I need 3D models for
https://www.modalai.com/products/mdk-m0061-2?variant=44563858850096
https://www.modalai.com/products/voxl-microhard-modem-usb-hub
Thank you.
Thank you.
@modaltb thank you for the detailed info, I am preparing a list of components I will order from ModalAI, and it'd be a pity if some of them aren't compatible with each other so I have to be careful about that.
Hi, I want to use two HD camera sensors (https://www.modalai.com/products/mdk-m0061-2?variant=44563858850096) and one Flir Boson 320(https://www.oemcameras.com/thermal-imaging-cameras/thermal-imaging-cores/flir-boson-series.htm/flir-boson-320x256-2mm.htm) on my drone. I know that the FLIR boson sensors are connected to USB and that's okay. I also checked the datasheet, and it says the board has support for four MIPI CSI cameras on the VOXL Mini 2 board but I noticed there are only two connectors(Camera Group 0 and 1). How do you connect 2 cameras(mentioned above link) to the board? Is there an additional board like this(https://www.modalai.com/collections/accessories/products/mdk-m0135) needed? And I am also wondering if VOXL 2 Mini and VOXL 2 have support for the same image sensors. Thank you.
Thank you @modaltb, but I have selected Boson 320 (https://www.flircameras.com/thermal-imaging-cameras/thermal-imaging-cores/flir-boson-series.htm/flir-boson-320x256-2mm.htm). is this camera supported?
has VOXL 2 Mini board support for Flir Boson cameras and are there additional components needed to connect to the Boson?
