  3. VOXL 2 Frequently Asked Questions
Scheduled Pinned Locked Moved VOXL 2 and VOXL 2 Mini
1 Posts 1 Posters 1.7k Views
  • ModeratorM Offline
    What is the availability of VOXL 2?
    VOXL 2 is available now.
    Is VOXL 2 compatible with VOXL?
    The VOXL SDK runs on both platforms. All VOXL add-ons are compatible with VOXL 2. VOXL 2 has a superset of VOXL’s functionality with significant performance improvements.
    Where is VOXL 2 documented?
    Documentation and datasheets can be found at https://docs.modalai.com/voxl2
    How do I purchase VOXL 2?
    You can purchase VOXL 2 at https://modalai.com/voxl-2
    How does VOXL 2 compare to Qualcomm Flight RB5?
    VOXL 2 uses the same QRB5165 chipset as the Qualcomm Flight RB5 and has the same computational performance in a much smaller footprint. VOXL 2’s form factor enables easy integration into existing aircraft, accelerating time to market.
    Can I run my own flight controller on the DSP?
    Yes. Source code and build instructions for the PX4 reference can be found here: https://github.com/modalai/px4-firmware/tree/voxl-master
    Can I use an external flight controller?
    Yes. A UART can be used to communicate with an external flight controller, documentation can be found here: https://docs.modalai.com/voxl2-external-flight-controller/
