James KDHJ
James KDH
@James KDH
  • Setting up Voxl2 MicroDDS Communication with PX4
    James KDHJ James KDH
    Okay I managed to solve the problem. The reason why my external pc is unable to see the /fmu topics is probably due to the voxl-microdds-agent service starting before the network is fully "set up". From this stack overflow topic, I edited my /etc/systemd/system/voxl-microdds-agent.service file to include the line ExecStartPre=/bin/sh -c 'until ping -c1 google.com; do sleep 1; done; (this is the only "hacky" method that somehow worked). My entire service file is:
    [Unit]
    Description=voxl-microdds-agent
    SourcePath=/usr/bin/MicroXRCEAgent
    After=network.target
    After=multi-user.target
    # After=network-online.target
    # Wants=network-online.target
    [Service]
    User=root
    Type=simple
    ExecStartPre=/bin/sh -c 'until ping -c1 google.com; do sleep 1; done;'
    ExecStart=/usr/bin/MicroXRCEAgent udp4 -p 8888
    [Install]
    WantedBy=multi-user.target
    After modifying the service file and rebooting the voxl2, the external computer can now see and echo topics from the /fmu. This will obviously not work if the voxl2 is not connected to the internet.. However you can still manually fix this by ssh or adb shell into the voxl2 and restart the service using the commands:
    systemctl stop voxl-microdds-agent
    systemctl start voxl-microdds-agent
    and the external computer should be able to see /fmu topics.
    On a side note, to customize & add a prefix to the /fmu topic such that it is /drone1/fmu/ in ROS2, edit the px4 start up script /usr/bin/voxl-px4-start. There is a line that starts the microdds_client for px4 where:
    # Start microdds_client for ros2 offboard messages from agent over localhost
    microdds_client start -t udp -h 127.0.0.1 -p 8888
    Simply add -n <desired _name> such that it becomes:
    microdds_client start -t udp -h 127.0.0.1 -p 8888 -n drone2
    VOXL SDK and Software ros
    @brahim I tried setting on both the voxl2 and external PC
    ROS_DOMAIN_ID = 0
    ROS_LOCALHOST_ONLY = 0
    and I am still unable to see the /fmu topics on the external pc. Running
    ifconfig | grep -i multicast
    Results in something like in both the external pc and voxl2.
    bond0: flags=5123<UP,BROADCAST,MASTER,MULTICAST>  mtu 1500
    docker0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
    wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
    Which indicates that multicast enabled on both the external pc and voxl2.
    Hello, I managed to fix this issue. Turns out the ROS domain ID needs to be 0 (by default), I set it to 1 previously and could not echo out the fmu topics. By simply setting it to 0 again i am able to see the /fmu topics now.
    export ROS_DOMAIN_ID=0
    However I encounter another issue where I am unable to see the /fmu out topics in an external computer but voxl2 can see topics that are being published by the computer as shown in the image below.
    Also is there a way to remap the topic names ? i.e from /fmu to /drone_1.
    To give some context, me and my lab is trying to experiment with indoor swarming. Thus it is essential for the drones to be able to communicate with each other (such as via ROS2).
    @Zachary-Lowell-0 Yes I have installed ros2 foxy and the mpa-to-ros2 deb. Running the command:
    systemctl status voxl-microdds-agent
    Gives this output:
    Meanwhile running :
    ros2 topic list
    Still gives nothing:
    I am running SDK version 1.35 on starling 2.
    Hello, I tried following this guide to set up Voxl2 MicroDDS Communication with PX4. After running the two commands given in the documentation:
    1. apt install -y voxl-microdds-agent
    2. voxl-configure-microdds
    I don't see any uORB topics published in ROS2. I have tried using voxl-inspect-services and the micro-dds-agent is indeed running in the voxl2. Am I missing something here? Thanks!
