Viswanadh CheguV
Viswanadh Chegu
@Viswanadh Chegu
  • Dual tracking camera configuration in SDK 1.0
    Viswanadh CheguV Viswanadh Chegu
    Hi @Moderator, @modaltb
    Any update on the configuration of tracking camera in HW Sensor ID- 3. Camera Server crashes whenever i connect tracking camera in HW sensor ID-3 (J7U) but in the camera server configuration, SDK 1.0 (C-06, C-14 , C-16, C-17 ) configurations shows that the tracking camera is connected to J7U.
    Can you please give me update on this?
  • voxl 2 Failed to appy GPU delegate
    @James-Strawson Thanks for reply, Will look into it and get back.
    Hi @modaltb, @Chad-Sweet
    We are facing issue with our own tflite model deployed on voxl2 for text detection bounding boxes.
    Here we are seeing "Failed to apply GPU deligate".
    From our understanding it seems that model will run on CPU in this case. So we are seeing high inference latency of 7-8 seconds, which we want to minimize by running it on GPU.
    Can you please help use with this issue.
    PS: Our tflite model size is 41MB.
    Attaching snapshot from voxl2 run for reference.
    Thanks
  • GPIO numbering
    Found the offset
    its gpiochip1100
    so for gpio 12
    echo 1112 > /sys/class/gpio/export
    will enable gpio 12
  • GPIO numbering
    I would like to access the gpio pin 12 using interposer M0076 TP5 at J8
    echo 12 > /sys/class/gpio/export
    Not works shows Invalid argument
    but
    echo 1073 > /sys/class/gpio/export
    works
    But in voxl2 the numbering is different starts at 1072 and ends at 1280
    gpiochip1100 has 180 in ngpio
    how to get exact number for gpio pin 12 in relation to above.
    can someone tell the mapping of gpio numbers.
  • hires camera snapshot in python
    @Chad-Sweet Thanks for reply,
    I am just triggering via python subprocess
    voxl-send-command hires_snapshot snapshot
    able to get snapshots.
    will try to look into mavsdk also.
    Can anyone help me how to take snapshots using hires_snapshot feature in python script in voxl2. I am able to see /hires_snapshot topic in ros but unable to process through it.
  • Broken Package? Unable to configure cameras and hires video record.
    @Jyotish-Kumar i have faced the same issue. the record pipe name has changed in dev branch, try to use
    hires_large_encoded or hires_small_encoded based on your resolution requirement. Can find more config parameters in /etc/modalai/voxl-camera-server.conf
