Daniel RinconD
Daniel Rincon
@Daniel Rincon
  • Problem of overconsumption. HELP!
    Daniel RinconD Daniel Rincon
    Hi @Alex-Kushleyev ! Thank you very much for responding. Here is a diagram of how we use the cameras. Almost everything comes from the factory. I made some optimizations, such as ensuring that our mission manager does not consume or open a video consumption channel, but only consumes data, which has improved things, but I have not been able to significantly improve consumption and temperature issues. Sometimes the open vins reaches over 100% consumption and dies in the process (state -1), which is extremely risky for autonomous operation. I also noticed that it has a certain delay, which can lead to erroneous coordinates or erratic movements. I saw that you recommend a fan. Which one would you recommend? Do you sell them?
    I look forward to your comments and possible help, thank you very much.
    I am having a problem that I think is due to overconsumption. I created a manager that is responsible for orchestrating missions. For the first phase, I do an autonomous takeoff that relies on the use of OV. What happens is that I think that due to overconsumption, the VIO system starts to experience a delay or lag, and the drone starts to move erratically. It is also essential to use tflite for this. Since I analyze my own model, I see that the camera server has very high consumption. As you can see, I have left the camera server configuration below, but I have reduced almost everything to low resolution, except for the small one. I also see that open-vins is at 101%. What can I do to improve this and reduce the risk in missions?
     voxl-camera-server       |  Enabled  |   Running   |   157.6%
     voxl-cpu-monitor         |  Enabled  |   Running   |     0.0%
     voxl-dfs-server          | Disabled  | Not Running |
     voxl-elrs-startup        | Disabled  | Not Running |
     voxl-feature-tracker     | Disabled  | Not Running |
     voxl-flow-server         | Disabled  | Not Running |
     voxl-imu-server          |  Enabled  |   Running   |     3.4%
     voxl-joystick-server     | Disabled  | Not Running |
     voxl-lepton-tracker      | Disabled  | Not Running |
     voxl-logger              | Disabled  | Not Running |
     voxl-mapper              |  Enabled  |   Running   |    71.2%
     voxl-mavcam-manager      |  Enabled  |   Running   |     0.0%
     voxl-mavlink-server      |  Enabled  |   Running   |    11.9%
     voxl-mini-tof-server     | Disabled  | Not Running |
     voxl-mission-manager     | Disabled  | Not Running |
     voxl-modem-doodle        | Disabled  | Not Running |
     voxl-open-vins-server    |  Enabled  |   Running   |    96.6%
     voxl-osd                 | Disabled  | Not Running |
     voxl-portal              | Disabled  | Not Running |
     voxl-px4                 |  Enabled  |   Running   |    57.6%
     voxl-qvio-server         | Disabled  | Not Running |
     voxl-rangefinder-server  |  Enabled  |   Running   |     0.0%
     voxl-seek-server         | Disabled  | Not Running |
     voxl-softap              | Disabled  | Not Running |
     voxl-state-estimator     | Disabled  | Not Running |
     voxl-streamer            |  Enabled  |   Running   |     0.0%
     voxl-tag-detector        | Disabled  | Not Running |
     voxl-tflite-server       |  Enabled  |   Running   |   103.4%
     voxl-vision-hub          |  Enabled  |   Running   |    16.9%
     voxl-vrx                 | Disabled  | Not Running |
     voxl-vtx                 | Disabled  | Not Running |
    Name   Freq (MHz) Temp (C) Util (%)
    cpu0       1075.2     95.8    67.64
    cpu1       1075.2     95.4    56.92
    cpu2       1075.2     96.1    57.65
    cpu3       1075.2     96.1    57.65
    cpu4        710.4     96.5    28.77
    cpu5        710.4     97.3    28.15
    cpu6        710.4     96.1    27.91
    cpu7        844.8     96.1    24.68
    Total                 96.2    43.67
    10s avg                       47.49
    small cores only              59.96
    big cores only                27.38
    GPU         305.0     95.4     5.28
    GPU 10s avg                    4.84
    memory temp:       95.7 C
    memory used:  1781/7671 MB
    Flags
    CPU freq scaling mode: auto
    Standby Not Active
    CPU OVERHEAT WARNING
    	"version":	0.1,
    	"fsync_en":	true,
    	"fsync_gpio":	109,
    	"cameras":	[{
    			"type":	"ar0144",
    			"name":	"tracking_front",
    			"enabled":	true,
    			"camera_id":	0,
    			"fps":	30,
    			"en_rotate":	true,
    			"en_preview":	true,
    			"preview_width":	1280,
    			"preview_height":	800,
    			"en_raw_preview":	true,
    			"en_misp":	true,
    			"misp_width":	1280,
    			"misp_height":	800,
    			"misp_venc_enable":	true,
    			"misp_venc_mode":	"h265",
    			"misp_venc_br_ctrl":	"cbr",
    			"misp_venc_Qfixed":	38,
    			"misp_venc_Qmin":	15,
    			"misp_venc_Qmax":	50,
    			"misp_venc_nPframes":	29,
    			"misp_venc_mbps":	2,
    			"misp_venc_osd":	false,
    			"misp_awb":	"auto",
    			"misp_gamma":	1,
    			"ae_mode":	"lme_msv",
    			"gain_min":	54,
    			"gain_max":	8000,
    			"ae_desired_msv":	60,
    			"exposure_min_us":	20,
    			"exposure_max_us":	12000,
    			"exposure_soft_min_us":	5000,
    			"ae_filter_alpha":	0.600000023841858,
    			"ae_ignore_fraction":	0.20000000298023224,
    			"ae_slope":	0.05000000074505806,
    			"ae_exposure_period":	1,
    			"ae_gain_period":	1
    			"type":	"imx412",
    			"name":	"hires",
    			"enabled":	true,
    			"camera_id":	1,
    			"fps":	30,
    			"en_preview":	false,
    			"preview_width":	640,
    			"preview_height":	480,
    			"en_raw_preview":	false,
    			"en_small_video":	true,
    			"small_video_width":	1024,
    			"small_video_height":	768,
    			"small_venc_mode":	"h264",
    			"small_venc_br_ctrl":	"cqp",
    			"small_venc_Qfixed":	30,
    			"small_venc_Qmin":	15,
    			"small_venc_Qmax":	40,
    			"small_venc_nPframes":	9,
    			"small_venc_mbps":	2,
    			"small_venc_osd":	false,
    			"en_large_video":	false,
    			"large_video_width":	4056,
    			"large_video_height":	3040,
    			"large_venc_mode":	"h264",
    			"large_venc_br_ctrl":	"cqp",
    			"large_venc_Qfixed":	40,
    			"large_venc_Qmin":	15,
    			"large_venc_Qmax":	50,
    			"large_venc_nPframes":	29,
    			"large_venc_mbps":	40,
    			"large_venc_osd":	false,
    			"en_snapshot":	false,
    			"en_snapshot_width":	4056,
    			"en_snapshot_height":	3040,
    			"exif_focal_length":	3.0999999046325684,
    			"exif_focal_length_in_35mm_format":	17,
    			"exif_fnumber":	1.2400000095367432,
    			"snapshot_jpeg_quality":	75,
    			"ae_mode":	"isp",
    			"gain_min":	54,
    			"gain_max":	8000
    			"type":	"ar0144",
    			"name":	"tracking_rear",
    			"enabled":	true,
    			"camera_id":	2,
    			"fps":	30,
    			"en_rotate":	true,
    			"en_preview":	true,
    			"en_misp":	true,
    			"misp_width":	1280,
    			"misp_height":	800,
    			"misp_awb":	"auto",
    			"misp_gamma":	1,
    			"gain_min":	54,
    			"gain_max":	8000,
    			"ae_gain_period":	1
    			"type":	"pmd-tof-liow2",
    			"name":	"tof",
    			"enabled":	true,
    			"camera_id":	3,
    			"fps":	10,
    			"en_rotate":	true,
    			"ae_mode":	"off",
    			"gain_min":	0,
    			"gain_max":	0,
    			"exposure_max_us":	6000,
    			"standby_enabled":	false,
    			"decimator":	5
    			"type":	"ar0144",
    			"name":	"tracking_down",
    			"enabled":	true,
    			"camera_id":	4,
    			"fps":	30,
    			"en_rotate":	false,
    			"en_preview":	true,
    			"en_misp":	true,
    			"misp_width":	1280,
    			"misp_height":	800,
    			"misp_awb":	"auto",
    			"misp_gamma":	1,
    			"gain_min":	54,
    			"gain_max":	8000,
    			"ae_gain_period":	1
    I think it's due to overconsumption because when I deactivated the TFLite server, it took off normally. I tested this several times. But flying without TFLite is not an option since this is the main requirement.
  • Problem building voxl-Mapper on voxl cross
    Solved using SDK 1.4
    Hello! I am using voxl-cross version 4.4 and I am getting this error:
    make[2]: *** No rule to make target '/usr/lib64/libceres.so', needed by 'server/mav_path_smoothing/libmav_path_smoothing.so'.  Stop.
    make[1]: *** [CMakeFiles/Makefile2:385: server/mav_path_smoothing/CMakeFiles/mav_path_smoothing.dir/all] Error 2
    make[1]: *** Waiting for unfinished jobs....
    [ 44%] Built target voxblox_planning_common
    make: *** [Makefile:136: all] Error 2
    I have also tried building with 4.0 and nothing works. How can I fix this?
    I tried installing it with: apt install -y libceres-dev libeigen3-dev libgoogle-glog-dev libgflags-dev
    and it didn't work.
    It's for a Starling2. (VOXL2)
  • QVIO unstable flight. Please help!
    @zauberflote1 @tom Hi Zauber and Tom! I have done everything you have recommended, I updated to version 1.5.0 of the SDK, I also did a complete calibration of both the cameras and the IMU and the PX4, I have checked the extrinsics file and it seems correct, I leave all the information I have right now. But I have not been able to get the drone to fly in a stable way, when taking off you get an extremely unstable flight, in which it can start to go up or down or move to the sides, this is extremely dangerous for a critical operation and in an indoor place, because generally there is not much margin for error, I need to solve this urgently! if you need something else let me know!
    kernel:       #1 SMP PREEMPT Mon Mar 24 22:31:58 UTC 2025 4.19.125
    hw platform:  M0054
    mach.var:     1.0.1
    SKU:          MRB-D0014-4-V1-C27-T7-M22-X0
    voxl-suite:   1.5.0
    Packages:
    Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.5/binary-arm64/
    Last Updated: 2025-07-28 15:33:25
    List:
    libfc-sensor                1.0.7
    libmodal-cv                 0.5.18
    libmodal-exposure           0.1.4
    libmodal-journal            0.2.6
    libmodal-json               0.4.7
    libmodal-pipe               2.13.2
    libqrb5165-io               0.5.0
    libvoxl-cci-direct          0.3.3
    libvoxl-cutils              0.1.5
    modalai-slpi                1.2.0
    mv-voxl                     0.1-r0
    qrb5165-bind                0.1-r0
    qrb5165-dfs-server          0.2.0
    qrb5165-imu-server          1.1.3
    qrb5165-mini-tof-server     0.2.2
    qrb5165-rangefinder-server  0.1.5
    qrb5165-slpi-test-sig       01-r0
    qrb5165-system-tweaks       0.3.6
    qrb5165-tflite              2.8.0-2
    voxl-bind-spektrum          0.1.1
    voxl-camera-calibration     0.6.0
    voxl-camera-server          2.2.4
    voxl-ceres-solver           2:1.14.0-10
    voxl-configurator           1.0.2
    voxl-cpu-monitor            0.6.0
    voxl-docker-support         1.3.1
    voxl-elrs                   0.4.7
    voxl-esc                    1.5.4
    voxl-feature-tracker        0.5.2
    voxl-flow-server            0.3.6
    voxl-gphoto2-server         0.0.10
    voxl-joystick-server        0.0.6
    voxl-jpeg-turbo             2.1.3-7
    voxl-lepton-server          1.3.3
    voxl-lepton-tracker         0.0.4
    voxl-libgphoto2             0.0.4
    voxl-libuvc                 1.0.7
    voxl-logger                 0.5.3
    voxl-mavcam-manager         0.6.0
    voxl-mavlink                0.1.5
    voxl-mavlink-server         1.4.9
    voxl-modem                  1.1.8
    voxl-mongoose               7.7.0-2
    voxl-mpa-to-ros             0.3.9
    voxl-mpa-tools              1.4.0
    voxl-open-vins              0.4.19
    voxl-open-vins-server       0.3.12
    voxl-opencv                 4.5.5-3
    voxl-osd                    0.1.8
    voxl-portal                 0.7.11
    voxl-px4                    1.14.0-2.0.105
    voxl-px4-params             0.7.5
    voxl-qvio-server            1.2.0
    voxl-remote-id              0.0.9
    voxl-reset-slpi             0.0.1
    voxl-state-estimator        0.0.5
    voxl-streamer               0.7.5
    voxl-suite                  1.5.0
    voxl-tag-detector           0.0.5
    voxl-tflite-server          0.4.1
    voxl-utils                  1.4.8
    voxl-uvc-server             0.1.7
    voxl-vision-hub             1.8.23
    voxl-vtx                    1.4.7
    voxl-wavemux                0.0.1
    voxl2-io                    0.0.3
    voxl2-system-image          1.8.04-r0
    voxl2-wlan                  1.0-r0
    	"name":	"D0014_Starling_2",
    	"extrinsics": [{
    			"parent": "imu_apps",
    			"child":  "tracking_front",
    			"T_child_wrt_parent": [0.037, 0.000, 0.0006],
    			"RPY_parent_to_child":    [0, 90, 90]
    			"child":  "tracking_down",
    			"T_child_wrt_parent": [-0.08825, -0.0045, 0.0269],
    			"RPY_parent_to_child":    [0, 0, 180]
    			"child":  "tracking_rear",
    			"T_child_wrt_parent": [-0.092, 0.016, 0.0036],
    			"RPY_parent_to_child":    [0, -90, -90]
    			"child":  "hires",
    			"T_child_wrt_parent": [0.0388, 0.0, 0.0186],
    			"parent": "body",
    			"child":  "imu_apps",
    			"T_child_wrt_parent": [0.0295, -0.0065, -0.016],
    			"RPY_parent_to_child":    [0, 0, 0]
    			"parent": "body",
    			"child":  "imu_px4",
    			"T_child_wrt_parent": [0.0043, 0.0073, -0.0163],
    			"child":	"lepton0_raw",
    			"T_child_wrt_parent":	[-0.0846, 0.0128, 0.0242],
    			"RPY_parent_to_child":	[0, 0, 90]
    			"parent": "body",
    			"child":  "tof",
    			"T_child_wrt_parent": [0.066, 0.009, -0.012],
    			"RPY_parent_to_child":    [0, 90, 180]
    			"parent": "body",
    			"child":  "ground",
    			"T_child_wrt_parent": [0, 0, 0.033],
    cat opencv_tracking_front_intrinsics.yml
    %YAML:1.0
    M: !!opencv-matrix
       rows: 3
       cols: 3
       dt: d
       data: [ 4.5714170737476474e+02, 0., 6.5910963154859280e+02, 0.,
           4.5792960641409849e+02, 4.0038966931029148e+02, 0., 0., 1. ]
    D: !!opencv-matrix
       rows: 4
       cols: 1
       dt: d
       data: [ 6.2012870824903796e-02, 1.6259845524556362e-02,
           -4.2354944524998885e-03, -1.5471587475499430e-03 ]
    reprojection_error: 4.5942149808142413e-01
    width: 1280
    height: 800
    distortion_model: fisheye
    calibration_time: "2025-07-28 22:53:47"
    cat opencv_tracking_rear_intrinsics.yml
    %YAML:1.0
    M: !!opencv-matrix
       rows: 3
       cols: 3
       dt: d
       data: [ 4.8912456448648203e+02, 0., 6.4281111886295446e+02, 0.,
           4.8904789191290672e+02, 4.0021905849311702e+02, 0., 0., 1. ]
    D: !!opencv-matrix
       rows: 4
       cols: 1
       dt: d
       data: [ 3.7700429553275704e-02, -6.3619256403005392e-03,
           2.4382411049586192e-02, -1.2672813614381549e-02 ]
    reprojection_error: 4.1466991560546473e-01
    width: 1280
    height: 800
    calibration_time: "2025-07-28 22:57:03"
    cat opencv_tracking_down_intrinsics.yml
    %YAML:1.0
    M: !!opencv-matrix
       rows: 3
       cols: 3
       dt: d
       data: [ 4.6086004584403508e+02, 0., 6.4051075130106608e+02, 0.,
           4.6096052455716375e+02, 4.2617760618350911e+02, 0., 0., 1. ]
    D: !!opencv-matrix
       rows: 4
       cols: 1
       dt: d
       data: [ 7.2849347738052822e-02, -2.3660438800073867e-02,
           4.1302387135490337e-02, -1.7560990900256007e-02 ]
    reprojection_error: 5.1837524215838549e-01
    width: 1280
    height: 800
    calibration_time: "2025-07-28 23:08:04"
    	"config_file_version":	1,
    	"en_localhost_mavlink_udp":	true,
    	"localhost_udp_port_number":	14551,
    	"en_vio":	true,
    	"vio_pipe":	"ov",
    	"secondary_vio_pipe":	"qvio",
    	"vfc_vio_pipe":	"ov",
    	"en_reset_vio_if_initialized_inverted":	true,
    	"vio_warmup_s":	3,
    	"send_odom_while_failed":	true,
    	"horizon_cal_tolerance":	0.5,
    	"en_hitl":	false,
    	"offboard_mode":	"figure_eight",
    	"follow_tag_id":	0,
    	"figure_eight_move_home":	true,
    	"robot_radius":	0.300000011920929,
    	"collision_sampling_dt":	0.1,
    	"max_lookahead_distance":	1,
    	"backtrack_seconds":	60,
    	"backtrack_rc_chan":	8,
    	"backtrack_rc_thresh":	1500,
    	"wps_move_home":	true,
    	"wps_stride":	0,
    	"wps_timeout":	0,
    	"wps_damp":	1,
    	"wps_vfc_mission":	true,
    	"wps_vfc_mission_loop":	false,
    	"wps_vfc_mission_to_ramp":	25,
    	"wps_vfc_mission_to_kp":	0.10000000149011612,
    	"wps_vfc_mission_cruise_speed":	1,
    	"en_tag_fixed_frame":	false,
    	"fixed_frame_filter_len":	5,
    	"en_transform_mavlink_pos_setpoints_from_fixed_frame":	false,
    	"vfc_rate":	100,
    	"vfc_rc_chan_min":	980,
    	"vfc_rc_chan_max":	2020,
    	"vfc_thrust_ch":	3,
    	"vfc_roll_ch":	1,
    	"vfc_pitch_ch":	2,
    	"vfc_yaw_ch":	4,
    	"vfc_submode_ch":	6,
    	"vfc_alt_mode_rc_min":	0,
    	"vfc_alt_mode_rc_max":	0,
    	"vfc_flow_mode_rc_min":	0,
    	"vfc_flow_mode_rc_max":	0,
    	"vfc_hybrid_flow_mode_rc_min":	0,
    	"vfc_hybrid_flow_mode_rc_max":	0,
    	"vfc_position_mode_rc_min":	0,
    	"vfc_position_mode_rc_max":	2100,
    	"vfc_traj_mode_rc_min":	0,
    	"vfc_traj_mode_rc_max":	0,
    	"vfc_yaw_deadband":	30,
    	"vfc_vxy_deadband":	50,
    	"vfc_vz_deadband":	150,
    	"vfc_min_thrust":	0,
    	"vfc_max_thrust":	0.800000011920929,
    	"vfc_tilt_max":	0.43599998950958252,
    	"vfc_yaw_rate_max":	3,
    	"vfc_thrust_hover":	0.5,
    	"vfc_vz_max":	1,
    	"vfc_kp_z":	5.2899999618530273,
    	"vfc_kd_z":	5.9800000190734863,
    	"vfc_vxy_max":	3,
    	"vfc_kp_xy":	0.63999998569488525,
    	"vfc_kd_xy":	2.559999942779541,
    	"vfc_kp_z_vio":	5.2899999618530273,
    	"vfc_kd_z_vio":	5.9800000190734863,
    	"vfc_kp_xy_vio":	3.2400000095367432,
    	"vfc_kd_xy_vio":	3.9600000381469727,
    	"vfc_w_filt_xy_vio":	10,
    	"vfc_w_filt_xy_flow":	3,
    	"vfc_vel_ff_factor_vio":	0.899999976158142,
    	"vfc_xy_acc_limit_vio":	2.5,
    	"vfc_max_z_delta":	3,
    	"vfc_att_transition_time":	0.5,
    	"vfc_stick_move_threshold":	30,
    	"vfc_flow_transition_time":	1,
    	"vfc_q_min":	10,
    	"vfc_points_min":	7,
    	"vfc_en_submode_announcement":	1,
    	"vfc_disable_fallback":	false,
    	"vfc_traj_csv":	"/data/voxl-vision-hub/traj.csv",
    	"en_voa":	true,
    	"voa_upper_bound_m":	-0.15000000596046448,
    	"voa_lower_bound_m":	0.15000000596046448,
    	"voa_voa_memory_s":	1,
    	"voa_max_pc_per_fusion":	100,
    	"voa_pie_max_dist_m":	20,
    	"voa_pie_min_dist_m":	0.25,
    	"voa_pie_under_trim_m":	1,
    	"voa_pie_threshold":	3,
    	"voa_send_rate_hz":	20,
    	"voa_pie_slices":	36,
    	"voa_pie_bin_depth_m":	0.15000000596046448,
    	"voa_inputs":	[{
    			"enabled":	true,
    			"type":	"point_cloud",
    			"input_pipe":	"dfs_point_cloud",
    			"frame":	"stereo_l",
    			"max_depth":	8,
    			"min_depth":	0.300000011920929,
    			"cell_size":	0.079999998211860657,
    			"threshold":	4,
    			"x_fov_deg":	68,
    			"y_fov_deg":	56,
    			"conf_cutoff":	0
    			"enabled":	true,
    			"input_pipe":	"stereo_front_pc",
    			"frame":	"stereo_front_l",
    			"max_depth":	8,
    			"threshold":	4,
    			"x_fov_deg":	68,
    			"y_fov_deg":	56,
    			"conf_cutoff":	0
    			"enabled":	true,
    			"input_pipe":	"stereo_rear_pc",
    			"frame":	"stereo_rear_l",
    			"max_depth":	8,
    			"threshold":	4,
    			"x_fov_deg":	68,
    			"y_fov_deg":	56,
    			"conf_cutoff":	0
    			"enabled":	true,
    			"type":	"tof",
    			"input_pipe":	"tof",
    			"frame":	"tof",
    			"max_depth":	6,
    			"min_depth":	0.15000000596046448,
    			"threshold":	3,
    			"x_fov_deg":	106.5,
    			"y_fov_deg":	85.0999984741211,
    			"conf_cutoff":	125
    			"enabled":	true,
    			"type":	"rangefinder",
    			"input_pipe":	"rangefinders",
    			"frame":	"body",
    			"max_depth":	8,
    			"threshold":	4,
    			"x_fov_deg":	68,
    			"y_fov_deg":	56,
    			"conf_cutoff":	0
    to finish I have also observed that at the time of take off the points are not fixed before take off, if not just when the drone is armed, I am sometimes results in a mismatch, for example in the image that I show below, I only armed the drone, there if the points appeared, but as I left the drone only armed (not lift it) I could see that the position of the drone began to go negative infinititamente, when not even the drone was moving.
    @tom Thanks Tom, I will wait to see if someone else joins, as this has blocked our development, thank you very much.
    @tom Hello Tom! Yes, I understand this, but which one is more accurate? which one should I decide on in an Indoor environment? we have the Starling 2 triple tracking.
    Can you help me by answering the other questions? or is there someone in the ModalAI team who can help me?
    I have left all my settings there, and as you can see QVIO is set as the main VIO.
    Hello! very good morning! I am trying to develop a safe and efficient solution to control the drone in a simple way, the idea is to manage the drone through actions with the Mavlink server (I already have it, I can take off the drone from QGC) the problem is to get stability, the drone flies most of the time in an unstable way, i have configured the voxl-vision-hub with qvio, and i have also tried with ov, but in none of the two is stable, i take off the drone in position mode and what it does most of the times is not to keep its position, but to start flying uncontrolled, upwards or sideways.
    As you know this is totally inefficient and not applicable to the need I have, since basically the main thing is a safe and stable flight.
    I would like you to help me first to understand the difference between QVIO, VIO and OV (I have not seen anything in the documentation that explains well the difference between these three).
    And secondly to see if you can help me to be able to give the necessary configuration to be able to obtain a safe accuracy.
    I am going to leave you the configurations I have and the tests I have done.
    kernel:       #1 SMP PREEMPT Mon Nov 11 22:47:44 UTC 2024 4.19.125
    hw platform:  M0054
    mach.var:     1.0.1
    voxl-suite:   1.4.5
    Packages:
    Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.4/binary-arm64/
    Last Updated: 2025-07-16 21:35:53
    List:
    libfc-sensor                              1.0.7
    libmodal-cv                               0.5.18
    libmodal-journal                          0.2.5
    libmodal-json                             0.4.7
    libmodal-pipe                             2.13.1
    libqrb5165-io                             0.5.0
    libvoxl-cci-direct                        0.3.2
    modalai-slpi                              1.1.20
    qrb5165-system-tweaks                     0.3.5
    voxl-camera-calibration                   0.5.9
    voxl-camera-server                        2.2.1
    voxl-configurator                         1.0.1
    voxl-elrs                                 0.4.7
    voxl-esc                                  1.5.2
    voxl-io-server                            0.0.5
    voxl-logger                               0.5.3
    voxl-mapper                               0.2.4
    voxl-mavcam-manager                       0.5.8
    voxl-mavlink                              0.1.5
    voxl-mavlink-server                       1.4.7
    voxl-mission-manager                      1.0.6
    voxl-modem                                1.1.6
    voxl-nlopt                                2.5.0-4
    voxl-opencv                               4.5.5-3
    voxl-osd                                  0.1.7
    voxl-portal                               0.7.10
    voxl-px4                                  1.14.0-2.0.98
    voxl-px4-params                           0.7.3
    voxl-streamer                             0.7.5
    voxl-suite                                1.4.5
    voxl-tag-detector                         0.0.4
    voxl-tflite-server                        0.4.4
    voxl-utils                                1.4.7
    voxl-vision-hub                           1.8.21
    voxl-voxblox                              1.1.5
    voxl-vtx                                  1.3.14
    voxl-wavemux                              0.0.1
    voxl2-io                                  0.0.3
    voxl2-system-image                        1.8.02-r0
     voxl-camera-server       |  Enabled  |   Running   |    67.9%
     voxl-imu-server          |  Enabled  |   Running   |     1.8%
     voxl-io-server           | Disabled  | Not Running |
     voxl-mapper              |  Enabled  |   Running   |    53.6%
     voxl-mavlink-server      |  Enabled  |   Running   |     5.4%
     voxl-mission-manager     |  Enabled  | Not Running |
     voxl-open-vins-server    |  Enabled  |   Running   |    98.2%
     voxl-px4-imu-server      |  Enabled  |   Running   |     1.8%
     voxl-px4                 |  Enabled  |   Running   |    28.6%
     voxl-qvio-server         |  Enabled  |   Running   |    37.5%
     voxl-rangefinder-server  |  Enabled  |   Running   |     1.8%
     voxl-tflite-server       |  Enabled  |   Running   |     0.0%
     voxl-vision-hub          |  Enabled  |   Running   |     8.9%
    	"en_vio":	true,
    	"vio_pipe":	"qvio",
    	"secondary_vio_pipe":	"ov",
    	"vio_warmup_s":	3,
    	"en_hitl":	false,
    	"offboard_mode":	"trajectory",
    	"follow_tag_id":	0,
    	"wps_stride":	0,
    	"wps_timeout":	0,
    	"wps_damp":	1,
    	"vfc_rate":	100,
    	"vfc_thrust_ch":	3,
    	"vfc_roll_ch":	1,
    	"vfc_pitch_ch":	2,
    	"vfc_yaw_ch":	4,
    	"vfc_vz_max":	1,
    	"vfc_vxy_max":	3,
    	"vfc_q_min":	10,
    	"en_voa":	true,
    	"voa_inputs":	[{
    			"enabled":	true,
    			"max_depth":	8,
    			"threshold":	4,
    			"x_fov_deg":	68,
    			"y_fov_deg":	56,
    			"conf_cutoff":	0
    			"enabled":	true,
    			"max_depth":	8,
    			"threshold":	4,
    			"x_fov_deg":	68,
    			"y_fov_deg":	56,
    			"conf_cutoff":	0
    			"enabled":	true,
    			"max_depth":	8,
    			"threshold":	4,
    			"x_fov_deg":	68,
    			"y_fov_deg":	56,
    			"conf_cutoff":	0
    			"enabled":	true,
    			"type":	"tof",
    			"frame":	"tof",
    			"max_depth":	6,
    			"threshold":	3,
    			"x_fov_deg":	106.5,
    			"conf_cutoff":	125
    			"enabled":	true,
    			"frame":	"body",
    			"max_depth":	8,
    			"threshold":	4,
    			"x_fov_deg":	68,
    			"y_fov_deg":	56,
    			"conf_cutoff":	0
    	"odr_hz":	30,
    	"use_camera_height_bootstrap":	true,
    	"camera_height_off_ground_m":	0.085000000894069672,
    	"enable_init_while_moving":	false,
    	"cam_imu_timeshift_s":	0,
    	"cam_imu_timeshift_s_uncertainty":	9.99999974737875e-05,
    	"T_cam_wrt_imu_uncertainty":	[0.00050000002374872565, 0.00050000002374872565, 0.00050000002374872565],
    	"R_cam_to_imu_uncertainty":	[0.00499999988824129, 0.00499999988824129, 0.00499999988824129],
    	"accl_fsr_ms2":	156,
    	"gyro_fsr_rad":	34,
    	"accl_noise_std_dev":	0.31600001454353333,
    	"gyro_noise_std_dev":	0.00999999977648258,
    	"cam_noise_std_dev":	100,
    	"min_std_pixel_noise":	0.5,
    	"fail_high_pixel_noise_points":	1.6650999784469604,
    	"limited_imu_bw_trigger":	25,
    	"gps_imu_time_alignment_s":	0,
    	"T_gps_wrt_imu":	[0, 0, 0],
    	"enable_mapping":	true,
    	"enable_gps_vel":	false,
    	"en_auto_reset":	true,
    	"auto_reset_max_velocity":	10,
    	"auto_reset_max_v_cov_instant":	0.10000000149011612,
    	"auto_reset_max_v_cov":	0.00999999977648258,
    	"auto_reset_max_v_cov_timeout_s":	0.5,
    	"auto_reset_min_features":	3,
    	"auto_reset_min_feature_timeout_s":	1,
    	"en_standby_mode":	true,
    	"standby_skip_frames":	1,
    	"mask_file_path":	""
    finally I share with you the tests I have done:
    1. take off the drone in the place where I connect the battery (failure)
    2. move the drone manually until I saw that the z-axis coincided more or less with the movement it made, position the drone at 0, and take off (here I got more stability)
    3. reset qvio and ov, after powering up the drone, the qvio was accurate but the ov was moving crazily on the plane when static (failure)
    here are some images of the inconsistencies between qvio and ov
    thank you very much in advance, and sorry if the thread is too big!
  • Cant use Mavsdk! please Help!
    @Eric-Katzfey Hey Eric! I finally solved the problem by setting these variables:
    RC=EXTERNAL in voxl-px4.conf
    and
    px4-param set COM_RC_IN_MODE 0
    px4-param set COM_RC_OVERRIDE 1
    px4-param set COM_ARM_WO_GPS 1
    px4-param set COM_RC_LOSS_T 30.0
    This way I was able to make the takeoff autonomous, and also to have manual control for safety.
    Now the problem I have is about the qvio, in several situations (most) ends up being very unstable, it makes erratic movements, like going much higher than the takeoff, as I see it seems something of decalibration, but how to standardize this to work well always, because the qvio so unstable is dangerous, what do you recommend me? or should I make a new thread for this question?
    thanks in advance!
    @Eric-Katzfey Hi Erick! thanks for answering, yes my drone has GPS, we bought the Starling 2 with the most powerful construction (MRB-D0014-4-C27-M0-T0-K3), anyway, our flights will be indoor, although the tests I'm doing them from my studio, that despite being in a building, should get gps, I say this because I compare it with a Mavic 2 that if you get GPS right here, in the plotter of the portal I see activity but strangely says gps: 0, do you require to show you something specifically?
    Because this has stopped our development I was thinking about turning it around to Mavros, to see if I get a different result.
    The Workflow I have proposed is:
    voxl-mission-manager (our service) -> sends takeoff and puts the drone in hold state sends waypoints -> mapper extended to receive waypoints instead of a plan to a point -> runs mission -> in turn the manager monitors the mission and at certain waypoints activates and deactivates the tflite server -> when the mission ends it runs RTL from Mapper -> manager activates precise landing with Apriltags.
    all this we want to do autonomously, from takeoff to landing, is it possible or too ambitious?
    thanks for your answers!
  • YoloV8 Custom problem
    @Alex-Kushleyev Hey Alex, thanks for your reply, I managed to run the model by adding a specific helper, also converting my model several times to achieve the necessary parameters, the only problem I have now is performance, it runs at about 5fps, it is trained with yolovo8M, I think that may be a factor.
    when I use the mavsdk-docker example it just stays here:
    voxl2:~$ docker run -it --rm --privileged --net=host --ipc=host voxl-mavsdk:v1.2
    root@m0054:/home# ./voxl2_takeoff_land.py
    Waiting for the drone to connect...
    Drone connected!
    Waiting for the drone to have a global position estimation....
    it does nothing else, these are my configurations
    "en_vio": true,
    "vio_pipe": "qvio",
    "vio_warmup_s": 3,
    "en_hitl": false,
    "follow_tag_id": 0,
    i also made my own service that communicates with the docker-mavsdk to be able to send waypoints to the mapper (extend the plan to a point) and trigger commands to the tflite server between waypoints. but it does not work mainly because I have not been able to send instructions successfully to docker-mavsdk, from qgcontrol when I give arm I get this: MAV_CMD_COMPONENT_ARM_DISARM command temporarily rejected... this has me very blocked because I need to build this solution for a precision application.
    please help!
    we have a model trained in YoloV8, starting from Yolo8M, we did all the conversion process according to the documentation, starting from an ONNX, we did everything following the documentation but at the time of running the model we get this:
    Jul 09 18:41:59 m0054 bash[4052]: Fault thread: voxl-tflite-ser(tid: 6348)
    Jul 09 18:41:59 m0054 bash[4052]: Fault address: (nil)
    Jul 09 18:41:59 m0054 bash[4052]: Unknown reason.
    Jul 09 18:41:59 m0054 systemd[1]: voxl-tflite-server.service: Main process exited, code=killed, status=11/SEGV
    Jul 09 18:41:59 m0054 systemd[1]: voxl-tflite-server.service: Failed with result 'signal'.
    Jul 09 18:41:59 m0054 systemd[1]: voxl-tflite-server.service: Service hold-off time over, scheduling restart.
    Jul 09 18:41:59 m0054 systemd[1]: voxl-tflite-server.service: Scheduled restart job, restart counter is at 53.
    Jul 09 18:41:59 m0054 systemd[1]: Stopped voxl-tflite-server.
    Jul 09 18:41:59 m0054 systemd[1]: Started voxl-tflite-server.
    Jul 09 18:42:00 m0054 bash[6590]: INFO: Created TensorFlow Lite delegate for GPU.
    Jul 09 18:42:12 m0054 bash[6590]: INFO: Initialized OpenCL-based API.
    Jul 09 18:42:12 m0054 bash[6590]: INFO: Created 1 GPU delegate kernels.
    Jul 09 18:42:12 m0054 bash[6590]: ------VOXL TFLite Server------
    Jul 09 18:42:12 m0054 bash[6590]: Segmentation fault:
    Jul 09 18:42:12 m0054 bash[6590]: Fault thread: voxl-tflite-ser(tid: 8954)
    Jul 09 18:42:12 m0054 bash[6590]: Fault address: (nil)
    Jul 09 18:42:12 m0054 bash[6590]: Unknown reason.
    Jul 09 18:42:12 m0054 systemd[1]: voxl-tflite-server.service: Main process exited, code=killed, status=11/SEGV
    Jul 09 18:42:12 m0054 systemd[1]: voxl-tflite-server.service: Failed with result 'signal'.
    Jul 09 18:42:12 m0054 systemd[1]: voxl-tflite-server.service: Service hold-off time over, scheduling restart.
    Jul 09 18:42:12 m0054 systemd[1]: voxl-tflite-server.service: Scheduled restart job, restart counter is at 54.
    Jul 09 18:42:12 m0054 systemd[1]: Stopped voxl-tflite-server.
    Jul 09 18:42:12 m0054 systemd[1]: Started voxl-tflite-server.
    Jul 09 18:42:13 m0054 bash[9299]: INFO: Created TensorFlow Lite delegate for GPU.
    Jul 09 18:42:24 m0054 bash[9299]: INFO: Initialized OpenCL-based API.
    Jul 09 18:42:24 m0054 bash[9299]: INFO: Created 1 GPU delegate kernels.
    we have tried with the quantification proposed in the documentation and nothing, we are stuck with this, what can we do?
    voxl-suite: 1.4.5
    p.s. we also found an error in the voxl-configure-tfliteserver code, where this was shown when setting the custom model: set_param_bool expected 2 args, we corrected it this way: set_param_bool requires_labels true
  • Starling 2 Addons and more
    Hi! I am trying to adapt Starling 2 to the operations I have with my clients.
    For this I need to know first if the front camera is a camera that is used for the obstacle avoidance system and VIO, or if it is just a RGB camera that I can point downwards, so that I can run my own models on this camera, of course without affecting the obstacle avoidance system.
    If not, can I put an additional camera pointing downwards, so I can run my own YOLO model on it?
    I also need to know if I can put two lidars or ragefinders to be able to know the precise height up and down of the drone.
    Finally, I also need to protect the drone from the conditions in which it operates, can I build a case to wrap all the electronics, besides that, protect it from humidity and other factors, is this possible, is there a case I can buy for this?
    The idea is to be able to have a final product, adapting this great drone for these needs.
