J
John Schmidt
@John Schmidt
  • RB5 Incorrect Altitude in QGC
    J John Schmidt
    No, I don't believe so. I only have one RB5 in the lab.
    Development Drones rb5
    J John Schmidt
    Hi there,
    I have been noticing that the altimeter in QGroundControl is displaying the wrong data for the RB5 Flight. Moving the drone up by hand and holding it reports a positive number for a brief moment before reporting zero, and moving the drone down and holding it reports a negative number for a brief moment before reporting zero. This makes me think that GQC is actually reporting vertical speed data instead of altitude data, and I tried a sensor calibration through QGC, but the problem still exists. Is there a way to check the pose/vehicle odometry for the RB5 like there was for the VOXL drones? Any help would be appreciated.
    Thanks,
    John S
  • RB5 April Tag advice / repair advice
    J John Schmidt
    @Adrian-Hidalgo I just sent an email to the address you gave. Thanks again!
    J John Schmidt
    @Adrian-Hidalgo Thanks for the advice. I don't believe I need to splice the left cable, soldering is not too much of an issue. As for the right cable, would it be possible to send over a replacement?
    J John Schmidt
    @Alex-Gardner That's good to hear, I'll be on a lookout for the new release. Thanks!
    J John Schmidt
    Hi there,
    I was looking into a project that uses April Tag detection, and I am going to try to get that working on the RB5 Flight. However, I noticed that there is an example in the VOXL sdk that features April Tag relocalization and started wondering if there is something similar for the RB5 sdk. If there isn't, do you have any pointers on how I could go about detecting April Tags with the RB5 flight?
    Also, after bringing the quad down for landing a little too hard after a flight, I found two things that I need to repair.
    I believe the snapped wire from the spektrum receiver in the left red circle just needs to be resoldered, but the plug in the right red circle must have cracked a little as it does not stay plugged in anymore. Is it possible to order a new set of wires with that plug/connector to replace the old one, or am I better off just cutting the plug from the existing wires and soldering a new one to exposed end?
    Any advice would be greatly appreciated.
    Thanks,
    John
