@Alex-Kushleyev Just figured out why the motors were ceasing mid-air, it was the power module wire that was loose, so whenever I took off, the board was rebooting, (coz of the loose connection to the power module.)
Manu Verma
Voxl starling crashed all motors stop working mid air -
Voxl starling crashed all motors stop working mid air@Eric-Katzfey All 4 motors ceased at the same time it was not spinning at a lower speed after the crash.
Voxl starling crashed all motors stop working mid air@Alex-Kushleyev How can I send you the system data logs from Voxl not the px4 logs, since I can't attach any file here, can you tell by checking the system data logs? And how can I share that file here? Also, I gave the throttle to zero after it crashed.
Voxl starling crashed all motors stop working mid air@Eric-Katzfey Following is the system_data logs and PX4 logs recorded during last flight.
https://review.px4.io/plot_app?log=dd990b27-ef3a-453a-91ef-c51ff4dc4bbd
Voxl starling crashed all motors stop working mid airMy Starlink drone crashed while it was in mid-air, all 4 motors ceased working suddenly. After the crash, I saw qgc was not connected. Has anyone faced this problem? If so can anyone point out the reason and how to solve it? I am assuming it is because the communication failed or the Voxl restarted its services mid-air which led to the crash. If anyone has faced this problem can you please tell me how to sort this out?
ESC CalibrationHow to do ESC calibration with VOXL ESC . Do I need to calibrate it from the qgc or do I need to run a command to calibrate it?
