Hello, I just updated the system image to version 3 beta. And I accidentally erased the data partition on the voxl. Is it possible to get image of original data partition from the factory, the original that I got when I bought flight deck like all the pre-configuration files which were present in the data partition and also any other files necessary that comes included in untouched flight deck.
Posts made by abdullah.sorathi
Acidentaly deleted parttionposted in Ask your questions right here!
RE: Failed to start Stereo Camera Nodeletposted in Ask your questions right here!
@Chad-Sweet
Yes I tried both setting it to true and false. But once you start launch camera and the terminated and try to launch again it does not launch. -
@modaltb
I am using voxl-flight deck
cameras are same that comes with flight deck-> stereo camera, hires and optical flow cameraThis is the voxl version currently in use in my setup
yocto:/# voxl-version -------------------------------------------------------------------------------- system-image: ModalAI 2.5.2 BUILDER: ekatzfey BUILD_TIME: 2020-08-24_00:08 kernel: #1 SMP PREEMPT Wed Sep 9 22:28:09 UTC 2020 3.18.71-perf factory-bundle: 1.0.1 -------------------------------------------------------------------------------- architecture: aarch64 processor: apq8096 os: GNU/Linux -------------------------------------------------------------------------------- voxl-suite: Package: voxl-suite Version: 0.2.0 Depends: docker, imu_app (= 0.0.6), libvoxl_io (= 0.5.2), voxl-cam-manager (= 0.2.2), voxl-docker-support (= 1.1.1), voxl-hal3-tof-cam-ros (= 0.0.2), voxl-modem (= 0.10.0), voxl-nodes (= 0.0.8), voxl-rtsp (= 1.0.2), voxl-utils (= 0.5.2), voxl-vision-px4 (= 0.6.8), voxl_imu (= 0.0.4), voxl-time-sync (= 0.0.1), voxl-vpn (= 0.0.2), librc_math (= 1.1.2), libmodal_pipe (= 1.2.2), modalai-vl (= 0.1.3) Status: install user installed Section: base Architecture: armv7a Maintainer: james@modalai.com MD5Sum: af706cd3c1ea59f274f2ed9b93141f1d Size: 870 Filename: voxl-suite_0.2.0.ipk Description: meta-package to install all of the voxl-suite Installed-Time: 4024 -------------------------------------------------------------------------------- yocto:/#I am currently working with SNAV and followed this [https://docs.modalai.com/snapdragon-navigator/]
RE: rodep ssl errorposted in Ask your questions right here!
I was trying to rosdep update on some custom packages. But then ended up adding source directly to the workspace.
I get this error every other time. for the first launch it executed perfectly but subsequent lanches throw error. Basically if it run perfectly and if i interrupt it by pressing ctrl + c and than run again it starts saying could not load nodelet. And many a time it says could not open camera ID = 2. Unable to open camera.
yocto:/# roslaunch voxl_cam_ros stereo.launch ... logging to /home/root/.ros/log/a0237ab4-4d5a-11eb-9155-ec5c68cd1745/roslaunch-apq8096-4987.log Checking log directory for disk usage. This may take awhile. Press Ctrl-C to interrupt Done checking log file disk usage. Usage is <1GB. started roslaunch server http://10.42.0.157:48704/ SUMMARY ======== PARAMETERS * /rosdistro: indigo * /rosversion: 1.11.21 * /stereo/stereo_cam_nodelet/cam_id: 2 * /stereo/stereo_cam_nodelet/cam_name: stereo * /stereo/stereo_cam_nodelet/format: 1 * /stereo/stereo_cam_nodelet/frame_id: left_stereo * /stereo/stereo_cam_nodelet/frame_id_right: right_stereo * /stereo/stereo_cam_nodelet/frame_rate: 15 * /stereo/stereo_cam_nodelet/height: 480 * /stereo/stereo_cam_nodelet/is_cam_master: True * /stereo/stereo_cam_nodelet/is_stereo: True * /stereo/stereo_cam_nodelet/skip_n_frames: 0 * /stereo/stereo_cam_nodelet/width: 640 NODES /stereo/ stereo_cam_nodelet (nodelet/nodelet) stereo_nodelet_manager (nodelet/nodelet) auto-starting new master process[master]: started with pid [5006] ROS_MASTER_URI=http://localhost:11311/ setting /run_id to a0237ab4-4d5a-11eb-9155-ec5c68cd1745 process[rosout-1]: started with pid [5020] started core service [/rosout] process[stereo/stereo_nodelet_manager-2]: started with pid [5036] process[stereo/stereo_cam_nodelet-3]: started with pid [5038] [ INFO] [1609633720.545179265]: Initializing nodelet with 4 worker threads. [ INFO] [1609633720.762515687]: SnapCamDriver Starting [ INFO] [1609633720.762910065]: Monotonic offset: 1609633473.790296944 [FATAL] [1609633726.430193936]: Failed to load nodelet '/stereo/stereo_cam_nodelet` of type `voxl_cam_ros/stereo_driver` to manager `stereo_nodelet_manager' [stereo/stereo_nodelet_manager-2] process has died [pid 5036, exit code -11, cmd /opt/ros/indigo/lib/nodelet/nodelet manager __name:=stereo_nodelet_manager __log:=/home/root/.ros/log/a0237ab4-4d5a-11eb-9155-ec5c68cd1745/stereo-stereo_nodelet_manager-2.log]. log file: /home/root/.ros/log/a0237ab4-4d5a-11eb-9155-ec5c68cd1745/stereo-stereo_nodelet_manager-2*.log [stereo/stereo_cam_nodelet-3] process has died [pid 5038, exit code 255, cmd /opt/ros/indigo/lib/nodelet/nodelet load voxl_cam_ros/stereo_driver stereo_nodelet_manager __name:=stereo_cam_nodelet __log:=/home/root/.ros/log/a0237ab4-4d5a-11eb-9155-ec5c68cd1745/stereo-stereo_cam_nodelet-3.log]. log file: /home/root/.ros/log/a0237ab4-4d5a-11eb-9155-ec5c68cd1745/stereo-stereo_cam_nodelet-3*.log ^C[rosout-1] killing on exit [master] killing on exit shutting down processing monitor... ... shutting down processing monitor complete done yocto:/#I even tried setting it as slave and not master as recommended over here [https://docs.modalai.com/voxl-cam-ros/](link url)
but after showing
Monotonic offsetit throws error -
I am able to get rosdep working by updating ca-certificates through this
update-ca-certificates cp /etc/ssl/certs/ca-certificates.crt /usr/lib/ssl/certsand setting SSL_CERT_FILE variable to point to ca-certificate path
export SSL_CERT_FILE=/usr/lib/ssl/certs/ca-certificates.crtbut now rosdep dos not detect OS used by Voxl
ERROR: Rosdep experienced an error: Could not detect OS, tried ['windows', 'ubuntu', 'slackware', 'rhel', 'qnx', 'osx', 'opensuse', 'opensuse', 'mint', 'linaro', 'gentoo', 'funtoo', 'freebsd', 'fedora', 'elementary', 'debian', 'cygwin', 'centos', 'arch'] -
I am not able to init rosdep. When I dosudo rosdep initit keeps giving errorERROR: cannot download default sources list from: https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/sources.list.d/20-default.list Website may be down.I tried manually downloading
20-default.litusing wget and placing it inside/etc/ros/rosdep/sources.list.d/directory and tried runningrosdep updatestill it says connection timeout whereas these url are perfectly working when open through browseryocto:/etc/ros/rosdep/sources.list.d# rosdep update reading in sources list data from /etc/ros/rosdep/sources.list.d Warning: running 'rosdep update' as root is not recommended. You should run 'sudo rosdep fix-permissions' and invoke 'rosdep update' again without sudo. ERROR: unable to process source [https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/osx-homebrew.yaml]: <urlopen error [Errno 110] Connection timed out> (https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/osx-homebrew.yaml) ERROR: unable to process source [https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/base.yaml]: <urlopen error [Errno 110] Connection timed out> (https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/base.yaml) ERROR: unable to process source [https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/python.yaml]: <urlopen error [Errno 110] Connection timed out> (https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/python.yaml) ERROR: unable to process source [https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/ruby.yaml]: <urlopen error [Errno 110] Connection timed out> (https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/ruby.yaml) ERROR: unable to process source [https://raw.githubusercontent.com/ros/rosdistro/master/releases/fuerte.yaml]: Failed to download target platform data for gbpdistro: <urlopen error [Errno 110] Connection timed out> Query rosdistro index https://raw.githubusercontent.com/ros/rosdistro/master/index.yaml ERROR: error loading sources list: <urlopen error <urlopen error [Errno 110] Connection timed out> (https://raw.githubusercontent.com/ros/rosdistro/master/index.yaml)> yocto:/etc/ros/rosdep/sources.list.d#I tried doing this updating certificates but it didn't work
update-ca-certificates cp /etc/ssl/certs/ca-certificates.crt /usr/lib/ssl/certsI am using voxl-flightdeck and these are the versions of onboard images
