Nguyen Tien SuN
Nguyen Tien Su
@Nguyen Tien Su
  • Error when using opencv dnn module.
    Nguyen Tien SuN Nguyen Tien Su
    Thank @Chad-Sweet !
    Hi all!
    I can't use dnn module of opencv in voxl-tflite-server service.
    Please help me solve this problem! Thank you very much!
  • Does voxl-tflite-server support Yolov5 model?
    Hi @Matt-Turi !
    Thank your information!
    Hi all!
    voxl-tflite-server seems to only support Tensorflow SSD Object Detection. Does it support Yolov5 model? I can't find any document about it.
  • How to receive GPS information in voxl-tflite-server?
    Hi @Matt-Turi !
    You right. I hardcoded tflite server channel, so I forgot to change it when setting callback function. Now, my code works fine.
    Thank you very much for your enthusiastic help!
    Hi @Matt-Turi ! This is error.
    I tried to change the channel of GPS, then I can't receive any GPS message. I also tried to change channel of the TFLITE server but it couldn't start.
    Thank @Matt-Turi very much !
    I am successful to receive GPS in voxl-tflite-server. But I can't open 2 pipes GPS and TFLITE at the same time since they use same channel 0. Their channel seems to be set up by the MPA and can't change. How can I solve this problem?
    Thank you, @Matt-Turi !
    I checked the code and understood. But it's error when I include mavlink.h header file from c_library_v2 library into voxl-tflite-server. It said that mavlink.h file not found. How can I solve this problem?
    I need to have GPS information such as latitude, and longitude, ... to process in voxl-tflite-server c++ code. How can I do it?
