl-esc-upload-firmware-all.sh , which is a wrapper for voxl-esc-upload-firmware.py . please keep track of which ESCs were updated
                  • upload latest compatible params (you can use generic params for now) : for example from here https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/blob/master/voxl-esc-params/boards/esc_params_generic_m0134.xml . Later you can update params with your actual tuning results.
                  • ./voxl-esc-scan.py to scan the escs
                  • './voxl-esc-verify-params.py` to verify params
                    J Offline
                    J Offline
                    jenyeom
                    Thanks for the quick response.
                    I was able to upload firmware version 36, but had issues getting the ESC set to the right baud rate, using voxl-esc-upload-params.py. Even though I was giving it 250,000 as the baud rate, it seemed to be stuck at 57600, which may have been a hint that the params were not loading well (after further reading in the forums and modalai documentation).
                    However, now I cannot even communicate with the ESC.
                    Here is what I get when I try the voxl-esc-scan.py script:
                    Could I have bricked the ESC...?
                    Any idea how I might go about reviving it?
                    Nothing (uplading firmware or parameter or scanning) seems to work at this point.
                    Thanks much!
                    • J jenyeom
                      Thanks much!
                      #21
                      @jenyeom ,
                      As i just mentioned above, i will repeat again 🙂
                      use latest voxl-esc tools from dev branch : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/tree/dev/voxl-esc-tools
                      You should recover the ESC to the latest state and then if you want to go back to older firmware and params, i can tell you how to do it properly.
                        @jenyeom ,
                        Once you recover to the newest firmware, before going to the old firmware, i would suggest that we figure out if you used wrong ESC params in the recent tests. So if you had old params, did you upload them after the ESC firmware was updated to version 39?
                          #23
                          Also, if you are using very old SDK on VOXL2, the uart bridge may not be working 100% properly.
                          When in doubt, the best thing to do is to connect to the ESC using a serial to usb adapter going directly to a Linux PC (and run voxl-esc tools on the PC). do you have that available?
