david devassyD
david devassy
@david devassy
  • Starling: unable to run adb shell
    david devassyD david devassy
    @modaltb Hi thanks for the update. I have used the file which is shared by modal AI team through email and it worked 100%
    Here is the file
    https://storage.googleapis.com/modalai_public/qdl/2024-02-09-1.7.4-M0054-2.zip
    Thanks again.
  • Starling not arming
    Thanks for the wonderful support from team modal AI. Here is the solution which they have shared with me, which is tested and working 100%.
    Please download the attached file
    file:
    Download this
    Move into the ufs sub directory of that release ^:
    cd 2024-02-09-1.7.4-M0054-2/ufs
    Slide the SW2 switch to ON to be in QDL mode
    Plug in power and USB
    Run:
    sudo qdl --debug --storage ufs --include . prog_firehose_ddr.elf rawprogram_unsparse0.xml rawprogram1.xml rawprogram2.xml rawprogram3.xml rawprogram4.xml rawprogram5.xml patch0.xml patch1.xml patch2.xml patch3.xml patch4.xml patch5.xml
    Development Drones starling
  • How to do SLAM and VOXL-Mapper flying with Starling Drone ?
    @tom
    I have a new issue
    Since yesterday, when I turned on the Starling drone, it just sits there. It's not getting armed. When I checked for ADB shell, it's not getting connected, and an error comes up saying no devices found. When I checked the forum, it said it might be bricked due to some file loss. We followed the unbrick tutorial, and after successful flashing of the latest QDL M0054.14.1a-flat-v3, the device is showing up as Qualcomm bulk something. However, ADB still isn't getting connected.
    Please note that I am unable to enter adb shell and fast boot mode .
    For unbrick I followed this
    https://docs.modalai.com/voxl2-unbricking
    https://docs.modalai.com/voxl2-unbricking/
  • Starling not arming. Un reliable product!!?
    How can I solve this?
    @tom yes its a new one. stock unmodified. i think TOF module is not working properly. Do you provide any warranty for these.?
    @tom voxl2:/$ voxl-list-pipes
    cpu_monitor
    gcs_ip_list
    hires_large_color
    hires_large_encoded
    hires_large_grey
    hires_small_color
    hires_small_encoded
    hires_small_grey
    hires_snapshot
    horizon_cal_io
    imu_apps
    imu_apps_fft
    mavlink_ap_heartbeat
    mavlink_attitude
    mavlink_from_gcs
    mavlink_gps_raw_int
    mavlink_local_position_ned
    mavlink_onboard
    mavlink_sys_status
    mavlink_to_gcs
    modal_io_bridge
    plan_msgs
    qvio
    qvio_extended
    qvio_overlay
    tracking
    voa_pc_out
    voxl_mapper_aligned_ptcloud
    voxl_mapper_costmap
    voxl_mesh
    voxl_mesh_endpoint
    voxl_planner_render
    vvhub_body_wrt_fixed
    vvhub_body_wrt_local
    vvhub_fixed_pose_input
    voxl2:/$ systemctl status voxl-camera-server
    ● voxl-camera-server.service - voxl-camera-server
    Loaded: loaded (/usr/bin/voxl-camera-server; enabled; vendor preset: enabled)
    Active: active (running) since Fri 2024-04-12 09:02:25 UTC; 3min 59s ago
    Main PID: 1404 (voxl-camera-ser)
    Tasks: 68 (limit: 4915)
    CGroup: /system.slice/voxl-camera-server.service
    └─1404 /usr/bin/voxl-camera-server
    Apr 12 09:02:25 m0054 voxl-camera-server[1404]: gbm_create_device(156): Info: backend name is: msm_drm
    Apr 12 09:02:25 m0054 voxl-camera-server[1404]: Starting Camera: tracking (originally id #2) with id offset: 1
    Apr 12 09:02:25 m0054 voxl-camera-server[1404]: Using gain limits min: 54 max: 3451
    Apr 12 09:02:25 m0054 voxl-camera-server[1404]: setting ov7251 BLC register for cam id 1
    Apr 12 09:02:25 m0054 voxl-camera-server[1404]: ------ voxl-camera-server: Started 2 of 3 cameras
    Apr 12 09:02:25 m0054 voxl-camera-server[1404]: ------ voxl-camera-server: Camera server is now running
    voxl2:/$
    @tom
    VOXL Platform: M0054
    INFO: ESC(s) detected on port: /dev/slpi-uart-2, baud rate: 2000000
    INFO: ESCs detected:
    INFO: ---------------------
    ID: 0, SW: 39, HW: 37: ModalAi 4-in-1 ESC (M0134-1)
    ID: 1, SW: 39, HW: 37: ModalAi 4-in-1 ESC (M0134-1)
    ID: 2, SW: 39, HW: 37: ModalAi 4-in-1 ESC (M0134-1)
    ID: 3, SW: 39, HW: 37: ModalAi 4-in-1 ESC (M0134-1)
    INFO: Loading XML config file...
    INFO: Uploading params for ESC ID 255...
    -- board config
    -- id config
    -- uart config
    -- tune config
    DONE
    INFO: Resetting ESCs...
    DONE
    WARNING: Received 12 bytes of data from SLPI while SLPI uart not in use (topic uart_data)
    disabling bridge
    bridge disabled
    Success!
    executing: voxl-elrs --scan
    [ERROR] Error reading device information.
    [ERROR] Ensure that transmitter is turned off and receiver is not in bootloader mode.
    first try failed, executing a second time: voxl-elrs --scan
    FAILED TO EXECUTE: voxl-elrs --scan
    executing: systemctl stop voxl-px4
    Success!
    executing: rm -f /data/px4/param/parameters
    Success!
    executing: voxl-configure-px4 starling_v2
    wiping old config file
    enabling voxl-px4 systemd service
    Created symlink /etc/systemd/system/multi-user.target.wants/voxl-px4.service → /etc/systemd/system/voxl-px4.service.
    Done configuring voxl-px4
    Success!
    executing: systemctl stop voxl-mavlink-server
    Success!
    executing: sleep 1
    Success!
    executing: voxl-configure-px4-params --non-interactive --platform MRB-D0005-V2
    [INFO] Voxl-px4 not currently running.
    [INFO] Starting voxl-px4 service...
    [INFO] Voxl-px4 started successfully!
    [INFO] Loading the following param files: platforms/Starling_V2.params, EKF2_helpers/indoor_vio.params, radio_helpers/Commando_8.params.
    [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/platforms/Starling_V2.params
    [INFO] Scanning currently loaded parameters...
    The following parameters about to be loaded differ from those currently loaded:
    NAME CURRENT NEW
    [1] CBRK_IO_SAFETY N/A 22027
    [2] COM_CPU_MAX 0.0 -1.0
    [3] COM_OF_LOSS_T N/A 3.0
    [4] NAV_ACC_RAD N/A 2.0
    [5] GPS_UBX_DYNMODEL N/A 6
    [6] RTL_RETURN_ALT N/A 30
    [7] RTL_DESCEND_ALT N/A 10
    [8] SENS_BOARD_ROT N/A 0
    [9] BAT1_N_CELLS N/A 2
    [10] BAT1_R_INTERNAL N/A 0.025
    [11] BAT1_CAPACITY N/A 2900
    [12] BAT1_V_CHARGED N/A 4.1
    [13] BAT1_V_EMPTY N/A 3.2
    [14] BAT_LOW_THR N/A 0.15
    [15] BAT_CRIT_THR N/A 0.10
    [16] BAT_EMERGEN_THR N/A 0.05
    [17] MPC_THR_HOVER 0.42 0.34
    [18] THR_MDL_FAC N/A 0.9
    [19] VOXL_ESC_RPM_MAX 10500.0 15000.0
    [20] VOXL_ESC_RPM_MIN 1000.0 3000.0
    [21] VOXL_ESC_FUNC2 103.0 104.0
    [22] VOXL_ESC_FUNC3 104.0 102.0
    [23] VOXL_ESC_FUNC4 102.0 103.0
    [24] VOXL_ESC_T_COSP N/A 0.990000009536743164
    [25] VOXL_ESC_T_DEAD N/A 20
    [26] VOXL_ESC_T_EXPO N/A 35
    [27] VOXL_ESC_T_MINF N/A 0.150000005960464478
    [28] VOXL_ESC_T_PERC N/A 90
    [29] VOXL_ESC_VLOG N/A 1
    [30] MC_BAT_SCALE_EN N/A 0
    [31] EKF2_IMU_POS_X 0.027 0.0157
    [32] EKF2_IMU_POS_Y 0.009 0.0078
    [33] EKF2_IMU_POS_Z -0.019 -0.018
    [34] EKF2_EV_POS_X N/A 0.0
    [35] EKF2_EV_POS_Y N/A 0.0
    [36] EKF2_EV_POS_Z N/A 0.0
    [37] CA_ROTOR0_PX 0.15 0.085
    [38] CA_ROTOR0_PY 0.15 0.0625
    [39] CA_ROTOR1_PX -0.15 -0.085
    [40] CA_ROTOR1_PY -0.15 -0.0625
    [41] CA_ROTOR2_PX 0.15 0.085
    [42] CA_ROTOR2_PY -0.15 -0.0625
    [43] CA_ROTOR3_PX -0.15 -0.085
    [44] CA_ROTOR3_PY 0.15 0.0625
    [45] CA_ROTOR0_AX N/A 0.0
    [46] CA_ROTOR0_AY N/A 0.0
    [47] CA_ROTOR1_AX N/A 0.0
    [48] CA_ROTOR1_AY N/A 0.0
    [49] CA_ROTOR2_AX N/A 0.0
    [50] CA_ROTOR2_AY N/A 0.0
    [51] CA_ROTOR3_AX N/A 0.0
    [52] CA_ROTOR3_AY N/A 0.0
    [53] CA_ROTOR0_KM N/A 0.05
    [54] CA_ROTOR1_KM N/A 0.05
    [55] MOT_SLEW_MAX N/A 0.0
    [56] IMU_DGYRO_CUTOFF N/A 60.0
    [57] IMU_ACCEL_CUTOFF N/A 80.0
    [58] IMU_GYRO_CUTOFF N/A 80.0
    [59] IMU_GYRO_DNF_EN N/A 1
    [60] IMU_GYRO_DNF_HMC N/A 3
    [61] IMU_GYRO_DNF_BW N/A 15
    [62] MC_PITCH_P 5.5 16.0
    [63] MC_PITCHRATE_P 0.08 0.12
    [64] MC_PITCHRATE_I 0.2 0.05
    [65] MC_PITCHRATE_D 0.0013 0.0015
    [66] MC_PITCH_CUTOFF N/A 150.0
    [67] MC_ROLL_P 5.5 16.0
    [68] MC_ROLLRATE_P 0.08 0.09
    [69] MC_ROLLRATE_I 0.2 0.05
    [70] MC_ROLLRATE_D 0.0013 0.0015
    [71] MC_ROLL_CUTOFF N/A 150.0
    [72] MC_YAW_P 2.0 2.8
    [73] MC_YAWRATE_I 0.1 0.5
    [74] MC_YAW_CUTOFF N/A 150.0
    [75] MC_ROLLRATE_MAX N/A 130.0
    [76] MC_PITCHRATE_MAX N/A 130.0
    [77] MC_YAWRATE_MAX N/A 150.0
    [78] MPC_POS_MODE 0.0 4.0
    [79] MPC_YAW_EXPO 0.2 0.3
    [80] MPC_XY_MAN_EXPO 0.2 0.45
    [81] MPC_Z_MAN_EXPO 0.2 0.1
    [82] MPC_ACC_HOR N/A 3.0
    [83] MPC_JERK_MAX N/A 40.0
    [84] MPC_TILTMAX_AIR N/A 30.0
    [85] MPC_ACC_HOR_MAX N/A 1000.0
    [86] MPC_ACC_UP_MAX N/A 3.0
    [87] MPC_ACC_DOWN_MAX N/A 3.0
    [88] MPC_VEL_MANUAL 5.0 3.0
    [89] MPC_XY_VEL_MAX 5.0 3.0
    [90] MPC_XY_CRUISE 5.0 3.0
    [91] MPC_Z_VEL_MAX_DN 1.5 1.0
    [92] MPC_Z_VEL_MAX_UP 4.0 1.0
    [93] MPC_HOLD_MAX_XY N/A 0.0
    [94] MPC_HOLD_MAX_Z N/A 0.0
    [95] MPC_THR_MAX 0.75 0.7
    [96] MPC_MANTHR_MIN 0.05 0.08
    [97] MPC_XY_P 0.95 3.5
    [98] MPC_Z_P 1.0 5.0
    [99] MPC_TKO_RAMP_T 1.5 1.0
    [100] COM_SPOOLUP_TIME N/A 2.0
    [101] LNDMC_ROT_MAX N/A 30.0
    [102] LNDMC_TRIG_TIME N/A 0.5
    [103] COM_DISARM_LAND N/A 0.1
    [104] COM_DISARM_PRFLT -1.0 20.0
    [INFO] Setting params...
    [ERROR] Failed to set PX4 parameters. Check voxl-px4 status for details.
    first try failed, executing a second time: voxl-configure-px4-params --non-interactive --platform MRB-D0005-V2
    [INFO] Voxl-px4 service found and active.
    NAME CURRENT NEW
    [2] CBRK_SUPPLY_CHK N/A 894281
    [3] COM_CPU_MAX N/A -1
    [4] COM_OF_LOSS_T N/A 3.0
    [5] NAV_ACC_RAD N/A 2.0
    [6] GPS_UBX_DYNMODEL N/A 6
    [7] RTL_RETURN_ALT N/A 30
    [8] RTL_DESCEND_ALT N/A 10
    [9] IMU_GYRO_RATEMAX N/A 800
    [10] SYS_AUTOSTART N/A 4001
    [11] MAV_TYPE N/A 2
    [12] SENS_BOARD_ROT N/A 0
    [13] BAT1_N_CELLS N/A 2
    [14] BAT1_R_INTERNAL N/A 0.025
    [15] BAT1_CAPACITY N/A 2900
    [16] BAT1_V_CHARGED N/A 4.1
    [17] BAT1_V_EMPTY N/A 3.2
    [18] BAT_LOW_THR N/A 0.15
    [19] BAT_CRIT_THR N/A 0.10
    [20] BAT_EMERGEN_THR N/A 0.05
    [21] MPC_THR_HOVER N/A 0.34
    [22] THR_MDL_FAC N/A 0.9
    [23] VOXL_ESC_FUNC1 N/A 101
    [24] VOXL_ESC_FUNC2 103.0 104.0
    [25] VOXL_ESC_FUNC3 104.0 102.0
    [26] VOXL_ESC_FUNC4 102.0 103.0
    [27] VOXL_ESC_SDIR1 N/A 0
    [28] VOXL_ESC_SDIR2 N/A 0
    [29] VOXL_ESC_SDIR3 N/A 0
    [30] VOXL_ESC_SDIR4 N/A 0
    [31] VOXL_ESC_BAUD N/A 2000000
    [32] VOXL_ESC_CONFIG N/A 1
    [33] VOXL_ESC_MODE N/A 0
    [34] VOXL_ESC_REV N/A 0
    [35] CA_AIRFRAME N/A 0
    [36] CA_ROTOR_COUNT N/A 4
    [37] CA_ROTOR2_KM N/A -0.05
    [38] CA_ROTOR3_KM N/A -0.05
    [39] MC_AIRMODE N/A 0
    [40] MC_PITCHRATE_K N/A 1.0
    [41] MC_ROLLRATE_K N/A 1.0
    [42] MC_YAWRATE_P N/A 0.15
    [43] MC_YAWRATE_D N/A 0.0
    [44] MC_YAWRATE_K N/A 1.0
    [45] MPC_LAND_SPEED N/A 1.0
    [46] MPC_THR_MIN N/A 0.08
    [47] MPC_XY_VEL_P_ACC N/A 3.00
    [48] MPC_XY_VEL_I_ACC N/A 0.10
    [49] MPC_XY_VEL_D_ACC N/A 0.00
    [50] MPC_Z_VEL_P_ACC N/A 8.0
    [51] MPC_Z_VEL_I_ACC N/A 2.0
    [52] MPC_Z_VEL_D_ACC N/A 0.0
    [53] MPC_TKO_SPEED N/A 1.50
    [INFO] PX4 parameter configuration successful!
    [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/EKF2_helpers/indoor_vio.params
    NAME CURRENT NEW
    [1] SYS_HAS_MAG N/A 1
    [2] SYS_HAS_GPS N/A 1
    [3] COM_ARM_WO_GPS N/A 1
    [4] EKF2_GPS_CTRL N/A 0
    [5] EKF2_MAG_TYPE N/A 5
    [6] EKF2_BARO_CTRL N/A 1
    [7] EKF2_EV_CTRL N/A 15
    [8] EKF2_OF_CTRL N/A 0
    [9] EKF2_RNG_CTRL N/A 0
    [10] EKF2_HGT_REF N/A 3
    [11] EKF2_EV_QMIN N/A 1
    [12] EKF2_EV_NOISE_MD N/A 0
    [13] EKF2_EVA_NOISE N/A 0.1
    [14] EKF2_EVP_GATE N/A 5.0
    [15] EKF2_EVP_NOISE N/A 0.1
    [16] EKF2_EVV_GATE N/A 3.0
    [17] EKF2_EVV_NOISE N/A 0.1
    [18] EKF2_EV_DELAY N/A 0.00
    [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/radio_helpers/Commando_8.params
    NAME CURRENT NEW
    [1] RC_CHAN_CNT N/A 16
    [2] RC_MAP_KILL_SW N/A 5
    [3] RC_MAP_FLTMODE N/A 6
    [4] COM_FLTMODE1 N/A 0
    [5] COM_FLTMODE2 N/A -1
    [6] COM_FLTMODE3 N/A -1
    [7] COM_FLTMODE4 N/A 2
    [8] COM_FLTMODE5 N/A -1
    [9] COM_FLTMODE6 N/A 7
    [10] RC1_DZ N/A 10.000000000000000000
    [11] RC1_MAX N/A 2000.000000000000000000
    [12] RC1_MIN N/A 1000.000000000000000000
    [13] RC1_REV N/A 1.000000000000000000
    [14] RC1_TRIM N/A 1500.000000000000000000
    [15] RC2_DZ N/A 10.000000000000000000
    [16] RC2_MAX N/A 2000.000000000000000000
    [17] RC2_MIN N/A 1000.000000000000000000
    [18] RC2_REV N/A 1.000000000000000000
    [19] RC2_TRIM N/A 1500.000000000000000000
    [20] RC3_DZ N/A 10.000000000000000000
    [21] RC3_MAX N/A 2000.000000000000000000
    [22] RC3_MIN N/A 1000.000000000000000000
    [23] RC3_REV N/A 1.000000000000000000
    [24] RC3_TRIM N/A 1500.000000000000000000
    [25] RC4_DZ N/A 10.000000000000000000
    [26] RC4_MAX N/A 2000.000000000000000000
    [27] RC4_MIN N/A 1000.000000000000000000
    [28] RC4_REV N/A 1.000000000000000000
    [29] RC4_TRIM N/A 1500.000000000000000000
    [30] RC5_DZ N/A 10.000000000000000000
    [31] RC5_MAX N/A 1988.000000000000000000
    [32] RC5_MIN N/A 1011.000000000000000000
    [33] RC5_REV N/A 1.000000000000000000
    [34] RC5_TRIM N/A 1500.000000000000000000
    [35] RC6_DZ N/A 10.000000000000000000
    [36] RC6_MAX N/A 1988.000000000000000000
    [37] RC6_MIN N/A 1011.000000000000000000
    [38] RC6_REV N/A 1.000000000000000000
    [39] RC6_TRIM N/A 1500.000000000000000000
    [40] RC7_DZ N/A 10.000000000000000000
    [41] RC7_MAX N/A 1988.000000000000000000
    [42] RC7_MIN N/A 1011.000000000000000000
    [43] RC7_REV N/A 1.000000000000000000
    [44] RC7_TRIM N/A 1500.000000000000000000
    [45] RC8_DZ N/A 10.000000000000000000
    [46] RC8_MAX N/A 1988.000000000000000000
    [47] RC8_MIN N/A 1011.000000000000000000
    [48] RC8_REV N/A 1.000000000000000000
    [49] RC8_TRIM N/A 1500.000000000000000000
    [50] RC9_DZ N/A 0.000000000000000000
    [51] RC9_MAX N/A 2000.000000000000000000
    [52] RC9_MIN N/A 1000.000000000000000000
    [53] RC9_REV N/A 1.000000000000000000
    [54] RC9_TRIM N/A 1500.000000000000000000
    [55] RC10_DZ N/A 0.000000000000000000
    [56] RC10_MAX N/A 2000.000000000000000000
    [57] RC10_MIN N/A 1000.000000000000000000
    [58] RC10_REV N/A 1.000000000000000000
    [59] RC10_TRIM N/A 1500.000000000000000000
    [60] RC11_DZ N/A 0.000000000000000000
    [61] RC11_MAX N/A 2000.000000000000000000
    [62] RC11_MIN N/A 1000.000000000000000000
    [63] RC11_REV N/A 1.000000000000000000
    [64] RC11_TRIM N/A 1500.000000000000000000
    [65] RC12_DZ N/A 0.000000000000000000
    [66] RC12_MAX N/A 1988.000000000000000000
    [67] RC12_MIN N/A 1011.000000000000000000
    [68] RC12_REV N/A 1.000000000000000000
    [69] RC12_TRIM N/A 1499.000000000000000000
    [70] RC13_DZ N/A 0.000000000000000000
    [71] RC13_MAX N/A 2000.000000000000000000
    [72] RC13_MIN N/A 1000.000000000000000000
    [73] RC13_REV N/A 1.000000000000000000
    [74] RC13_TRIM N/A 1500.000000000000000000
    [75] RC14_DZ N/A 0.000000000000000000
    [76] RC14_MAX N/A 2000.000000000000000000
    [77] RC14_MIN N/A 1000.000000000000000000
    [78] RC14_REV N/A 1.000000000000000000
    [79] RC14_TRIM N/A 1500.000000000000000000
    [80] RC15_DZ N/A 0.000000000000000000
    [81] RC15_MAX N/A 2000.000000000000000000
    [82] RC15_MIN N/A 1000.000000000000000000
    [83] RC15_REV N/A 1.000000000000000000
    [84] RC15_TRIM N/A 1500.000000000000000000
    [85] RC16_DZ N/A 0.000000000000000000
    [86] RC16_MAX N/A 2000.000000000000000000
    [87] RC16_MIN N/A 1000.000000000000000000
    [88] RC16_REV N/A 1.000000000000000000
    [89] RC16_TRIM N/A 1500.000000000000000000
    [90] RC17_DZ N/A 0.000000000000000000
    [91] RC17_MAX N/A 2000.000000000000000000
    [92] RC17_MIN N/A 1000.000000000000000000
    [93] RC17_REV N/A 1.000000000000000000
    [94] RC17_TRIM N/A 1500.000000000000000000
    [95] RC18_DZ N/A 0.000000000000000000
    [96] RC18_MAX N/A 2000.000000000000000000
    [97] RC18_MIN N/A 1000.000000000000000000
    [98] RC18_REV N/A 1.000000000000000000
    [99] RC18_TRIM N/A 1500.000000000000000000
    [100] RC_MAP_ACRO_SW N/A 0
    [101] RC_MAP_ARM_SW N/A 0
    [102] RC_MAP_AUX1 N/A 0
    [103] RC_MAP_AUX2 N/A 0
    [104] RC_MAP_AUX3 N/A 0
    [105] RC_MAP_AUX4 N/A 0
    [106] RC_MAP_AUX5 N/A 0
    [107] RC_MAP_AUX6 N/A 0
    [108] RC_MAP_FAILSAFE N/A 0
    [109] RC_MAP_FLAPS N/A 0
    [110] RC_MAP_GEAR_SW N/A 0
    [111] RC_MAP_LOITER_SW N/A 0
    [112] RC_MAP_MAN_SW N/A 0
    [113] RC_MAP_MODE_SW N/A 0
    [114] RC_MAP_OFFB_SW N/A 0
    [115] RC_MAP_PARAM1 N/A 0
    [116] RC_MAP_PARAM2 N/A 0
    [117] RC_MAP_PARAM3 N/A 0
    [118] RC_MAP_PITCH N/A 2
    [119] RC_MAP_POSCTL_SW N/A 0
    [120] RC_MAP_RATT_SW N/A 0
    [121] RC_MAP_RETURN_SW N/A 0
    [122] RC_MAP_ROLL N/A 1
    [123] RC_MAP_STAB_SW N/A 0
    [124] RC_MAP_THROTTLE N/A 3
    [125] RC_MAP_TRANS_SW N/A 0
    [126] RC_MAP_YAW N/A 4
    [INFO] Loading file: /data/px4/param/parameters_gyro.cal
    NAME CURRENT NEW
    [1] CAL_GYRO0_ID N/A 2490378
    [2] CAL_GYRO0_PRIO N/A 50
    [3] CAL_GYRO0_XOFF N/A 0.0134728
    [4] CAL_GYRO0_YOFF N/A -0.00290391
    [5] CAL_GYRO0_ZOFF N/A -0.000202846
    [6] CAL_GYRO0_ROT N/A -1
    [INFO] Trimming duplicate parameters...
    [INFO] Loading file: /data/px4/param/parameters_acc.cal
    NAME CURRENT NEW
    [1] CAL_ACC0_ID N/A 2490378
    [2] CAL_ACC0_PRIO N/A 50
    [3] CAL_ACC0_XOFF N/A 0.016479
    [4] CAL_ACC0_YOFF N/A 0.0495152
    [5] CAL_ACC0_ZOFF N/A -0.00822353
    [6] CAL_ACC0_XSCALE N/A 1
    [7] CAL_ACC0_YSCALE N/A 1
    [8] CAL_ACC0_ZSCALE N/A 1
    [9] CAL_ACC0_ROT N/A -1
    [INFO] Loading file: /data/px4/param/parameters_level.cal
    NAME CURRENT NEW
    [1] SENS_BOARD_X_OFF N/A 0.0105941
    [2] SENS_BOARD_Y_OFF N/A 0.00175017
    [INFO] Loading file: /data/px4/param/parameters_mag.cal
    NAME CURRENT NEW
    [1] CAL_MAG0_ID N/A 527625
    [2] CAL_MAG0_PRIO N/A 75
    [3] CAL_MAG0_XOFF N/A -0.284582
    [4] CAL_MAG0_YOFF N/A -0.281098
    [5] CAL_MAG0_ZOFF N/A 0.219934
    [6] CAL_MAG0_XSCALE N/A 1.00463
    [7] CAL_MAG0_YSCALE N/A 1.01471
    [8] CAL_MAG0_ZSCALE N/A 0.979607
    [9] CAL_MAG0_XODIAG N/A -0.0119525
    [10] CAL_MAG0_YODIAG N/A 0.0184261
    [11] CAL_MAG0_ZODIAG N/A -0.00372516
    [12] CAL_MAG0_XCOMP N/A 0
    [13] CAL_MAG0_YCOMP N/A 0
    [14] CAL_MAG0_ZCOMP N/A 0
    [15] CAL_MAG0_ROT N/A 0
    [INFO] Loading file: /data/px4/param/parameters_rc.cal
    [INFO] No difference in parameters was detected.
    [INFO] Done configuring for platform MRB-D0005-V2
    Success running a second time
         The following steps worked on the second try:
         FAILED TO EXECUTE the following steps:
    voxl-elrs --scan
      Encountered Problems Configuring MPA Services :-/
        Some Services may not start up on next reboot
    Calibration File Status:
    Present /data/modalai/voxl-imu-server.cal
    Present /data/modalai/opencv_tracking_intrinsics.yml
    Present /data/px4/param/parameters_gyro.cal
    Present /data/px4/param/parameters_acc.cal
    Present /data/px4/param/parameters_level.cal
    Present /data/px4/param/parameters_mag.cal
                PLEASE POWER CYCLE YOUR VOXL
    @tom ------------------------------------------------------------------
    Welcome to the voxl-configure-sku Wizard!
    VOXL currently thinks it is in the following hardware:
    family code: MRB-D0005 (starling)
    compute board: 4 (voxl2)
    hw version: 3
    cam config: 6
    SKU: MRB-D0005-4-V3-C6
    If this is what you want, select 1 (accept and continue) to
    leave it as-is. Otherwise, select the desired product family:
    1. accept and continue 10) seeker
    2. starling 11) rb5-flight
    3. sentinel 12) flight-deck
    4. fpv 13) voxl-deck
    5. D0010 14) voxl2-flight-deck
    6. px4-autonomy-dev-kit 15) voxl2-test-fixture
    7. stinger 16) voxl2-mini-test-fixture
    8. m500 17) voxl2-board-only
    9. voxlcam 18) voxl2-mini-board-only
      #? 2
      selected starling
    MRB-D0005 Starling currently has two versions in circulation.
    Version 2 with silver motors (pre December 2023)
    Version 3 with black motors (December 2023 onward)
    Please select the appropriate one.
    1. quit
    2. 2
    3. 3
      #? 3
    If you would like to select a special camera config that differs
    from the default for your product family, please select an option.
    Simply hit ENTER to use the default
    01 - ov7251 tracking ov7251 stereo
    02 - ov7251 tracking
    03 - ov7251 tracking ov7251 stereo imx214 hires
    04 - ov7251 tracking imx214 hires
    05 - pmd-tof ov7251 tracking
    06 - D0005 Starling pmd-tof imx214 hires ov7251 tracking
    08 - imx214
    09 - pmd-tof
    10 - ov7251 stereo
    11 - D0006 Sentinel
    12 - ov9782 stereo
    13 - ov9782 stereo imx214 hires
    14 - ov9782 stereo pmd-tof ov7251 tracking (copy)
    15 - D0008 dual 9782 tracking
    16 - pmd-tof ov7251 dual tracking imx214 hires
    17 - D0010 pmd-tof imx412 hires ov7251 tracking ov9782 stereo
    18 - D0008 triple ov9782
    19 - D0005 without tof imx214 hires ov7251 tracking
    20 - D0011 imx412 hires ar0144 tracking
    21 - old C6
    22 - D0013 imx412 flipped ov7251
    23 - D0010 without stereo
    C - use user-defined custom camera config in
    (/data/modalai/custom_camera_config.txt)
    q - Quit The Wizard
    The default camera config for Starling is
    6 (hires+TOF+tracking)
    selection:
    Selecting default camera config
    Your answers would construct the following SKU:
    hw version: 3
    cam config: 6
    This sku will be saved to persistent memory so VOXL
    will remember what it is installed in, even between
    system image flashes.
    Press enter to accept and continue.
    If something is wrong press ctrl-C to quit and try again.
    DONE, MRB-D0005-4-V3-C6 has been written to /data/modalai/sku.txt
    Next you will likely want to run voxl-configure-mpa
    voxl2:/$ voxl-configure-mpa
               Welcome to voxl-configure-mpa!
    VOXL is currently thinks it is in the following hardware:
    hw version: 3
    cam config: 6
    If this doesn't look right, quit and run voxl-configure-sku to
    set it correctly. Then run voxl-configure-mpa again.
    Continue? y/n: y
    Continuing
    About to Execute:
    voxl-configure-extrinsics starling_v2_voxl2
    voxl-configure-cameras 6
    voxl-configure-cpu-monitor factory_enable
    voxl-configure-qvio factory_enable_imu_apps
    voxl-configure-open-vins disable
    voxl-configure-dfs factory_disable
    voxl-configure-tag-detector factory_disable
    voxl-configure-tflite factory_disable
    voxl-configure-vision-hub factory_enable
    voxl-configure-mavlink-server factory_enable
    voxl-configure-portal enable
    voxl-configure-lepton disable
    voxl-configure-uvc disable
    voxl-configure-streamer factory_enable
    voxl-configure-modem disable
    voxl-configure-mavcam factory_enable
    voxl-configure-rangefinders disable
    voxl-configure-px4-imu-server factory_disable
    voxl-configure-imu factory_enable
    voxl-configure-flow-server disable
    voxl-configure-feature-tracker disable
    systemctl disable voxl-px4
    sleep 3
    voxl-esc setup_starling_black_motors
    voxl-elrs --scan
    sleep 1
    enabling voxl-wait-for-fs service
    executing: voxl-configure-extrinsics starling_v2_voxl2
    wiping old extrinsics config file
    copying /usr/share/modalai/extrinsic_configs/starling_v2_voxl2.conf to /etc/modalai/extrinsics.conf
    loading and updating file with voxl-inspect-extrinsics -q
    done configuring extrinsics
    Success!
    executing: voxl-configure-cameras 6
    Camera Configuration: 6
    camera server config helper list:
    tof:pmd-tof:0:
    hires:imx214:1:
    tracking:ov7251:2:
    driver binary list:
    /usr/share/modalai/chi-cdk/irs1645/com.qti.sensormodule.irs1645_0.bin
    /usr/share/modalai/chi-cdk/imx214/com.qti.sensormodule.imx214_2.bin
    /usr/share/modalai/chi-cdk/ov7251/com.qti.sensormodule.ov7251_3.bin
    calling camera-server-config-helper tof:pmd-tof:0: hires:imx214:1: tracking:ov7251:2:
    detected system image 1.7.4
    using new imx214 defaults
    successfully wrote this camera config to disk:
    configuration for 3 cameras:
    cam #0
    sensor type: pmd-tof
    isEnabled: 1
    camId: 0
    camId2: -1
    fps: 5
    en_rotate: 0
    en_rotate2: 0
    en_preview:          1
    pre_width:           224
    pre_height:          1557
    en_raw_preview:      1
    en_small_video:      0
    small_video_width:   -1
    small_video_height:  -1
    en_large_video:      0
    large_video_width:   -1
    large_video_height:  -1
    en_snapshot:         0
    snap_width:          -1
    snap_height:         -1
    ae_mode:             off
    standby_enabled:     0
    decimator:           5
    independent_exposure:0
    cam #1
    sensor type: imx214
    isEnabled: 1
    camId: 1
    camId2: -1
    fps: 30
    en_rotate: 0
    en_rotate2: 0
    en_preview:          0
    pre_width:           640
    pre_height:          480
    en_raw_preview:      0
    en_small_video:      1
    small_video_width:   1024
    small_video_height:  768
    en_large_video:      1
    large_video_width:   4208
    large_video_height:  3120
    en_snapshot:         1
    snap_width:          4208
    snap_height:         3120
    ae_mode:             isp
    standby_enabled:     0
    decimator:           1
    cam #2
    sensor type: ov7251
    isEnabled: 1
    camId: 2
    camId2: -1
    fps: 30
    en_rotate: 0
    en_rotate2: 0
    en_preview:          1
    pre_width:           640
    pre_height:          480
    en_raw_preview:      1
    en_small_video:      0
    en_large_video:      0
    en_snapshot:         0
    snap_width:          -1
    snap_height:         -1
    ae_mode:             lme_msv
    standby_enabled:     0
    decimator:           1
    camera_server_config_helper is done
    copying required camera drivers in place
    enabling voxl-camera-server
    Done Configuring Cameras
    Please power cycle VOXL to load new drivers
    camera server will start on next reboot
    Success!
    executing: voxl-configure-cpu-monitor factory_enable
    Creating new config file: /etc/modalai/voxl-cpu-monitor.conf
    enabling voxl-cpu-monitor systemd service
    Done configuring voxl-cpu-monitor
    Success!
    executing: voxl-configure-qvio factory_enable_imu_apps
    loading config file
    Creating new config file: /etc/modalai/voxl-qvio-server.conf
    enabling voxl-qvio-server systemd service
    Done configuring voxl-qvio-server
    Success!
    executing: voxl-configure-open-vins disable
    disabling voxl-open-vins-server systemd service
    stopping voxl-open-vins-server systemd service
    Done configuring voxl-open-vins-server
    Success!
    executing: voxl-configure-dfs factory_disable
    Creating new config file: /etc/modalai/voxl-dfs-server.conf
    disabling voxl-dfs-server systemd service
    Removed /etc/systemd/system/multi-user.target.wants/voxl-dfs-server.service.
    stopping voxl-dfs-server systemd service
    Done configuring voxl-dfs-server
    Success!
    executing: voxl-configure-tag-detector factory_disable
    Creating new config file: /etc/modalai/voxl-tag-detector.conf
    disabling voxl-tag-detector systemd service
    stopping voxl-tag-detector systemd service
    Done configuring voxl-tag-detector
    Success!
    executing: voxl-configure-tflite factory_disable
    Creating new config file: /etc/modalai/voxl-tflite-server.conf
    The config file was modified during parsing, saving the changes to disk
    disabling voxl-tflite-server systemd service
    Removed /etc/systemd/system/multi-user.target.wants/voxl-tflite-server.service.
    stopping voxl-tflite-server systemd service
    Done configuring voxl-tflite-server
    Success!
    executing: voxl-configure-vision-hub factory_enable
    Created new json file: /etc/modalai/voxl-vision-hub.conf
    The JSON config file data was modified during parsing, saving the changes to disk
    enabling voxl-vision-hub systemd service
    Done configuring voxl-vision-hub
    service will start on next reboot
    Success!
    executing: voxl-configure-mavlink-server factory_enable
    Created new json file: /etc/modalai/voxl-mavlink-server.conf
    enabling voxl-mavlink-server systemd service
    Done configuring voxl-mavlink-server
    Success!
    executing: voxl-configure-portal enable
    enabling voxl-portal systemd service
    Done configuring voxl-portal
    Success!
    executing: voxl-configure-lepton disable
    disabling voxl-lepton-server systemd service
    stopping voxl-lepton-server systemd service
    Done configuring voxl-lepton-server
    Success!
    executing: voxl-configure-uvc disable
    disabling voxl-uvc-server systemd service
    stopping voxl-uvc-server systemd service
    Done configuring voxl-uvc-server
    Success!
    executing: voxl-configure-streamer factory_enable
    Creating new config file: /etc/modalai/voxl-streamer.conf
    writing /etc/modalai/voxl-streamer.conf to disk
    parsed config file
    enabling voxl-streamer systemd service
    Done configuring voxl-streamer, it will start on next reboot
    Success!
    executing: voxl-configure-modem disable
    disabling voxl-modem systemd service
    stopping voxl-modem systemd service
    Done configuring voxl-modem
    Success!
    executing: voxl-configure-mavcam factory_enable
    Creating new config file: /etc/modalai/voxl-mavcam-manager.conf
    writing /etc/modalai/voxl-mavcam-manager.conf to disk
    enabling voxl-mavcam-manager systemd service
    Done configuring voxl-mavcam-manager
    It will start automatically on the next reboot
    Success!
    executing: voxl-configure-rangefinders disable
    disabling voxl-rangefinder-server systemd service
    Removed /etc/systemd/system/multi-user.target.wants/voxl-rangefinder-server.service.
    stopping voxl-rangefinder-server systemd service
    Done configuring voxl-rangefinder-server
    Success!
    executing: voxl-configure-px4-imu-server factory_disable
    disabling voxl-px4-imu-server systemd service
    stopping voxl-px4-imu-server systemd service
    Done configuring voxl-px4-imu-server
    Success!
    executing: voxl-configure-imu factory_enable
    Creating new config file: /etc/modalai/voxl-imu-server.conf
    enabling voxl-imu-server systemd service
    Done configuring voxl-imu-server
    Success!
    executing: voxl-configure-flow-server disable
    disabling voxl-flow-server systemd service
    stopping voxl-flow-server systemd service
    Done configuring voxl-flow-server
    Success!
    executing: voxl-configure-feature-tracker disable
    disabling voxl-feature-tracker systemd service
    stopping voxl-feature-tracker systemd service
    Done configuring voxl-feature-tracker
    Success!
    Success!
    executing: systemctl disable voxl-px4
    Success!
    executing: sleep 3
    Success!
    executing: voxl-esc setup_starling_black_motors
    enabling bridge
    bridge enabled
    [INFO] Setting CPU to performance mode
    [INFO] Scanning for ESC...
    dpkg-query: no packages found matching voxl-esc-board-detect.py
    dpkg-query: no packages found matching voxl-esc-calibrate.py
    dpkg-query: no packages found matching voxl-esc-led.py
    dpkg-query: no packages found matching voxl-esc-neopixel-test.py
    dpkg-query: no packages found matching voxl-esc-scan.py
    dpkg-query: no packages found matching voxl-esc-spin-helper.sh
    dpkg-query: no packages found matching voxl-esc-spin-sine.py
    dpkg-query: no packages found matching voxl-esc-spin-step.py
    dpkg-query: no packages found matching voxl-esc-spin.py
    dpkg-query: no packages found matching voxl-esc-tools-bin
    dpkg-query: no packages found matching voxl-esc-upload-firmware-all.sh
    dpkg-query: no packages found matching voxl-esc-upload-firmware.py
    dpkg-query: no packages found matching voxl-esc-upload-params.py
    dpkg-query: no packages found matching voxl-esc-verify-params.py
    dpkg-query: no packages found matching voxl_esc_setup_paths.py
    dpkg-query: no packages found matching voxl_serial.py
    [INFO] M0134-1 detected
    [INFO] has for most recent firmware: eb6fb500
    [INFO] Expected ESC firmware info:
    Firmware: modalai_esc_firmware_m0134_1_v0_39_RC10_eb6fb500.bin
    Firmware hash: eb6fb500
    [INFO] Number of ESCs with correct FW: 4
    [INFO] All of the ESCs have the correct firmware loaded
    uploading params file ../voxl-esc-params/starling_1504_3000kv/starling_1504_3000kv.xml
    [GCC 8.4.0]
    Found voxl-esc tools bin version: 1.6
    INFO: ESC(s) detected on port: /dev/slpi-uart-2, baud rate: 2000000, protocol: firmware
    INFO: ESC Information:
    Board : version 37: ModalAi 4-in-1 ESC (M0134-1)
    UID : 0x2033303852465719003E0056
    Firmware : version 39, hash eb6fb500
    Bootloader : version 183, hash b4fa2cf8
    UID        : 0x20333038524657190026004F
    UID        : 0x203330385246571900260049
    UID        : 0x2033303852465718001C002B
    successfully pinged ESCs
    [GCC 8.4.0]
    INFO: Params file name : ../voxl-esc-params/starling_1504_3000kv/starling_1504_3000kv.xml
    INFO: Params file size : 7602 bytes
    STILL SAME. WE THINK OUR TOF UNIT IS NOT WORKING. ITS DEAD ON ARRIVAL.
    @Eric-Katzfey . Yes, we have followed the same only. i think my TOF sensor is not activated. we are not getting any data of TOF sensors on the VOXL Webportal. Can you Guide me on How to activate it.
    following attached images are the data regarding drone.Screenshot (2).png Screenshot (3).png Screenshot (4).png Screenshot (5).png
    We have recently purchased Starling Autonomy Drone. We are Facing following Issue:
    No Proper Guide on How to fly the drone Using VOXL Mapper(in Modal AI VOXL Web Portal)
    How to do Slamming and Obstacle avoidance Flying?
    Please Guide us on How to use your Web portal to Fly it inside a room using Mapper
    We have installed voxl-Mapper and started the services, changed offboard mode to trajectory also. When we tell it to go to one location its moving also. But no point cloud map is been generated inside Mapper at Voxl Web portal. Please assist.!Screenshot (1).png
    1. No Proper Guide on How to fly the drone Using VOXL Mapper(in Modal AI VOXL Web Portal)
    2. How to do Slamming and Obstacle avoidance Flying?
    Please Guide us on How to use your Web portal to Fly it inside a room using Mapper.
  • Voxl 2 (implementation of tracking of moving object)
    Hello everyone,
    We are working on a project which requires following challenges:
    1.object tracking using Yolo v5 on python.(yolo have an inbuilt tracking facility using tflite)
    2. Along with object avoidance(6sides) and SLAM using path prediction.
    Our doubts are
    1. Can we use this voxl2 for the above requirements.
    2. If yes what will be the response time.(FPS rate)
    General Questions voxl2 yolov5
