Thomas EiszlerT
Thomas Eiszler
@Thomas Eiszler
  • Monitor Sierra Wireless 5G signal?
    Thomas EiszlerT Thomas Eiszler
    @groupo Our goal is to use the Starling MAX with 5G to build a coverage map of our CBRS network. So I am planning to write a small bash script to periodically do AT!NRINFO? and AT!GPSLOC? alongside a timestamp. Then in post processing we can use the data to construct a heat map to see the extent. Once I get things working the way I want, I can share the script here if it would be useful to you.
  • Starling MAX
    @tom There is also another anomaly: voxl-inspect-battery shows voltage and current, but charge is listed as 0%. Is there some service that needs to be restarted/configured, like voxl-px4, in order to get a reading of the battery charge?
    I also ran px4-listener battery_status which also doesn't seem right. The cells that came with the Starling MAX I believe are 7.2V (two 2s in series, so 4 cells total).
    voxl2:/$ px4-listener battery_status
    TOPIC: battery_status
     battery_status
        timestamp: 1051478873 (0.067609 seconds ago)
        voltage_v: 5.76600
        voltage_filtered_v: 5.76056
        current_a: 1.00800
        current_filtered_a: 0.96054
        current_average_a: 3.40000
        discharged_mah: 299.21326
        remaining: 0.00000
        scale: 1.30000
        time_remaining_s: 0.00000
        temperature: nan
        voltage_cell_v: [0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000]
        max_cell_voltage_delta: 0.00000
        custom_faults: 0
        average_power: 0.00000
        available_energy: 0.00000
        full_charge_capacity_wh: 0.00000
        remaining_capacity_wh: 0.00000
        design_capacity: 0.00000
        nominal_voltage: 0.00000
        capacity: 3950
        cycle_count: 0
        average_time_to_empty: 0
        serial_number: 0
        manufacture_date: 0
        state_of_health: 0
        max_error: 0
        interface_error: 0
        faults: 0
        average_time_to_full: 0
        over_discharge_count: 0
        connected: True
        cell_count: 4
        source: 0
        priority: 0
        is_powering_off: False
        is_required: False
        warning: 3
        mode: 0
    Do I need to change the POWER_MANAGER in /etc/modalai/voxl-px4.conf from VOXLPM to NONE and restar the voxl-px4 service? The comments seem to indicate that we should be using NONE with the Mini-ESC 4 in1:
    # POWER_MANAGER:
    #     Tell PX4 which power manager to use.
    #     Use NONE for ModalAI Mini-ESC since the ESC driver handles PM.
    #     Use EXTERNAL when not using the ModalAI APM power manager to power the board
    #       This also just disables the voxlpm driver, same as the NONE option
    #     Options include: [VOXLPM, EXTERNAL, NONE]
    Development Drones
    @groupo To get a shell, you just do
    busybox microcom /dev/ttyUSB0
    Without the echo, it will just wait for your input and output the result after you type each command and hit enter. CTRL-X will return you to the voxl2 shell. i.e.:
    voxl2:/$ busybox microcom /dev/ttyUSB0
    AT!NRINFO?
    !NRINFO:
    Connectivity Mode: SA
    NR5G Cell ID:    8001 (32769)
    NR5G band:       n48       	        NR5G Carrier ID: 0
    NR5G dl bw:      40 MHz    	        NR5G ul bw:      40 MHz
    NR5G Tx Power:   ---        	        NR5G Tx chan:    0
    NR5G Rx chan:    638856
    NR5G dl MIMO:    4         	        NR5G ul MIMO:    1
    NR5G(sub6) Rx0 RSSI (dBm):   -39.9	NR5G(sub6) Rx1 RSSI (dBm):   -44.8
    NR5G(sub6) Rx2 RSSI (dBm):   ---  	NR5G(sub6) Rx3 RSSI (dBm):   ---
    NR5G RSRP (dBm): -68		                NR5G RSRQ (dB):  -11
    NR5G SINR (dB):  21.0
    OK
    I think the reason I wasn't getting output via echo, was because I forgot to send it the carriage return-line feed so it was still effectively 'waiting for me to press ENTER'.
    voxl2:/$ echo -ne 'AT!NRINFO?\r\n' | busybox microcom -t 1000 /dev/ttyUSB0
    AT!NRINFO?
    !NRINFO:
    NR5G(sub6) Rx0 RSSI (dBm):   -41.0	NR5G(sub6) Rx1 RSSI (dBm):   -53.4
    NR5G RSRP (dBm): -67		                NR5G RSRQ (dB):  -11
    OK
  • Starling MAX
    Thanks @tom! That seems to have worked. After configuration, I ran voxl-esc spin and all 4 rotors spun up in turn. Just another quick question about the output.
    Finished!
    [4.992197] TX=504, RX=1000 packets, RX CRC ERRORS=0
    Average RPMs: 0.00 0.00 0.00 1998.98
    Average RPM deviation between ESCs : 1998.98
    disabling bridge
    Is this just a quirk in the way the average RPMs are reported or should I be concerned that 3 of the 4 have a 0 average? They definitely all spun up, and seemed to reach the same speed.
    Development Drones
  • Starling MAX
    We had to replace the power/ESC module on our Starling MAX and now we cannot arm the drone. voxl-esc scan seems to detect the ESC, but perhaps we are missing some configuration. There are a number of setup_ commands for voxl-esc, but it is not clear which applies to the Starling Max. How can we set up the new ESC?
    Thanks,
    Tom
    Development Drones
    @Thomas-Eiszler Rather than echoing commands, I just went into the microcom shell and interactively ran some commands. AT+COPS? took a long time, and then afterwards, other commands also seemed to work, so I think it was perhaps the -t flag that was causing it to exit prematurely. Or something with redirection of stdout/stderr...
    @groupo Thanks for the tutorial! It didn't work the first time I echoed to new_id, but after I restarted the VOXL, the second time the kernel picked it up and created the ttyUSB0 device. Now I just need to figure out what command to use to get the signal strength. So far, most of the commands I have tried either yield no output or 'ERROR'. Progress by degrees...
    voxl2:/$ echo -ne "AT+QENG=\"servingcell\"\r" | busybox microcom -t 1000 /dev/ttyUSB0
    AT+QENG="servingcell"
    ERROR
    voxl2:/$ echo -ne 'AT!LTEINFO?' | busybox microcom -t 1000 /dev/ttyUSB0
    AT!LTEINFO?voxl2:/$ echo -ne 'AT+COPS=?' | busybox microcom -t 1000 /dev/ttyUSB0
    AT+COPS=?voxl2:/$
    voxl2:/$ echo -ne 'AT!NRINFO?' | busybox microcom -t 1000 /dev/ttyUSB0
    AT!NRINFO?voxl2:/$
    @pthomason I, too, am trying to find a way to get the signal strength periodically to build a coverage map of our 5G CBRS deployment. It seems like qmicli can be used for this purpose, but it doesn't give me anything interesting when I query for the signal information:
    voxl2:/$ qmicli -d /dev/cdc-wdm0 --device-open-proxy --nas-get-signal-info
    [/dev/cdc-wdm0] Successfully got signal info
    Has anyone successfully retrieved the signal information from voxl?
    Update:
    I also tried the following from another post, but the 5G Sierra Wireless modem is not on ttyUSB2, so I am not sure how to address it.
    echo -ne "AT+QENG=\"servingcell\"\r" | busybox microcom -t 1000 /dev/ttyUSB2
    lsusb shows it is on bus 002, device 003.
    voxl2:/dev/bus/usb/002$ lsusb
    Bus 002 Device 003: ID 1199:90e3 Sierra Wireless, Inc.
