@Eric-Katzfey Oh, do you mean I can see the "RTC time" by timedatectl, but it doesn't mean voxl2 has the RTC? I see. Thank you for your answer.
Posts made by kay.han
RE: How to sync RTC to UTC in voxl2?posted in Ask your questions right here!
I am using voxl2. Whenever I connect the battery, the device resets the RTC(Real Time Clock) to 1970-01-01. This is understandable.
My issue is that I tried to sync the RTC to UTC using several ways, but I couldn't. Can I know the how to sync the RTC to the UTC?
I tried to use "$ sudo timedatectl set-local-rtc 0", it didn't work.
Another approach is using hwclock, but it didn't work either.
The last approach is the below command, but I met permission denied, even though I am a root user.
How can I RTC to UTC?
Thanks,
Kay -
RE: How to enable BBR in VOXL2?posted in Ask your questions right here!
@Moderator Oh, thank you so much for sharing it. I'll check it!
I would like to improve the network performance in VOXL2 and I found out about the BBR.
- https://blog.apnic.net/2020/01/10/when-to-use-and-not-use-bbr/
- https://www.linuxbabe.com/ubuntu/enable-google-tcp-bbr-ubuntu
I thought I could use the BBR because VOXL2's OS was ubuntu 18.04 and its kernel version was above 4.9. However, I encountered the error message below.
Is there a way to apply the BBR to VOXL2?
