  2. Software Development
  3. voxl-cam-ros
voxl-cam-ros
Scheduled Pinned Locked Moved Software Development
12 Posts 5 Posters 2.8k Views 3 Watching
  • V Offline
    V Offline
    vaughanje
    I'm currently working on a VOXL Flight-based system. The forward facing camera is connected to the J2 port on the VOXL. I am able to get a stream from it in QgroundControl, but cannot seem to get the voxl_cam_ros package to run. It never connects to the camera, so the node fails after a timeout. I've tried a variety of options when running roslaunch, but with no success.
    Is there anything obvious that I might be missing? Common mistakes that I should check that I'm not making?
    The output of voxl-version is:
    system-image:    ModalAI 2.2.0 BUILDER: ekatzfey BUILD_TIME: 2020-01-28_23:54
    kernel:          #1 SMP PREEMPT Tue Jan 28 23:55:02 UTC 2020 3.18.71-perf
    factory-bundle:  0.0.5
    sw-bundle:       0.0.5
    architecture:    aarch64
    processor:       apq8096
    os:              GNU/Linux
    voxl-utils:
    Package: voxl-utils
    Version: 0.4.6
    Architecture: aarch64
    Installed-Time: 246
    Thank you.
    • modaltbM Offline
      modaltbM Offline
      modaltb
      Using this as reference: https://docs.modalai.com/voxl-cam-ros/
      These scripts use some environment variables that have tripped me up before, for tracking:
      Link Preview Image
      launch/tracking.launch · master · voxl / Deprecated / voxl-cam-ros · GitLab
      GitLab.com
      favicon
      GitLab (gitlab.com)
      Can you run voxl-env show ?
      TRACKING_CAM_IDneeds to match that of the launch file.
      You can use voxl-configure-cameras to modify if needed.
      • V Offline
        V Offline
        vaughanje
        The content of voxl-env show is:
        ROS_MASTER_URI=http://localhost:11311/
        ROS_IP=192.168.8.1
        CAM_CONFIG_ID=2
        HIRES_CAM_ID=-1
        TRACKING_CAM_ID=0
        STEREO_CAM_ID=-1
        TOF_CAM_ID=-1
        This was after running voxl-configure-cameras to change to the tracking camera only configuration. However, given that the camera is connected to J2, should I use the hires camera? I'm basing this question on the information here:
        Link Preview Image
        VOXL Flight Quickstart
        favicon
        which reports the J2 connector as the hires camera. Should I use a hires camera configuration? I have tried both without success, but if I'm asking to make sure that I do have the correct camera configuration. That would help me narrow the issue on my side.
        James StrawsonJ 1 Reply Last reply
          When you look at the RTSP stream, is it in color? Trying to understand what setup you have. The config implies you have a single, high-resolution camera connected. Since voxl-rtsp is working, the camera is working. It looks like if you have voxl-cam-ros use camera ID 1, it should work
          • V Offline
            V Offline
            vaughanje
            Yes. I get color images from the RTSP stream.
            We do currently only have a single camera, connected to J2.
            • V vaughanje
              ROS_IP=192.168.8.1
              CAM_CONFIG_ID=2
              HIRES_CAM_ID=-1
              TRACKING_CAM_ID=0
              STEREO_CAM_ID=-1
              TOF_CAM_ID=-1
              Link Preview Image
              favicon
              James StrawsonJ Offline
              James Strawson
              @vaughanje
              voxl-configure-cameras doesn't have a hires-only option but option #4 (hires + tracking) should work for you. Any option that sets the HIRES_CAM_ID to 0 which will be it's index if it's the only camera connected. You also need to make sure the "ROS_IP" variable is set correctly in ~/my_ros_env.sh otherwise roscore will fail to start and no nodes will start. That's just a fun feature of ROS that it needs to know its own IP address before starting even when only running nodes locally.
              After running voxl-configure-cameras or updating ~/my_ros_env.sh make sure to refresh the new bash environment variables with "exec bash"
              The ROS node needs to be run in either master mode if running alone, or slave mode if the rtsp streamer was started first. The ROS node cannot be started before the RTSP stream. The command to launch the hires cam in master mode is:
              roslaunch voxl_cam_ros hires.launch
              OR
              roslaunch voxl_cam_ros hires_color.launch
              To run as slave:
              roslaunch voxl_cam_ros hires.launch is_cam_master:=false
              OR
              roslaunch voxl_cam_ros hires_color.launch is_cam_master:=false
              Regards,
              James
              • V Offline
                V Offline
                vaughanje
                Thanks for the help.
                I reverted to using the hires + tracking option. So, the current output of voxl-env show is:
                ROS_IP=192.168.8.1
                CAM_CONFIG_ID=4
                HIRES_CAM_ID=0
                TRACKING_CAM_ID=1
                STEREO_CAM_ID=-1
                TOF_CAM_ID=-1
                The RTSP stream is running, so I used the is_cam_master:=false version of the suggested roslaunch commands. There is a pause between libcam.dump.dir /data/misc/camera/dumps and ERROR: could not open camera subscriber for cam id 0.
                SUMMARY
                PARAMETERS
                 * /hires/voxl_cam_nodelet/cam_id: 0
                 * /hires/voxl_cam_nodelet/cam_name: hires
                 * /hires/voxl_cam_nodelet/format: 1
                 * /hires/voxl_cam_nodelet/frame_id: hires_frame
                 * /hires/voxl_cam_nodelet/frame_rate: 15
                 * /hires/voxl_cam_nodelet/height: 1080
                 * /hires/voxl_cam_nodelet/is_cam_master: False
                 * /hires/voxl_cam_nodelet/skip_n_frames: 0
                 * /hires/voxl_cam_nodelet/width: 1920
                 * /hires/voxl_cam_nodelet/yuv_remap: yuv422
                 * /rosdistro: indigo
                 * /rosversion: 1.11.21
                NODES
                  /hires/
                    hires_nodelet_manager (nodelet/nodelet)
                    voxl_cam_nodelet (nodelet/nodelet)
                auto-starting new master
                process[master]: started with pid [4890]
                setting /run_id to da98c2d4-1dd3-11b2-913f-ec5c68cd238b
                process[rosout-1]: started with pid [4903]
                started core service [/rosout]
                process[hires/hires_nodelet_manager-2]: started with pid [4916]
                process[hires/voxl_cam_nodelet-3]: started with pid [4921]
                [ INFO] [764.624133042]: Initializing nodelet with 4 worker threads.
                [ INFO] [764.819000074]: SnapCamDriver Starting
                [ INFO] [764.819231792]: Monotonic offset: 1.670465990
                libcam.enable.publish  1
                libcam.enable.publish.dump 0
                libcam.publish.buffer.policy max
                libcam.publish.buffer.max 3
                libcam.debug.level info
                [ERROR] [781.824676109]: CameraManager::Initialize() failed
                [ERROR] [781.825179598]: Unable to open camera.
                Any ideas?
                  Can you try the camera-test app? See if you can find a camera ID that enumerates as high-res. Maybe it's not actually located at ID 0 (the ID can change based on which cameras are connected)
                  • V Offline
                    V Offline
                    vaughanje
                    wrote on last edited by vaughanje
                    #9
                    Running camera-test gives:
                    num_cameras = 1
                    Testing camera id=0
                    Segmentation fault
                      It seems voxl-rtsp cannot run concurrently with voxl-cam-ros. We are working on a new camera-server to fan out the cameras more consistently, but that is probably a month away.
                      voxl-cam-ros uses libCamera which does support multiple clients of the same camera. It would be possible to write an rtsp server using the built in live555 and libCamera that would work concurrently with voxl-cam-ros.
                      Otherwise it seems in the meantime you will need to disable voxl-rtsp to get voxl-cam-ros to work
                      • V Offline
                        V Offline
                        vaughanje
                        Sorry for the slight delay. I was finally able to get back to this this morning. Killing voxl-rtsp fixed this issue. voxl-cam-ros will launch without issue. Thank you for the help.
                        P 1 Reply Last reply
                        • V vaughanje
                          P Offline
                          P Offline
                          ptaylor1234
                          @vaughanje I am with you up until this point, but I can't figure out how to kill voxl-rtsp. what command did you use for that?
