박지현박
박지현
@박지현
  • Using Ardupilot with Flight Core v2+VOXL Mini 4-in-1 ESC : Min/Max PWM Mismatch and motors keep spinning after disarm
    박지현박 박지현
    Hello Modal AI team,
    I'm currently testing Ardupilot firmware on the Flight Core v2, and I am trying to use the VOXL Mini 4-in-1 ESC in PWM mode (not UART)
    The motors do spin, but I'm facing two criticla issues:
    1. PWM min/max values do not match the ESC range
    Even after setting standard values:
    • SERVO _MIN = 1000
    • SERVO _TRIM = 1000
    • SERVO _MAX= 2000
    • MOT_PWM_TYPE = 0(Nomal) ※If I change this parameter for 6(Dshot600), Motor don't spin well.
    the ESC does not respond correctly.
    It looks like the ESC expects a different throttle calibration range, and the output from Ardupilot is not lining up with the ESC's internal min/max mapping.
    2. Motors keep spinning even after Disarm
    Even when the vehicle is disarmed, the motors continue spinning at a low RPM.
    However, the ESC still keeps the motors running, which makes me suspect that the ESC interprets the "idle PWM" differently from standard hobby ESCs
    3. Questions
    3-1. Does the VOXL Mini 4-in-1 ESC require a specific PWM range or calibration sequence when used outside PX4/VOXL?
    3-2. Is there a recommended PWM frequency or pulse width range for compatibility with Ardupilot?
    3-3. Are there known limitations when using ESC in PWM mode with Ardupilot(instead of the UART protocol it was designed for)?
    3-4. Is there any way to explicitly set the ESC's zero-throttle PWM value?
    4. Test Environment
    • FC : Modal AI Flight Core v2
    • ESC : VOXL Mini 4-in-1 ESC (PWM input pins used)
    • Firmware : Ardupilot Copter
    • GCS : Mission Planner
    • MOTOR : T-Motor Air2216/kv920
    • Controller : SIYI FT24 (Sbus)
    • Battery : 3S 5,300mAh LiPo
    Any guidance or documentation on the correct PWM range, calibration method, or expected behavior would be greatly appreciated.
    Thank you!
