N. ChenN
N. Chen
@N. Chen
  • voxl2 unbrick fails
    N. ChenN N. Chen
    @N-Chen
    To anyone reading this, maybe encountering the same issue in the future.
    I've tested the board with a guy that has a lot of experience with the voxl2 board,
    According to him, the board was faulty, probably some electrical issue, the amperage did not cross 0.1, and the board usually runs on something like 0.5.
    I've replaced my board as well as my power-supply cables (which were also under par).
  • Recovering Flight Logs from a Bricked VOXL2
    N. ChenN N. Chen
    @lhermosillo
    That is harsh. Do you have a bare board, or one with some additions? If you can use the bare voxl2, try that. If you have been using the bare board all along, I'm stumped here. I'd maybe try to reinstall the modalai-qdl env, or use another image. Maybe the qdl command itself instead of the webUI. Hope you'll be able to save your board!
    N. ChenN N. Chen
    @N-Chen
    Adding the new full log, for completeness, in hope someone from the dev Team might actually look at this and try to figure it out.
    Maybe at least try to get some help from Qualcomm devs if you have no clue?
    {"message": "modal hello\n[MODALAI] test log\n\n[MODALAI] Executing usb_open\n[MODALAI] Completed usb_open\n[MODALAI] Executing sahara_run\nHELLO version: 0x2 compatible: 0x1 max_len: 1024 mode: 0\nREAD64 image: 13 offset: 0x0 length: 0x40\nREAD64 image: 13 offset: 0x40 length: 0x310\nREAD64 image: 13 offset: 0x1000 length: 0x1000\nREAD64 image: 13 offset: 0x2000 length: 0xc48\nREAD64 image: 13 offset: 0x3000 length: 0x1000\nREAD64 image: 13 offset: 0x4000 length: 0x1000\nREAD64 image: 13 offset: 0x5000 length: 0x1000\nREAD64 image: 13 offset: 0x6000 length: 0x1000\nREAD64 image: 13 offset: 0x7000 length: 0x1000\nREAD64 image: 13 offset: 0x8000 length: 0x1000\nREAD64 image: 13 offset: 0x9000 length: 0x1000\nREAD64 image: 13 offset: 0xa000 length: 0x1000\nREAD64 image: 13 offset: 0xb000 length: 0x1000\nREAD64 image: 13 offset: 0xc000 length: 0x1000\nREAD64 image: 13 offset: 0xd000 length: 0x1000\nREAD64 image: 13 offset: 0xe000 length: 0x1000\nREAD64 image: 13 offset: 0xf000 length: 0x1000\nREAD64 image: 13 offset: 0x10000 length: 0x1000\nREAD64 image: 13 offset: 0x11000 length: 0x1000\nREAD64 image: 13 offset: 0x12000 length: 0x1000\nREAD64 image: 13 offset: 0x13000 length: 0x1000\nREAD64 image: 13 offset: 0x14000 length: 0x1000\nREAD64 image: 13 offset: 0x15000 length: 0x1000\nREAD64 image: 13 offset: 0x16000 length: 0x1000\nREAD64 image: 13 offset: 0x17000 length: 0x1000\nREAD64 image: 13 offset: 0x18000 length: 0x1000\nREAD64 image: 13 offset: 0x19000 length: 0x1000\nREAD64 image: 13 offset: 0x1a000 length: 0x1000\nREAD64 image: 13 offset: 0x1b000 length: 0x1000\nREAD64 image: 13 offset: 0x1c000 length: 0x1000\nREAD64 image: 13 offset: 0x1d000 length: 0x1000\nREAD64 image: 13 offset: 0x1e000 length: 0x1000\nREAD64 image: 13 offset: 0x1f000 length: 0x1000\nREAD64 image: 13 offset: 0x20000 length: 0x1000\nREAD64 image: 13 offset: 0x21000 length: 0x1000\nREAD64 image: 13 offset: 0x22000 length: 0x1000\nREAD64 image: 13 offset: 0x23000 length: 0x1000\nREAD64 image: 13 offset: 0x24000 length: 0x1000\nREAD64 image: 13 offset: 0x25000 length: 0x1000\nREAD64 image: 13 offset: 0x26000 length: 0x1000\nREAD64 image: 13 offset: 0x27000 length: 0x1000\nREAD64 image: 13 offset: 0x28000 length: 0x1000\nREAD64 image: 13 offset: 0x29000 length: 0x1000\nREAD64 image: 13 offset: 0x2a000 length: 0x1000\nREAD64 image: 13 offset: 0x2b000 length: 0x1000\nREAD64 image: 13 offset: 0x2c000 length: 0x1000\nREAD64 image: 13 offset: 0x2d000 length: 0x1000\nREAD64 image: 13 offset: 0x2e000 length: 0x1000\nREAD64 image: 13 offset: 0x2f000 length: 0x1000\nREAD64 image: 13 offset: 0x30000 length: 0x1000\nREAD64 image: 13 offset: 0x31000 length: 0x1000\nREAD64 image: 13 offset: 0x32000 length: 0x1000\nREAD64 image: 13 offset: 0x33000 length: 0x1000\nREAD64 image: 13 offset: 0x34000 length: 0x1000\nREAD64 image: 13 offset: 0x35000 length: 0x1000\nREAD64 image: 13 offset: 0x36000 length: 0x1000\nREAD64 image: 13 offset: 0x37000 length: 0x1000\nREAD64 image: 13 offset: 0x38000 length: 0x1000\nREAD64 image: 13 offset: 0x39000 length: 0x1000\nREAD64 image: 13 offset: 0x3a000 length: 0x1000\nREAD64 image: 13 offset: 0x3b000 length: 0x1000\nREAD64 image: 13 offset: 0x3c000 length: 0x1000\nREAD64 image: 13 offset: 0x3d000 length: 0x1000\nREAD64 image: 13 offset: 0x3e000 length: 0x1000\nREAD64 image: 13 offset: 0x3f000 length: 0x1000\nREAD64 image: 13 offset: 0x40000 length: 0x1000\nREAD64 image: 13 offset: 0x41000 length: 0x1000\nREAD64 image: 13 offset: 0x42000 length: 0x1000\nREAD64 image: 13 offset: 0x43000 length: 0x1000\nREAD64 image: 13 offset: 0x44000 length: 0x1000\nREAD64 image: 13 offset: 0x45000 length: 0x1000\nREAD64 image: 13 offset: 0x46000 length: 0x1000\nREAD64 image: 13 offset: 0x47000 length: 0x1000\nREAD64 image: 13 offset: 0x48000 length: 0x1000\nREAD64 image: 13 offset: 0x49000 length: 0x1000\nREAD64 image: 13 offset: 0x4a000 length: 0x1000\nREAD64 image: 13 offset: 0x4b000 length: 0x1000\nREAD64 image: 13 offset: 0x4c000 length: 0x1000\nREAD64 image: 13 offset: 0x4d000 length: 0x1000\nREAD64 image: 13 offset: 0x4e000 length: 0x1000\nREAD64 image: 13 offset: 0x4f000 length: 0x1000\nREAD64 image: 13 offset: 0x50000 length: 0x1000\nREAD64 image: 13 offset: 0x51000 length: 0x1000\nREAD64 image: 13 offset: 0x52000 length: 0x1000\nREAD64 image: 13 offset: 0x53000 length: 0x1000\nREAD64 image: 13 offset: 0x54000 length: 0x1000\nREAD64 image: 13 offset: 0x55000 length: 0x1000\nREAD64 image: 13 offset: 0x56000 length: 0x1000\nREAD64 image: 13 offset: 0x57000 length: 0x1000\nREAD64 image: 13 offset: 0x58000 length: 0x1000\nREAD64 image: 13 offset: 0x59000 length: 0x1000\nREAD64 image: 13 offset: 0x5a000 length: 0x1000\nREAD64 image: 13 offset: 0x5b000 length: 0x1000\nREAD64 image: 13 offset: 0x5c000 length: 0x1000\nREAD64 image: 13 offset: 0x5d000 length: 0x1000\nREAD64 image: 13 offset: 0x5e000 length: 0x1000\nREAD64 image: 13 offset: 0x5f000 length: 0x1000\nREAD64 image: 13 offset: 0x60000 length: 0x1000\nREAD64 image: 13 offset: 0x61000 length: 0x1000\nREAD64 image: 13 offset: 0x62000 length: 0x1000\nREAD64 image: 13 offset: 0x63000 length: 0x1000\nREAD64 image: 13 offset: 0x64000 length: 0x1000\nREAD64 image: 13 offset: 0x65000 length: 0x16c\nREAD64 image: 13 offset: 0x65170 length: 0x1000\nREAD64 image: 13 offset: 0x66170 length: 0x1000\nREAD64 image: 13 offset: 0x67170 length: 0x1000\nREAD64 image: 13 offset: 0x68170 length: 0x1000\nREAD64 image: 13 offset: 0x69170 length: 0x1000\nREAD64 image: 13 offset: 0x6a170 length: 0x1000\nREAD64 image: 13 offset: 0x6b170 length: 0x1000\nREAD64 image: 13 offset: 0x6c170 length: 0x1000\nREAD64 image: 13 offset: 0x6d170 length: 0x1000\nREAD64 image: 13 offset: 0x6e170 length: 0x1000\nREAD64 image: 13 offset: 0x6f170 length: 0x1000\nREAD64 image: 13 offset: 0x70170 length: 0x1000\nREAD64 image: 13 offset: 0x71170 length: 0x6a0\nREAD64 image: 13 offset: 0x71810 length: 0x1000\nREAD64 image: 13 offset: 0x72810 length: 0x1000\nREAD64 image: 13 offset: 0x73810 length: 0x1000\nREAD64 image: 13 offset: 0x74810 length: 0x1000\nREAD64 image: 13 offset: 0x75810 length: 0x1000\nREAD64 image: 13 offset: 0x76810 length: 0x1000\nREAD64 image: 13 offset: 0x77810 length: 0x1000\nREAD64 image: 13 offset: 0x78810 length: 0x1000\nREAD64 image: 13 offset: 0x79810 length: 0x1000\nREAD64 image: 13 offset: 0x7a810 length: 0x1000\nREAD64 image: 13 offset: 0x7b810 length: 0x1000\nREAD64 image: 13 offset: 0x7c810 length: 0x1000\nREAD64 image: 13 offset: 0x7d810 length: 0x1000\nREAD64 image: 13 offset: 0x7e810 length: 0x1000\nREAD64 image: 13 offset: 0x7f810 length: 0x1000\nREAD64 image: 13 offset: 0x80810 length: 0x1000\nREAD64 image: 13 offset: 0x81810 length: 0xcc\nREAD64 image: 13 offset: 0x818e0 length: 0x84\nREAD64 image: 13 offset: 0x81964 length: 0x1000\nREAD64 image: 13 offset: 0x82964 length: 0x1000\nREAD64 image: 13 offset: 0x83964 length: 0x1000\nREAD64 image: 13 offset: 0x84964 length: 0x1000\nREAD64 image: 13 offset: 0x85964 length: 0x1000\nREAD64 image: 13 offset: 0x86964 length: 0x1000\nREAD64 image: 13 offset: 0x87964 length: 0x1000\nREAD64 image: 13 offset: 0x88964 length: 0x134\nREAD64 image: 13 offset: 0x88a98 length: 0x1000\nREAD64 image: 13 offset: 0x89a98 length: 0x1000\nREAD64 image: 13 offset: 0x8aa98 length: 0x1000\nREAD64 image: 13 offset: 0x8ba98 length: 0x1000\nREAD64 image: 13 offset: 0x8ca98 length: 0x1000\nREAD64 image: 13 offset: 0x8da98 length: 0x1000\nREAD64 image: 13 offset: 0x8ea98 length: 0x3f0\nREAD64 image: 13 offset: 0x8ee88 length: 0x1000\nREAD64 image: 13 offset: 0x8fe88 length: 0x1000\nREAD64 image: 13 offset: 0x90e88 length: 0x1000\nREAD64 image: 13 offset: 0x91e88 length: 0x1000\nREAD64 image: 13 offset: 0x92e88 length: 0x1000\nREAD64 image: 13 offset: 0x93e88 length: 0x1000\nREAD64 image: 13 offset: 0x94e88 length: 0x3f0\nREAD64 image: 13 offset: 0x95278 length: 0x1000\nREAD64 image: 13 offset: 0x96278 length: 0x1000\nREAD64 image: 13 offset: 0x97278 length: 0x1000\nREAD64 image: 13 offset: 0x98278 length: 0x1000\nREAD64 image: 13 offset: 0x99278 length: 0x1000\nREAD64 image: 13 offset: 0x9a278 length: 0x1000\nREAD64 image: 13 offset: 0x9b278 length: 0x1000\nREAD64 image: 13 offset: 0x9c278 length: 0x1000\nREAD64 image: 13 offset: 0x9d278 length: 0x1000\nREAD64 image: 13 offset: 0x9e278 length: 0x1000\nREAD64 image: 13 offset: 0x9f278 length: 0x1000\nREAD64 image: 13 offset: 0xa0278 length: 0x1000\nREAD64 image: 13 offset: 0xa1278 length: 0x1000\nREAD64 image: 13 offset: 0xa2278 length: 0x1000\nREAD64 image: 13 offset: 0xa3278 length: 0x1000\nREAD64 image: 13 offset: 0xa4278 length: 0x1000\nREAD64 image: 13 offset: 0xa5278 length: 0x1000\nREAD64 image: 13 offset: 0xa6278 length: 0x1000\nREAD64 image: 13 offset: 0xa7278 length: 0x1000\nREAD64 image: 13 offset: 0xa8278 length: 0x1000\nREAD64 image: 13 offset: 0xa9278 length: 0x1000\nREAD64 image: 13 offset: 0xaa278 length: 0x1000\nEND OF IMAGE image: 13 status: 0\nDONE status: 1\n[MODALAI] Completed sahara_run\n[MODALAI] Executing firehose_run\n[MODALAI] Executing firehose_read\nLOG: INFO: Binary build date: Aug 17 2021 @ 23:37:37\nLOG: INFO: Binary build date: Aug 17 2021 @ 23:37:37 \nLOG: INFO: Chip serial num: 2337757136 (0x8b5757d0)\nLOG: INFO: Supported Functions (15):\nLOG: INFO: program\nLOG: INFO: read\nLOG: INFO: nop\nLOG: INFO: patch\nLOG: INFO: configure\nLOG: INFO: setbootablestoragedrive\nLOG: INFO: erase\nLOG: INFO: power\nLOG: INFO: firmwarewrite\nLOG: INFO: getstorageinfo\nLOG: INFO: benchmark\nLOG: INFO: emmc\nLOG: INFO: ufs\nLOG: INFO: fixgpt\nLOG: INFO: getsha256digest\nLOG: INFO: End of supported functions 15\n[MODALAI] Completed firehose_read\n[MODALAI] Executing ufs_need_provisioning\n\n\n[MODALAI] ==== Executing firehose configure ====\nLOG: INFO: Calling handler for configure\nLOG: INFO: Storage type set to value UFS\nLOG: DEBUG: Calling usb_al_bulk_set_zlp_mode(TRUE), zlp is not set to 0\n\n\n[MODALAI] ==== Completed firehose configure ====\n\n\n[MODALAI] ==== Executing firehose erase ====\n\n\n[MODALAI] ==== Completed firehose erase ====\n\n\n[MODALAI] ==== Executing firehose program ====\nLOG: INFO: Calling handler for program\nLOG: DEBUG: Can't decode attribute slot with value \nLOG: ERROR: Failed to open the UFS Device slot 0 partition 0\nLOG: ERROR: Failed to open the device:3 slot:0 partition:0 error:0\nLOG: ERROR: OPEN handle NULL and no error, weird 344489460\nLOG: ERROR: Failed to open device, type:UFS, slot:0, lun:0 error:3\nqdl: firehose operation timed out\n[PROGRAM] failed to setup programming\n\nFlash flat build failed\n"}
    N. ChenN N. Chen
    @N-Chen
    Tested with a different qdl image (older one)-- 1.1.2-M0054-14.1a-FLAT-V3.
    Getting the same result.
    I wish someone from the dev team of voxl2 will respond to this, and explain what is going on.
    I've seen this exact issue at least for one other person as well-- https://forum.modalai.com/topic/4649/unbricking-qrb5165-m-flashing-fails-with-failed-to-initialize-ufs-device?_=1762965114696
    Also his thread got ignored some three months ago and he just left...
    This was a new board. I haven't done anything with it aside from powering it up.
    N. ChenN N. Chen
    @lhermosillo said in Recovering Flight Logs from a Bricked VOXL2:
    If you use the tool, you'll lose your data, unlike what you wished for in the OP.
    However, if you want to proceed with this issue, I'd unplug the usb from the host, and reboot the device. Once booted, I'd plug the device and check with lsusb that is there ID 05c6:9008 Qualcomm, Inc. Gobi Wireless Modem (QDL mode). Then do the webUI process (select image, then flash).
  • Bricked VOXL2
    N. ChenN N. Chen
    @roy-crosthwaite said in Bricked VOXL2:
    The only way I see the device is with lsusb or the web interface shown below
    I've just received the voxl2, so not a lot of experience with it. Just for me to understand-- why not try to unbrick it with the qdl webUI, as it is the only tool that detects it? I'm asking since I have the my board at the same exact state, but this webUI tool failed, so I'm wondering if you know something that I don't (like whether seeing the device via fastboot is a prerequisite for the unbricking).
    N. ChenN N. Chen
    @N-Chen
    Can someone from the ModalAI team assist with this issue?
  • Unbricking QRB5165 M: Flashing Fails with "Failed to initialize UFS Device"
    N. ChenN N. Chen
    Were you able to solve this issue and unbrick the device? Can you explain how?
    Starling & Starling 2
    N. ChenN N. Chen
    I'm trying to unbrick the voxl2 board.
    I followed https://docs.modalai.com/voxl2-unbricking
    and downloaded the image suggested for M0054-1/M0154-1:
    Latest: VOXL 2 QDL Image 14.1a_1.7.8
    As I have the QRB5165M.
    I get the following error:
    What is this issue?
    Any idea how to proceed from here?
    Full log:
