muhammad kazim 0M
muhammad kazim 0
@muhammad kazim 0
  • Urgent Assistance Needed: Voxl2 and portal access issue in my starling 2 modalai drone
    muhammad kazim 0M muhammad kazim 0
    @Alex-Kushleyev Thank you for your response, it was the issue with the battery, May be my battery is damaged, when I provide external power source of 12 volt power supply, then it is working perfectly fine. Now I am able to access the portal and voxl2 as well. thank you
    Development Drones
  • Starling2 live streaming and video recording
    I have a Starling2 Modalai drone and require assistance recording its live stream directly on my PC. Currently, QGroundControl saves recordings to Voxl2 instead of my PC. Could you please advise on how to save recordings locally and capture multiple video feeds simultaneously (hires_color, hires_grey, qvio_overlay, tof_depth, and tof_ir)? Thank you.
    Development Drones starling
    HI @all
    I have starling 2 Modalai drone, and I am experiencing an issue with my Starling 2 Modalai drone (Voxl2).
    I mistakenly removed the ROS Foxy installation from /opt/ros using rm -rf foxy and subsequently tried to reinstalled ROS2 Foxy following this guide https://github.com/jetsonhacks/installROS2.
    Then after rebooting the drone, I can initially access Voxl2 via adb shell for about two minutes. However, it then reverts to my PC shell, and subsequent attempts to connect (via adb shell or adb devices) yield no devices/emulators found. Additionally, I cannot access the Voxl portal. I have also switched the device to station mode for Wi-Fi access.
    If I wait approximately 30 minutes by turning off the drone, it works and I am able to access the voxl2 shell but the issue recurs after two minutes.
    Could someone please advise on how to resolve this problem as soon as possible?
    Thank you for your assistance.
    Development Drones
