Paul CarffP
Paul Carff
@Paul Carff
  • Increasing the number of radio channels
    Paul CarffP Paul Carff
    Hi All,
    I am using a Spectrum ix14 transmitter, QGC and SDK 1.3.5 on the Sentinel. I can see channels 1-7 during calibration. How do I add channels?
    Development Drones sentinel
  • 5G modem
    @M-al-khatib
    I followed the directions :https://docs.modalai.com/sentinel-user-guide-connect-gcs/#vpn-setup
    There is a link in the middle
    "In order to install the Tailscale client on VOXL 2, follow these instructions: Installing Tailscale on Ubuntu 18.04."
    That worked settng up TailScale for me very easily.
  • WiFi connectivity
    I have a Sentinel with the 5G modem installed.
    I have not put in a sim card yet and have been operating using the alpha WiFi antenna. I had my maiden flight today including doing a waypoint mission wiht QGC.
    I had a lot of disconnect / reconnect announces. I was not flying far - 50m max and no more than 10m high.
    I have a travel router taped to the top of my monitor as the connection point.
    What can I look at to see if the signal is fluxuating and really that weak?
    Do I need to shift to 5G? (maybe the SANAV anntennas will make a difference?)
    I am also starting to learn how to use logs. If there is a good tutorial I can look at I will certainly spend time there.
  • Calibrating Cameras
    @Paul-Carff OK I guess 4th time is a charm. I completed successfully on the 4th try.
    I seem to have successfully calibrated the tracking camera and the front stereo cameras.
    However the rear stereo cameras are not so easy:
    This is on a sentinel wiht SDK 1.0.0
    voxl2:~$ voxl-calibrate-camera stereo_rear -s 6x9 -l 0.036
    Please open voxl-portal in a web browser to view the camera calibrator overlay stream
    Calibrating Left Camera
    Matrix
    [501.6341078021471, 0, 312.0570434152602;
    0, 501.6987891542731, 222.2877324066488;
    0, 0, 1]
    Distortion
    [-0.1502441527526627;
    0.03136514258800416;
    5.047978211251211e-06;
    0.0007012198359013242;
    0]
    distortion_model: plumb_bob
    Re-projection error reported by calibrateCamera: 0.339971
    Calibration Succeded!
    Calibrating Right Camera
    Matrix
    [499.4811952338386, 0, 314.4191622715103;
    0, 499.6489291511509, 227.6223607658805;
    0, 0, 1]
    Distortion
    [-0.1549310463664996;
    0.03293348747609434;
    -0.0007877854337037341;
    0.0003367908453812461;
    0]
    Re-projection error reported by calibrateCamera: 0.322899
    Calibrating Extrinsics
    4 frames will be processed
    R
    [0.9986976114002246, -0.05097017966660664, -0.002263132395515557;
    0.05095755996436296, 0.9986866400336852, -0.005321851248074788;
    0.002531415802302149, 0.005199596424927816, 0.999983277925713]
    T
    [-0.08038782105206063;
    -0.005256904223362341;
    0.003021027838004832]
    Re-projection error reported by stereoCalibrate: 0.524123
    Detected horizontal stereo pair
    Distance between cameras: 0.0804
    Extrinsics Calibration Failed
    exceeded allowable max reprojection error: 0.5
    Saved intrinsics to: /data/modalai/opencv_stereo_rear_intrinsics.yml
    Exiting Cleanly
    voxl2:~$
  • How to load parameters
    @Eric-Katzfey Thank you
    @Paul-Carff I have upgraded to voxl2_sdk1.0.0 onto my Sentinel.
    I believe this SDK uses px4 version is 1.14 Should I be using the v1.14 params now?
  • Detected 0 radio channels. To operate PX4 you need at least 5 channels
    @Paul-Carff
    Well that is embarassing. -s not -t
    Thanks all for the help - can close this one out as operator error.
    @Paul-Carff OMG - I just read my notes when I first configured and I wrote down that I used voxl-bind -s
    Can't wait to test when I get home tonight.
    @RichieRich
    Connected a new radio and have the same issue.
    This is curious as I can put it into bind mode via adb shell or ssh and voxl-bind -t or voxl-bind-spektrum -t depending on the SDK version.
    So it does communicate.
    Confirm I am using the 22 ms setting and now that I just re-read your note and looking at the githhub:
    Command Line Options
    -d, --debug enable debug messages
    -h, --help print this help messsage
    -t, --DSM2_22 3 pulses (DSM2 1024/22ms)
    -f, --DSM2_11 5 pulses (DSM2 2048/11ms)
    -s, --DSMX_22 7 pulses (DSMX 22ms)
    I will give the -s command a test tonight.
    I am doing this on my own time in the evenings - sorry I am so slow to respond.
    @Eric-Katzfey Thanks Eric - I will check the receiver and I have ordered a replacement to swap out as well. Will let you know what I find.
    @Eric-Katzfey
    Reflashed to 0.9.5 and have the same problem (expected this as that was my original issue.)
    The cable looks good from the receiver to the what looks like a board that is coated in silicon (I didn't want to start disassembling the drone yet.)
    I am wondering if it is the receiver that has failed?
    @Paul-Carff I was wondering:
    • should try to reinstall 0.9.5?
    • it is the reciever?
    Will await your next suggestion.
    @Paul-Carff
    I ran the SDK install again and am still getting this at the end of output of the journalctl -b -u voxl-px4
    voxl2:/$ px4-listener input_rc
    never published
    voxl2:/$ journalctl -b -u voxl-px4
    Jul 31 22:20:03 m0054 voxl-px4[1868]: WARN [uORB] orb_advertise_multi: failed to set queue size
    Jul 31 22:20:03 m0054 voxl-px4[1868]: ERROR [muorb] SLPI: Spektrum RC: Read something other than correct DSM frame on read
    Jul 31 22:20:04 m0054 voxl-px4[1868]: ERROR [muorb] SLPI: Spektrum RC: Read something other than correct DSM frame on read
    Jul 31 22:20:05 m0054 voxl-px4[1868]: ERROR [muorb] SLPI: Spektrum RC: Read something other than correct DSM frame on read
    Jul 31 22:20:06 m0054 voxl-px4[1868]: ERROR [muorb] SLPI: Spektrum RC: Read something other than correct DSM frame on read
    @Paul-Carff
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic autotune_attitude_control_status
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Ok executing command: mc_autotune_attitude_control start
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: qshell gotten: land_detector start multicopter
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg0 = 'land_detector'
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg1 = 'start'
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg2 = 'multicopter'
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Ok executing command: land_detector start multicopter
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic vehicle_land_detected
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_toINFO [qshell] Send cmd: 'manual_control start'
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [qshell] qshell return value timestamp: 16149538, local time: 16151789
    Jul 30 20:13:14 m0054 voxl-px4[1907]: INFO [qshell] Send cmd: 'control_allocator start'
    Jul 30 20:13:14 m0054 voxl-px4[1907]: INFO [qshell] qshell return value timestamp: 16436082, local time: 16437240
    Jul 30 20:13:14 m0054 voxl-px4[1907]: INFO [qshell] Send cmd: 'rc_update start'
    Jul 30 20:13:14 m0054 voxl-px4[1907]: INFO [qshell] qshell return value timestamp: 16756354, local time: 16757722
    Jul 30 20:13:14 m0054 voxl-px4[1907]: INFO [qshell] Send cmd: 'commander start'
    Jul 30 20:13:14 m0054 voxl-px4[1907]: INFO [qshell] qshell return value timestamp: 17013967, local time: 17016102
    Jul 30 20:13:14 m0054 voxl-px4[1907]: INFO [qshell] Send cmd: 'commander mode manual'
    Jul 30 20:13:14 m0054 voxl-px4[1907]: INFO [qshell] qshell return value timestamp: 17066595, local time: 17067798
    Jul 30 20:13:14 m0054 voxl-px4[1907]: INFO [qshell] Send cmd: 'param_set_selector start'
    Jul 30 20:13:14 m0054 voxl-px4[1907]: INFO [qshell] qshell return value timestamp: 17105139, local time: 17106319
    Jul 30 20:13:14 m0054 voxl-px4[1907]: INFO [qshell] Send cmd: 'flight_mode_manager start'
    Jul 30 20:13:14 m0054 voxl-px4[1907]: INFO [qshell] qshell return value timestamp: 17267022, local time: 17269946
    Jul 30 20:13:15 m0054 voxl-px4[1907]: pic
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [muorb] SLPI: qshell gotten: manual_control start
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg0 = 'manual_control'
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg1 = 'start'
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Ok executing command: manual_control start
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic manual_control_setpoint
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [muorb] SLPI: qshell gotten: control_allocator start
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg0 = 'control_allocator'
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic control_allocator_status
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [uORB] Marking DeviceNode(control_allocator_status) as advertised in process_remote_topic
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic actuator_motors
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic actuator_servos
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic actuator_servos_trim
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Ok executing command: control_allocator start
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [muorb] SLPI: qshell gotten: rc_update start
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg0 = 'rc_update'
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [muorb] SLPI: RC_MAP_MODE_SW deprecated
    Jul 30 20:13:15 m0054 voxl-px4[1907]: ERROR [muorb] SLPI: Cannot reset parameters on client side
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Ok executing command: rc_update start
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [muorb] SLPI: qshell gotten: commander start
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg0 = 'commander'
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Creating pthread commander
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Successfully created px4 task PX4_commander with tid 2097641
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic led_control
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [muorb] SLPI: LED: open /dev/led0 failed (22)
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic tune_control
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Ok executing command: commander start
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic event
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic health_report
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic failsafe_flags
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic actuator_armed
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic vehicle_control_mode
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic vehicle_status
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic failure_detector_status
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic vehicle_thrust_setpoint
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic vehicle_torque_setpoint
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic vehicle_rates_setpoint
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic vehicle_local_position_setpoint
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic vehicle_attitude_setpoint
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [muorb] SLPI: qshell gotten: commander mode manual
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg1 = 'mode'
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg2 = 'manual'
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic vehicle_command
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Ok executing command: commander mode manual
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic vehicle_command_ack
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [uORB] Marking DeviceNode(vehicle_attitude_setpoint) as advertised in process_remote_topic
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [muorb] SLPI: qshell gotten: param_set_selector start
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg0 = 'param_set_selector'
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Ok executing command: param_set_selector start
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [muorb] SLPI: qshell gotten: flight_mode_manager start
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg0 = 'flight_mode_manager'
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [uORB] Marking DeviceNode(vehicle_command) as advertised in process_remote_topic
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Ok executing command: flight_mode_manager start
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic actuator_controls_status_0
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [dataman] data manager file '/data/px4/dataman' size is 7866640 bytes
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Advertising remote topic transponder_report
    Jul 30 20:13:15 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Advertising remote topic rtl_time_estimate
    Jul 30 20:13:17 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Advertising remote topic position_sINFO [mavlink] MAVLink only on localhost (set param MAV_{i}_BROADCAST = 1 to e
    Jul 31 21:35:31 m0054 voxl-px4[1907]: etpoint_triplet
    Jul 31 21:35:31 m0054 voxl-px4[1907]: INFO [mavlink] mode: Onboard, data rate: 100000 B/s on udp port 14556 remote port 14557
    Jul 31 21:35:31 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Advertising remote topic telemetry_status
    Jul 31 21:35:31 m0054 voxl-px4[1907]: INFO [mavlink] partner IP: 127.0.0.1
    Jul 31 21:35:31 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Advertising remote topic vehicle_visual_odometry
    Jul 31 21:35:31 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Advertising remote topic obstacle_distance
    Jul 31 21:35:31 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Advertising remote topic offboard_control_mode
    Jul 31 21:35:31 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Advertising remote topic timesync_status
    Jul 31 21:35:31 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic estimator_aid_src_ev_hgt
    Jul 31 21:35:31 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic estimator_aid_src_ev_pos
    Jul 31 21:35:31 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic estimator_aid_src_ev_vel
    Jul 31 21:35:31 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic estimator_aid_src_ev_yaw
    Jul 31 21:35:31 m0054 voxl-px4[1907]: INFO [mavlink] mode: Normal, data rate: 100000 B/s on udp port 14558 remote port 14559
    Jul 31 21:35:31 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Marking DeviceNode(telemetry_status) as advertised in process_remote_topic
    Jul 31 21:35:31 m0054 voxl-px4[1907]: INFO [px4] Startup script returned successfully
    Jul 31 21:35:31 m0054 voxl-px4[1907]: INFO [muorb] SLPI: u-blox firmware version: SPG 3.01
    Jul 31 21:35:31 m0054 voxl-px4[1907]: INFO [muorb] SLPI: u-blox protocol version: 18.00
    Jul 31 21:35:31 m0054 voxl-px4[1907]: INFO [muorb] SLPI: u-blox module: NEO-M8N-0
    Jul 31 21:35:31 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic sensor_gps
    Jul 31 21:35:31 m0054 voxl-px4[1907]: WARN [uORB] orb_advertise_multi: failed to set queue size
    Jul 31 21:35:31 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Advertising remote topic ping
    Jul 31 21:35:31 m0054 voxl-px4[1907]: ERROR [muorb] SLPI: Spektrum RC: Read something other than correct DSM frame on read. Got 16 bytes. Protocol byte is 0x01
    --- Repeats that last line.
    voxl2:~$ journalctl -b -u voxl-px4
    -- Logs begin at Thu 2023-03-02 12:58:02 UTC, end at Mon 2023-07-31 21:39:52 UTC. --
    Jul 30 20:13:03 m0054 systemd[1]: Starting px4...
    Jul 30 20:13:05 m0054 systemd[1]: Started px4.
    Jul 30 20:13:05 m0054 voxl-px4[1907]: [INFO] Reading from /etc/modalai/voxl-px4.conf
    Jul 30 20:13:05 m0054 voxl-px4[1907]: Found DSP signature file
    Jul 30 20:13:05 m0054 voxl-px4[1907]: [INFO] Daemon mode enabled
    Jul 30 20:13:05 m0054 voxl-px4[1907]: *************************
    Jul 30 20:13:05 m0054 voxl-px4[1907]: GPS=HOLYBRO
    Jul 30 20:13:05 m0054 voxl-px4[1907]: RC=SPEKTRUM
    Jul 30 20:13:05 m0054 voxl-px4[1907]: OSD=DISABLE
    Jul 30 20:13:05 m0054 voxl-px4[1907]: DAEMON_MODE=ENABLE
    Jul 30 20:13:05 m0054 voxl-px4[1907]: SENSOR_CAL=ACTUAL
    Jul 30 20:13:05 m0054 voxl-px4[1907]: EXTRA STEPS:
    Jul 30 20:13:05 m0054 voxl-px4[1907]: INFO [px4] mlockall() enabled. PX4's virtual address space is locked into RAM.
    Jul 30 20:13:05 m0054 voxl-px4[1907]: INFO [px4] assuming working directory is rootfs, no symlinks needed.
    Jul 30 20:13:05 m0054 voxl-px4[1907]: INFO [muorb] Got muorb init command
    Jul 30 20:13:05 m0054 voxl-px4[1907]: Sending initialization request
    Jul 30 20:13:05 m0054 voxl-px4[1907]: Got topic data before configuration complete
    Jul 30 20:13:05 m0054 voxl-px4[1907]: GPS: HOLYBRO
    Jul 30 20:13:05 m0054 voxl-px4[1907]: RC: SPEKTRUM
    Jul 30 20:13:05 m0054 voxl-px4[1907]: OSD: DISABLE
    Jul 30 20:13:05 m0054 voxl-px4[1907]: Running on M0054
    Jul 30 20:13:06 m0054 voxl-px4[1907]: INFO [param] selected parameter default file /data/px4/param/parameters
    Jul 30 20:13:08 m0054 voxl-px4[1907]: INFO [parameters] BSON document size 2958 bytes, decoded 2958 bytes (INT32:51, FLOAT:84)
    Jul 30 20:13:09 m0054 voxl-px4[1907]: Starting IMU driver with no rotation
    Jul 30 20:13:09 m0054 voxl-px4[1907]: INFO [qshell] Send cmd: 'icm42688p start -s'
    Jul 30 20:13:09 m0054 voxl-px4[1907]: INFO [qshell] qshell return value timestamp: 11920803, local time: 11922676
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [qshell] Send cmd: 'icp101xx start -I -b 5'
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [qshell] qshell return value timestamp: 12953238, local time: 12955346
    Jul 30 20:13:10 m0054 voxl-px4[1907]: Starting Holybro magnetometer
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: muorb aggregator thread running
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] muorb protobuf initalize method succeeded
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Creating pthread test_MUORB
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097656
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] succesfully did ADVERTISE_TEST_TYPE
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] succesfully did SUBSCRIBE_TEST_TYPE
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097655
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] succesfully did TOPIC_TEST_TYPE
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097654
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] succesfully did UNSUBSCRIBE_TEST_TYPE
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097653
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] muorb test passed
    Jul 30 20:13:10 m0054 voxl-px4[1907]: ______ __ __ ___
    Jul 30 20:13:10 m0054 voxl-px4[1907]: | ___ \ \ \ / / / |
    Jul 30 20:13:10 m0054 voxl-px4[1907]: | |/ / \ V / / /| |
    Jul 30 20:13:10 m0054 voxl-px4[1907]: | __/ / \ / /
    Jul 30 20:13:10 m0054 voxl-px4[1907]: | | / /^\ \ ___ |
    Jul 30 20:13:10 m0054 voxl-px4[1907]: _| / / |_/
    Jul 30 20:13:10 m0054 voxl-px4[1907]: px4 starting.
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Advertising remote topic log_message
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [px4] startup script: /bin/sh /usr/bin/voxl-px4-start 0
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [parameters] Starting param sync THREAD
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Starting param sync THREAD
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: before starting the qshell_entry task
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Creating pthread qshell
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: qshell entry.....
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Successfully created px4 task PX4_qshell with tid 2097652
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Init app map initialized
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: after starting the qshell_entry task
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Marking DeviceNode(parameter_client_reset_request) as advertised in process_remote_topic
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [uORB] Marking DeviceNode(parameter_client_reset_response) as advertised in process_remote_topic
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Advertising remote topic parameter_update
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Marking DeviceNode(parameter_client_set_value_request) as advertised in process_remote_topic
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [uORB] Marking DeviceNode(parameter_server_set_used_request) as advertised in process_remote_topic
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Marking DeviceNode(parameter_server_set_used_response) as advertised in process_remote_topic
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [uORB] Marking DeviceNode(parameter_client_set_value_response) as advertised in process_remote_topic
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [logger] logger started (mode=all)
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: qshell gotten: icm42688p start -s
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg0 = 'icm42688p'
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg1 = 'start'
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg2 = '-s'
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: *** SPI Device ID 0x26000a 2490378
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic sensor_accel
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic sensor_gyro
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: ICM42688P::probe successful!
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: on SPI bus 1
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: icm42688p #0 on SPI bus 1
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: >>> ICM42688P this: 3176e4c0
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Ok executing command: icm42688p start -s
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic qshell_retval
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Register interrupt b21d3164 e620e69c 3176e4c0
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic sensor_gyro_fifo
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic sensor_accel_fifo
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic imu_server
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: qshell gotten: icp101xx start -I -b 5
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg0 = 'icp101xx'
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg2 = '-I'
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg3 = '-b'
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg4 = '5'
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: *** I2C Device ID 0xb76329 12018473
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: icp101xx #0 on I2C bus 5
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: address 0x63
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Ok executing command: icp101xx start -I -b 5
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [muorb] SLPI: qshell gotten: ist8310 starINFO [qshell] Send cmd: 'ist8310 start -R 10 -X -b 1'
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [qshell] qshell return value timestamp: 12985427, local time: 12996053
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [qshell] Send cmd: 'gps start'
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [qshell] qshell return value timestamp: 13022118, local time: 13022943
    Jul 30 20:13:10 m0054 voxl-px4[1907]: Starting Holybro LED driver
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [qshell] Send cmd: 'rgbled_ncp5623c start -X -b 1 -f 400 -a 56'
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [qshell] qshell return value timestamp: 13056790, local time: 13058244
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [qshell] Send cmd: 'modal_io start'
    Jul 30 20:13:10 m0054 voxl-px4[1907]: INFO [qshell] qshell return value timestamp: 13147708, local time: 13148566
    Jul 30 20:13:11 m0054 voxl-px4[1907]: Starting Spektrum RC
    Jul 30 20:13:11 m0054 voxl-px4[1907]: INFO [qshell] Send cmd: 'spektrum_rc start'
    Jul 30 20:13:11 m0054 voxl-px4[1907]: INFO [qshell] qshell return value timestamp: 14182612, local time: 14184757
    Jul 30 20:13:12 m0054 voxl-px4[1907]: INFO [qshell] Send cmd: 'voxlpm start -X -b 2'
    Jul 30 20:13:12 m0054 voxl-px4[1907]: INFO [qshell] qshell return value timestamp: 15237936, local time: 15243197
    Jul 30 20:13:13 m0054 voxl-px4[1907]: t -R 10 -X -b 1
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg0 = 'ist8310'
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg2 = '-R'
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg3 = '10'
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg4 = '-X'
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg5 = '-b'
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg6 = '1'
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: *** I2C Device ID 0x60e09 396809
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: ist8310 #0 on I2C bus 1
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: (external)
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: address 0xE
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: rotation 10
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Ok executing command: ist8310 start -R 10 -X -b 1
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: qshell gotten: gps start
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg0 = 'gps'
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Creating pthread gps
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Successfully created px4 task PX4_gps with tid 2097648
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Ok executing command: gps start
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: qshell gotten: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg0 = 'rgbled_ncp5623c'
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg2 = '-X'
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg3 = '-b'
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg4 = '1'
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg5 = '-f'
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg6 = '400'
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg7 = '-a'
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg8 = '56'
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: *** I2C Device ID 0x7b3809 8075273
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: rgbled_ncp5623c #0 on I2C bus 1
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: address 0x38
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Ok executing command: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic sensor_mag
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: qshell gotten: modal_io start
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg0 = 'modal_io'
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic actuator_outputs
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Ok executing command: modal_io start
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Opened UART ESC device
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic sensor_baro
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic actuator_outputs_debug
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic esc_status
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: qshell gotten: spektrum_rc start
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg0 = 'spektrum_rc'
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Creating pthread spektrum_rc_main
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Successfully created px4 task PX4_spektrum_rc_main with tid 2097645
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Ok executing command: spektrum_rc start
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: qshell gotten: voxlpm start -X -b 2
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg0 = 'voxlpm'
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg4 = '2'
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: *** I2C Device ID 0xd24411 13779985
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Set i2c address 0x6a, fd 3
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Set i2c address 0x44, fd 3
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic battery_status
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: voxlpm #0 on I2C bus 2
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: address 0x44
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Ok executing command: voxlpm start -X -b 2
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic power_monitor
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: qshell gotten: sensors start
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg0 = 'sensors'
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic sensor_selection
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic sensors_status_imu
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic vehicle_acceleration
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic vehicle_angular_velocity
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic sensor_combined
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic vehicle_air_data
    Jul 30 20:13:13 m0054 voxl-px4[1907]: ERROR [muorb] SLPI: Timeout waiting for parINFO [qshell] Send cmd: 'sensors start'
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [qshell] qshell return value timestamp: 15437907, local time: 15439773
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [qshell] Send cmd: 'ekf2 start'
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [qshell] qshell return value timestamp: 15721127, local time: 15722467
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [qshell] Send cmd: 'mc_pos_control start'
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [qshell] qshell return value timestamp: 15824233, local time: 15827379
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [qshell] Send cmd: 'mc_att_control start'
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [qshell] qshell return value timestamp: 15870832, local time: 15872897
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [qshell] Send cmd: 'mc_rate_control start'
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [qshell] qshell return value timestamp: 15961562, local time: 15963617
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [qshell] Send cmd: 'mc_hover_thrust_estimator start'
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [qshell] qshell return value timestamp: 16009786, local time: 16011482
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [qshell] Send cmd: 'mc_autotune_attitude_control start'
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [qshell] qshell return value timestamp: 16053076, local time: 16055646
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [qshell] Send cmd: 'land_detector start multicopter'
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [qshell] qshell return value timestamp: 16102398, local time: 16104095
    Jul 30 20:13:13 m0054 voxl-px4[1907]: ameter_server_set_used_response for SENS_GPS_MASK
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic vehicle_gps_position
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic sensors_status_baro
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic vehicle_magnetometer
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic sensor_preflight_mag
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic vehicle_imu
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic vehicle_imu_status
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Ok executing command: sensors start
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic sensors_status_mag
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: qshell gotten: ekf2 start
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg0 = 'ekf2'
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic vehicle_attitude
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic vehicle_local_position
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic estimator_event_flags
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic estimator_innovation_test_ratios
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic estimator_innovation_variances
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic estimator_innovations
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic estimator_sensor_bias
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic estimator_states
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic estimator_status_flags
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Ok executing command: ekf2 start
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic ekf2_timestamps
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic vehicle_odometry
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic estimator_aid_src_baro_hgt
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic estimator_aid_src_fake_pos
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic estimator_aid_src_fake_hgt
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic estimator_aid_src_mag_heading
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic estimator_aid_src_gravity
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: qshell gotten: mc_pos_control start
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg0 = 'mc_pos_control'
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic takeoff_status
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Ok executing command: mc_pos_control start
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: qshell gotten: mc_att_control start
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg0 = 'mc_att_control'
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Ok executing command: mc_att_control start
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: qshell gotten: mc_rate_control start
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg0 = 'mc_rate_control'
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [uORB] Advertising remote topic rate_ctrl_status
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Ok executing command: mc_rate_control start
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: qshell gotten: mc_hover_thrust_estimator start
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg0 = 'mc_hover_thrust_estimator'
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: Ok executing command: mc_hover_thrust_estimator start
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: qshell gotten: mc_autotune_attitude_control start
    Jul 30 20:13:13 m0054 voxl-px4[1907]: INFO [muorb] SLPI: arg0 = 'mc_autotune_attitude_control'
    @RichieRich said in Detected 0 radio channels. To operate PX4 you need at least 5 channels:
    voxl-inspect-sku
    yes to the configuration:
    voxl2:~$ voxl-inspect-sku
    family code: MRB-D0006 (sentinel)
    compute board: 4 (voxl2)
    hw version: 1
    cam config: 11
    SKU: MRB-D0006-4-V1-C11
    voxl2:~$ px4-listener input_rc
    never published
    Sentinel on 0.9.5
    I had done some bench testing and all was working. When I went out to fly my sentinel the spektrum radio would not connect.
    I have it back on the bench - did the rebind (flashing light, bind, power cycle turning off sentinel and then TX and then turning on TX and then sentinel)
    Reciever is show solid orange light.
    However when I go into QGC - I get the Detected 0 radio channels.
    I saw the bootcamp and that SDK v1.0.0 was released so I upgraded. I am getting the same issue.
    I have two different spektrum radios (older DX8 and new iX14) I have the same behavior with both TX.
    Any recommendations for how to proceed troubleshooting this?
    @Eric-Katzfey Thank you.
    @Paul-Carff
    Which params v do I use :
    Here is what I am currently running:
