  2. VOXL Compute & Autopilot
  3. Flight Core
  4. Unable to open port while calibrating ESC
Scheduled Pinned Locked Moved Flight Core
2 Posts 2 Posters 1.4k Views 1 Watching
  • J Offline
    Jimk_Aero
    At the point in the ESC calibration python program where I attach the USB cable and reconnect power to our flight core, I receive the following message:
    Using portname /dev/serial/by-id/usb-ModalAI_PX4_FMU_ModalAI_FCv1_0-if00
    connecting...
    Error: Unable to open port
    I'm using Castle Multi-Roto 35 ESC's and I cannot get all the motors to spin.
    This is my last try. I've about given up on the flight core.
      Hi @Jimk_Aero ,
      Sorry to hear about the problems. Not being able to power off USB does make this hard and is a carry over from the VOXL Flight....
      • Even without ESC calibration, you can manually attempt to spin a motor, if using PWM, via this: https://dev.px4.io/master/en/middleware/modules_command.html#pwm
        Do you have an oscilliscope? You could probe the PWM channel output pretty easy (pins 2-5 for a quad) and see if you see any signal coming out of the board. If there's no signal, when you expect it, on a single channel, try to look at those ESD diodes right next to the connector and check for any fried parts.
      • PX4 FW version you are running? There are two programs to handle some edge cases, px4-esc-cal-tool-v1-11.py and px4-esc-cal-tool.py
