Nse ObotN
Nse Obot
@Nse Obot
  • tensorflow lite dev setup failing on Ubuntu 22
    Nse ObotN Nse Obot
    @Alex-Kushleyev That worked! Thanks.
    Nse ObotN Nse Obot
    Dear ModalAI,
    Below are the steps I took to get tensorflow lite working on a voxl2 sterling drone. The main issue is that the build script on my dev machine is failing on Modal SDK dependencies.
    Install Ubuntu Desktop 22.04 on laptop
    https://ubuntu.com/tutorials/install-ubuntu-desktop#1-overview
    Install docker
    https://docs.docker.com/install/linux/docker-ce/ubuntu/
    Create a modal ai developer account
    https://developer.modalai.com/
    Download Voxl-cross V4.0
    https://developer.modalai.com/asset/eula-download/173
    Install voxl-docker
    https://gitlab.com/voxl-public/support/voxl-docker
    Read through the Voxl2 SDK feature page on Deep Learning
    https://docs.modalai.com/voxl-tflite-server/
    Go to the source section to find the Gitlab source code for tensor flow lite on voxl
    https://gitlab.com/voxl-public/voxl-sdk/services/voxl-tflite-server
    Follow the instructions for chipset qrb5165 (voxl-2)
    Failing on step 3. Build scripts. Console log below:
    ./build.sh qrb5165
    CMake Deprecation Warning at CMakeLists.txt:1 (cmake_minimum_required):
      Compatibility with CMake < 3.10 will be removed from a future version of
      CMake.
      Update the VERSION argument <min> value or use a ...<max> suffix to tell
      CMake that the project does not need compatibility with older versions.
    WARN you're using a deprecated toolchain, please use the new toolchains:
    WARN qrb5165_ubun1_18.04_aarch64.toolchain.cmake
    WARN qrb5165_ubun2_20.04_aarch64.toolchain.cmake
    -- Using voxl-cross 64-bit toolchain for QRB5165 ubun1 18.04
    -- C Compiler 	: /usr/bin/aarch64-linux-gnu-gcc-10
    -- C++ Compiler   : /usr/bin/aarch64-linux-gnu-g++-10
    -- Sysroot    	: /opt/sysroots/qrb5165_1
    -- C flags    	: -idirafter /usr/include -march=armv8.2-a
    -- CXX flags  	: -idirafter /usr/include -march=armv8.2-a
    -- EXE Link Flags : -L/opt/sysroots/qrb5165_1/usr/lib/aarch64-linux-gnu -L/opt/sysroots/qrb5165_1/lib -L/opt/sysroots/qrb5165_1/usr/lib -L/usr/lib64 -L/usr/lib
    -- SO Link Flags  : -L/opt/sysroots/qrb5165_1/usr/lib/aarch64-linux-gnu -L/opt/sysroots/qrb5165_1/lib -L/opt/sysroots/qrb5165_1/usr/lib -L/usr/lib64 -L/usr/lib
    CMake Deprecation Warning at src/CMakeLists.txt:1 (cmake_minimum_required):
      CMake.
    -- Configuring done (0.0s)
    -- Generating done (0.0s)
    -- Build files have been written to: /home/root/build
    [  6%] Building CXX object src/CMakeFiles/voxl-tflite-server.dir/config_file.cpp.o
    [ 13%] Building CXX object src/CMakeFiles/voxl-tflite-server.dir/inference_handler.cpp.o
    In file included from /home/root/src/config_file.cpp:1:
    /home/root/src/../include/config_file.h:37:10: fatal error: modal_json.h: No such file or directory
       37 | #include <modal_json.h>
    compilation terminated.
    make[2]: *** [src/CMakeFiles/voxl-tflite-server.dir/build.make:79: src/CMakeFiles/voxl-tflite-server.dir/config_file.cpp.o] Error 1
    make[2]: *** Waiting for unfinished jobs....
    In file included from /home/root/src/inference_handler.cpp:1:
    /home/root/src/../include/inference_handler.h:14:10: fatal error: modal_pipe.h: No such file or directory
       14 | #include <modal_pipe.h>
    make[2]: *** [src/CMakeFiles/voxl-tflite-server.dir/build.make:107: src/CMakeFiles/voxl-tflite-server.dir/inference_handler.cpp.o] Error 1
    make[1]: *** [CMakeFiles/Makefile2:106: src/CMakeFiles/voxl-tflite-server.dir/all] Error 2
    make: *** [Makefile:136: all] Error 2
    Resolution attempts
    Configuring Ubuntu Package manager
    https://docs.modalai.com/configure-pkg-manager/
    Fails on: The repository does not have release file.
    This indicates that the Voxl2 SDK does not have Ubuntu 22.04 support yet.
    Running Docker on the Sterling
    https://www.digitalocean.com/community/tutorials/how-to-install-and-use-docker-on-ubuntu-18-04
    Policy check indicates no repo is available for docker-ce
    apt-cache policy docker-ce
    docker-ce:
      Installed: (none)
      Candidate: (none)
      Version table:
    This leads to no package found
    sudo apt install docker-ce
    Reading package lists... Done
    Building dependency tree
    Package docker-ce is not available, but is referred to by another package.
    This may mean that the package is missing, has been obsoleted, or
    is only available from another source
    However the following packages replace it:
      docker-ce-cli:amd64
    E: Package 'docker-ce' has no installation candidate
    Also tried Modal AI’s docs on docker installation
    https://docs.modalai.com/voxl-docker-and-cross-installation/#installing-voxl-docker
    Fails on docker.com resolve host
    curl -fsSL https://get.docker.com -o get-docker.sh
    curl: (6) Could not resolve host: get.docker.com
