    voxl-camera-server
    1587
    • Jonathan JeffJ
      Jonathan Jeff
      my camera is broken and i am getting this error.
        what does journalctl -u voxl-camera-server say
        Jonathan JeffJ 1 Reply Last reply Reply Quote 0
        • Jonathan JeffJ
          Jonathan Jeff @Guest
          I can't find what is causing the problem.
            can you run camera server manually in the terminal with all debug prints enabled ie voxl-camera-server -d 0
            • Jonathan JeffJ
              Jonathan Jeff @Jonathan Jeff
              @Jonathan-Jeff Sorry for my late reply, unfortunately I noticed that the cable broke.
              • VOXL FlightV
                VOXL Flight
                @Alex-Gardner
                Hi Alex,
                I have the same issue, but I have output of journalctl -u voxl-camera-server as shown below
                Jan 01 00:57:14 apq8096 bash[1968]: There is a chance that it may segfault here, this is a mmqcamera bug, ignore it
                Jan 01 00:57:14 apq8096 bash[1968]: ------ voxl-camera-server INFO: Stopping tracking camera
                Jan 01 00:57:14 apq8096 bash[1968]: ------ voxl-camera-server INFO: tracking camera stopped successfully
                Jan 01 00:57:14 apq8096 bash[1968]: ------ voxl-camera-server INFO: Stopping tof camera
                Jan 01 00:57:14 apq8096 bash[1968]: Fault address: 0x68
                Jan 01 00:57:14 apq8096 bash[1968]: Address not mapped.
                Jan 01 00:57:14 apq8096 systemd[1]: [[1;39mvoxl-camera-server.service: Main process exited, code=killed, status=11/SEGV[[0m
                Jan 01 00:57:14 apq8096 systemd[1]: [[1;39mvoxl-camera-server.service: Unit entered failed state.[[0m
                Jan 01 00:57:14 apq8096 systemd[1]: [[1;39mvoxl-camera-server.service: Failed with result 'signal'.[[0m
                Jan 01 01:01:56 apq8096 systemd[1]: Stopped voxl-camera-server.
                Jan 01 01:01:56 apq8096 systemd[1]: Started voxl-camera-server.
                Jan 01 01:01:57 apq8096 bash[3385]: ------ voxl-camera-server INFO: Camera server is now stopping
                Jan 01 01:01:57 apq8096 bash[3385]: There is a chance that it may segfault here, this is a mmqcamera bug, ignore it
                Jan 01 01:01:57 apq8096 bash[3385]: ------ voxl-camera-server INFO: Stopping tracking camera
                Jan 01 01:01:57 apq8096 bash[3385]: ------ voxl-camera-server INFO: tracking camera stopped successfully
                Jan 01 01:01:57 apq8096 bash[3385]: ------ voxl-camera-server INFO: Stopping tof camera
                Jan 01 01:01:57 apq8096 bash[3385]: Fault address: 0x68
                Jan 01 01:01:57 apq8096 bash[3385]: Address not mapped.
                Jan 01 01:01:57 apq8096 systemd[1]: [[1;39mvoxl-camera-server.service: Main process exited, code=killed, status=11/SEGV[[0m
                Jan 01 01:01:57 apq8096 systemd[1]: [[1;39mvoxl-camera-server.service: Unit entered failed state.[[0m
                Jan 01 01:01:57 apq8096 systemd[1]: [[1;39mvoxl-camera-server.service: Failed with result 'signal'.[[0m
                any advice?
                • VOXL FlightV
                  VOXL Flight
                  Output of voxl-camera-server -d 0 is
                  ------ Result thread on camera: tracking recieved stop command, exiting
                  Fault address: 0x68
                  Address not mapped.
                  Segmentation fault
                  • VOXL FlightV
                    VOXL Flight
                    For your information,
                    voxl:~$ voxl-version
                    cat: /etc/modalai/voxl-software-bundle-version.txt: No such file or directory
                    system-image:    ModalAI 3.3.0 BUILDER: ekatzfey BUILD_TIME: 2021-06-06_19:28
                    kernel:          #1 SMP PREEMPT Sun Jun 6 19:41:01 UTC 2021 3.18.71-perf
                    architecture:    aarch64
                    processor:       apq8096
                    os:              GNU/Linux
                    voxl-suite:
                    Package: voxl-suite
                    Version: 0.5.0
                    Depends: libjpeg_turbo (>= 9.0.4), libmodal_exposure (>= 0.0.2), libmodal_json (>= 0.3.6), libmodal_pipe (>= 2.1.1), librc_math (>= 1.1.5), libvoxl_cutils (>= 0.0.2), libvoxl_io (>= 0.5.4), mavlink-camera-manager (>= 0.0.2), mongoose (>= 7.3.0), opencv (>= 4.5.2-2), openmp (>= 10.0.2), voxl-camera-calibration (>= 0.1.1), voxl-camera-server (>= 0.8.1), voxl-cpu-monitor (>= 0.2.0), voxl-dfs-server (>= 0.2.2), voxl-docker-support (>= 1.1.3), voxl-gphoto2 (>= 0.0.5), voxl-imu-server (>= 0.9.1), voxl-mavlink (>= 0.0.2), voxl-modem (>= 0.12.0), voxl-mpa-tools (>= 0.3.6), voxl-nodes (>= 0.2.0), voxl-portal (>= 0.1.2), voxl-qvio-server (>= 0.3.4), voxl-streamer (>= 0.2.6), voxl-tag-detector (>= 0.0.2), voxl-tflite (>= 2.2.3), voxl-tflite-server (>= 0.1.5), voxl-utils (>= 0.8.4), voxl-vision-px4 (>= 0.9.5), voxl-vpn (>= 0.0.3)
                    Architecture: all
                    Installed-Time: 5549
