    1. Home
    2. Jonathan Davis
    • Profile
    • Following 0
    • Followers 0
    • Topics 2
    • Posts 2
    • Best 2
    • Controversial 0
    • Groups 0
    Posts made by Jonathan Davis
    • Unable to run my own offboard node in starling 2
      I am using ros melodic and mavros to run my offboard node. It should fly in a square trajectory, but it stays still.
      When I try to run my offboard program, it instead runs the figure 8 which it should not because my own node is already running.
      Using the voxl-vision-hub wizard I tried to set it to offboard modes 1,2, & 3 and neither worked. In mode 1 it did the figure 8 trajectory. In mode 3 px4 didn't let me switch into offboard mode. In mode 2 it just stayed there.
      Here's my launch file:
      This is my voxl-vision-hub.conf file:
              "config_file_version":  1,
              "en_localhost_mavlink_udp":     false,
              "localhost_udp_port_number":    14551,
              "en_vio":       true,
              "vio_pipe":     "qvio",
              "secondary_vio_pipe":   "ov",
              "vio_warmup_s": 3,
              "send_odom_while_failed":       true,
              "horizon_cal_tolerance":        0.5,
              "offboard_mode":        "trajectory",
              "follow_tag_id":        0,
              "figure_eight_move_home":       true,
              "collision_sampling_dt":        0.1,
              "max_lookahead_distance":       1,
              "en_tag_fixed_frame":   false,
              "fixed_frame_filter_len":       5,
              "en_transform_mavlink_pos_setpoints_from_fixed_frame":  false,
              "en_voa":       true,
              "voa_upper_bound_m":    -0.15000000596046448,
              "voa_lower_bound_m":    0.15000000596046448,
              "voa_voa_memory_s":     1,
              "voa_max_pc_per_fusion":        100,
              "voa_pie_max_dist_m":   20,
              "voa_pie_min_dist_m":   0.25,
              "voa_pie_under_trim_m": 1,
              "voa_pie_threshold":    3,
              "voa_send_rate_hz":     20,
              "voa_pie_slices":       36,
              "voa_pie_bin_depth_m":  0.15000000596046448,
              "voa_inputs":   [{
                              "enabled":      true,
                              "type": "point_cloud",
                              "input_pipe":   "dfs_point_cloud",
                              "frame":        "stereo_l",
                              "max_depth":    8,
                              "min_depth":    0.300000011920929,
                              "cell_size":    0.079999998211860657,
                              "threshold":    4,
                              "x_fov_deg":    68,
                              "y_fov_deg":    56,
                              "conf_cutoff":  0
                              "enabled":      true,
                              "input_pipe":   "stereo_front_pc",
                              "frame":        "stereo_front_l",
                              "max_depth":    8,
                              "threshold":    4,
                              "x_fov_deg":    68,
                              "y_fov_deg":    56,
                              "conf_cutoff":  0
                              "enabled":      true,
                              "input_pipe":   "stereo_rear_pc",
                              "frame":        "stereo_rear_l",
                              "max_depth":    8,
                              "threshold":    4,
                              "x_fov_deg":    68,
                              "y_fov_deg":    56,
                              "conf_cutoff":  0
                              "enabled":      true,
                              "type": "tof",
                              "input_pipe":   "tof",
                              "frame":        "tof",
                              "max_depth":    6,
                              "min_depth":    0.15000000596046448,
                              "threshold":    3,
                              "x_fov_deg":    106.5,
                              "y_fov_deg":    85.0999984741211,
                              "conf_cutoff":  125
                      }, {![Screenshot 2024-03-29 175846.png](/assets/uploads/files/1711749611983-screenshot-2024-03-29-175846.png)
                              "enabled":      true,
                              "type": "rangefinder",
                              "input_pipe":   "rangefinders",
                              "frame":        "body",
                              "max_depth":    8,
                              "threshold":    4,
                              "x_fov_deg":    68,
                              "y_fov_deg":    56,
                              "conf_cutoff":  0
      Here is the part of my QGC log where it fails to move to offboard mode:
      k
      posted in VOXL 2
      J
      Jonathan Davis
      29 Mar 2024, 22:03
    • Waiting for EDL device
      I'm trying to re-flash the starling v2 voxl2 board by following the instructions here: https://docs.modalai.com/voxl2-unbricking/ .
      When I get to the step where I run
      "sudo qdl --debug --storage ufs --include . prog_firehose_ddr.elf rawprogram_unsparse0.xml rawprogram1.xml rawprogram2.xml rawprogram3.xml rawprogram4.xml rawprogram5.xml patch0.xml patch1.xml patch2.xml patch3.xml patch4.xml patch5.xml"
      it waits indefinitely, and doesn't print. ADB does not work, the last time I ssh'd in, and I had no read out from the command voxl-inspect-battery. Should there be prints while it is flashing, or is it just blank output until it is done? How should I proceed?
      posted in VOXL 2
      J
      Jonathan Davis
      28 Mar 2024, 16:21
