P
Piyush Singh
@Piyush Singh
  • VOXL2 Mini – Royale createDevice failed when starting ToF camera
    P Piyush Singh
    @Alex-Kushleyev I am using second one i.e. TOF V2 and defined it in custom_camera_config.txt file as given below:
    P Piyush Singh
    Hi ModalAI team,
    I am working with a VOXL2 Mini test fixture (TF-M0104) and encountering an issue when starting the ToF camera.
    The voxl-camera-server starts successfully and all cameras initialize, but it crashes when the ToF bridge attempts to initialize the Royale device.
    Additional details:
    • Platform: VOXL2 Mini (TF-M0104)
    • Camera server starts all 4 cameras
    • The crash occurs right after the ToF bridge initialization.
    Could you please advise what might cause Royale createDevice to fail in this situation?
    I have attached a screenshot of the full terminal output for reference.
    Thanks in advance for your help.
  • hires camera not detected
    P Piyush Singh
    @Piyush-Singh Also take a look at CPU usage of voxl-portal and voxl-camera-server
    P Piyush Singh
    @Alex-Kushleyev ,Thanks for the response.
    For testing, I am running multiple camera streams simultaneously and go to web portal to see the streaming:
    HiRes (IMX214): 30 FPS
    Small video: 1024×768 (H.265)
    Large video: 4208×3120 (H.265)
    Snapshots enabled
    PMD ToF (M0169): 10 FPS, decimator 5, exposure_max_us: 6000
    Tracking front (OV7251): 30 FPS, preview + raw preview enabled, preview_width and preview_height 640 and 480 respectively.
    With this configuration, CPU/GPU temperatures rise quickly and go beyond 80 °C. After running for some time, the ToF camera stops working, and the HiRes feed becomes unstable with significant latency and frame delays, as shown in the attached screenshots.
    P Piyush Singh
    @Alex-Kushleyev Thanks for the reply.
    I tested the HiRes camera with the 2.0.0 kernel variant as suggested. With this version, the HiRes camera is detected correctly, so that part seems to work as expected. However, I’m observing that the system temperature rises very quickly and crosses 80 °C+ during operation.
    P Piyush Singh
    Hii, Please take a look:
    P Piyush Singh
    Hii Modalai Team,
    Please help me , hires camera is not detected by camera server. I have connected hires to J6 L (using M0084) and Tracking to J7 L(M0135) .Camera server detects only tracking camera but not hires.
    83e2e742-a126-41a2-a48f-959a1115cf65-WhatsApp Image 2026-01-10 at 5.13.53 PM.jpeg /home/idr/Downloads/WhatsApp Image 2026-01-10 at 5.13.53 PM.jpeg
    6e34f6ea-795a-4ad6-8834-39f6adbd4de3-Screenshot from 2026-01-10 17-21-10.png /home/idr/Pictures/Screenshots/Screenshot from 2026-01-10 17-21-10.png
    4f1d25e5-4f1c-4ae5-8376-23159d98f429-Screenshot from 2026-01-10 17-21-32.png /home/idr/Pictures/Screenshots/Screenshot from 2026-01-10 17-21-32.png
    31efd0f7-7fbf-413d-8e84-2d9c7eacfd27-Screenshot from 2026-01-10 17-21-48.png /home/idr/Pictures/Screenshots/Screenshot from 2026-01-10 17-21-48.png
  • Only 2 out of 4 cameras are detected
    P Piyush Singh
    Hello ModalAI Team,
    I am working on an indoor drone using VOXL2 Mini, and I would appreciate your guidance regarding a camera detection issue with a multi-sensor setup.
    Goal
    My goal is to build an indoor drone, primarily relying on visual sensing rather than GPS.
    Camera Modules Used
    • M0169 – PMD ToF
    • M0014 – Tracking Camera
    • M0024 – High-Resolution Camera
    Hardware Connections
    • J6 → M0084
      • JU: PMD-ToF (external 5V power supplied to M0169)
      • JL: High-Resolution Camera
    • J7 → M0135
      • JU: Tracking Camera
      • JL: Tracking Camera
    Observed Issue
    When using a custom camera configuration file, "voxl-camera-server" detects only 2 out of 4 cameras:
    • Detected: High-Resolution + Tracking (Down)
    • Not detected: PMD-ToF + Tracking (Second unit)
    Debug Information
    While debugging, I consistently get the following error:
    ToF resolution not supported (224 × 1557)
    And Tracking front is not detected.
    To address this, I manually modified "/etc/modalai/voxl-camera-server.conf":
    • "preview_width": 240
    • "preview_height": 180
    After restarting "voxl-camera-server", the error still persists(Resolution error), and only 2 cameras are detected.
    My Questions
    1. From an indoor drone perspective, is my approach of using 4 camera sensors (ToF + dual tracking + high-resolution) correct, or would you recommend a different sensor combination?
    2. Why are only 2 cameras detected despite all 4 being connected correctly?
    3. Why does the ToF camera still report an unsupported resolution (224 × 1557) even after manually setting the preview resolution?
    4. Is there any additional configuration required for PMD-ToF when used alongside multiple cameras on VOXL2 Mini?
    Any guidance, recommended configuration, or known limitations would be very helpful.
  • VOXL2 Mini Not Detected via ADB/Fastboot – QDL Mode Behavior and Flashing Issues
    P Piyush Singh
    @ZuraNeb Please provide the correct link.
    P Piyush Singh
    Hello Modal AI Team,
    I am facing an issue with my VOXL2 Mini and would appreciate your assistance. Below are my detailed observations and the steps I’ve taken so far:
    Observation 1: ADB and Fastboot Detection Failure
    • Initially, when the VOXL2 Mini is powered with SW2 in the OFF position, the device does not appear when running adb devices or adb shell.
    • It is also not detected in lsusb.
    • When I turn ON the SW2 switch, the device shows up in QDL mode in the lsusb output.
    • At this point, I attempted to reflash the image using the Flash Flat Build method, but the process failed (see attached screenshots).
    • I also tried using the install.sh script to flash the image, but it couldn’t detect the VOXL2 Mini—neither through adb nor fastboot.
    Observation 2: Delayed QDL Mode Detection
    When SW2 is OFF and the board is powered:
    • Only the D1 LED turns on initially.
    • Nothing is detected in lsusb.
    • However, after 7–8 minutes, the DS2 LED turns on, and now the device appears in QDL mode in lsusb—even though SW2 remains OFF.
      Additional Info:
      Screenshots of the QDL detection and flash errors are attached for your reference.
    I would like help understanding:
    1. Why ADB/Fastboot modes are not accessible.
    2. Why the board defaults or switches to QDL mode after some delay even when SW2 is OFF.
    3. How to properly recover or reflash the VOXL2 Mini in this state.
