    Failed to start voxl-camera-server / voxl-mapper
    • G
      greg_s
      I am currently running a Starling 2 with this configuration:
      kernel: #1 SMP PREEMPT Mon Nov 11 22:08:01 UTC 2024 4.19.125
      hw platform: M0054
      mach.var: 1.0.0
      SKU: MRB-D0011-4-V1-C20-T7-M0-X0
      voxl-suite: 1.4.5
      When I scan the services This is the output:
      voxl2:~$ voxl-inspect-services
      Scanning services...
      Service Name | Enabled | Running | CPU Usage
      docker-autorun | Disabled | Not Running |
      modallink-relink | Disabled | Not Running |
      voxl-camera-server | Enabled | Not Running |
      voxl-cpu-monitor | Enabled | Running | 0.0%
      voxl-dfs-server | Disabled | Not Running |
      voxl-elrs-startup | Disabled | Not Running |
      voxl-feature-tracker | Disabled | Not Running |
      voxl-flow-server | Disabled | Not Running |
      voxl-imu-server | Enabled | Running | 3.8%
      voxl-io-server | Disabled | Not Running |
      voxl-lepton-server | Disabled | Not Running |
      voxl-lepton-tracker | Disabled | Not Running |
      voxl-logger | Disabled | Not Running |
      voxl-mapper | Enabled | Not Running |
      voxl-mavcam-manager | Enabled | Running | 0.0%
      voxl-mavlink-server | Enabled | Running | 7.5%
      voxl-modem | Disabled | Not Running |
      voxl-open-vins-server | Disabled | Not Running |
      voxl-osd | Disabled | Not Running |
      voxl-portal | Enabled | Running | 0.0%
      voxl-px4-imu-server | Disabled | Not Running |
      voxl-px4 | Enabled | Running | 41.5%
      voxl-qvio-server | Enabled | Running | 1.9%
      voxl-rangefinder-server | Enabled | Running | 1.9%
      voxl-remote-id | Disabled | Not Running |
      voxl-seek-server | Disabled | Not Running |
      voxl-softap | Disabled | Not Running |
      voxl-state-estimator | Disabled | Not Running |
      voxl-static-ip | Disabled | Not Running |
      voxl-streamer | Enabled | Running | 0.0%
      voxl-tag-detector | Disabled | Not Running |
      voxl-tflite-server | Disabled | Not Running |
      voxl-time-sync | Disabled | Not Running |
      voxl-uvc-server | Disabled | Not Running |
      voxl-vision-hub | Enabled | Running | 3.8%
      voxl-vrx | Disabled | Not Running |
      voxl-vtx | Disabled | Not Running |
      voxl-wait-for-fs | Enabled | Completed |
      When I checked the status of the camera server, this is the output:
      voxl2:~$ systemctl status voxl-camera-server
      ● voxl-camera-server.service - voxl-camera-server
      Loaded: loaded (/usr/bin/voxl-camera-server; enabled; vendor preset: enabled)
      Active: failed (Result: exit-code) since Mon 2025-07-21 22:57:39 UTC; 2 months 12 days ago
      Process: 2179 ExecStart=/usr/bin/voxl-camera-server (code=exited, status=255)
      Main PID: 2179 (code=exited, status=255)
      Jul 21 22:57:37 m0054 voxl-camera-server[2179]: fsync_gpio: 109
      Jul 21 22:57:37 m0054 voxl-camera-server[2179]: =================================================================
      Jul 21 22:57:37 m0054 systemd[1]: voxl-camera-server.service: Main process exited, code=exited, status=255/n/a
      Jul 21 22:57:37 m0054 systemd[1]: voxl-camera-server.service: Failed with result 'exit-code'.
      Jul 21 22:57:39 m0054 systemd[1]: voxl-camera-server.service: Service hold-off time over, scheduling restart.
      Jul 21 22:57:39 m0054 systemd[1]: voxl-camera-server.service: Scheduled restart job, restart counter is at 3.
      Jul 21 22:57:39 m0054 systemd[1]: Stopped voxl-camera-server.
      Jul 21 22:57:39 m0054 systemd[1]: voxl-camera-server.service: Start request repeated too quickly.
      Jul 21 22:57:39 m0054 systemd[1]: voxl-camera-server.service: Failed with result 'exit-code'.
      Jul 21 22:57:39 m0054 systemd[1]: Failed to start voxl-camera-server.
      When I check the mapper status, this is the output:
      voxl2:~$ systemctl status voxl-mapper
      ● voxl-mapper.service - voxl-mapper
      Loaded: loaded (/usr/bin/voxl-mapper; enabled; vendor preset: enabled)
      Active: failed (Result: exit-code) since Mon 2025-07-21 22:57:29 UTC; 2 months 12 days ago
      Process: 1709 ExecStart=/bin/bash -c /usr/bin/voxl-mapper (code=exited, status=255)
      Main PID: 1709 (code=exited, status=255)
      Jul 21 22:57:28 m0054 systemd[1]: Started voxl-mapper.
      Jul 21 22:57:29 m0054 bash[1709]: ERROR: /etc/modalai/extrinsics.conf missing tof to body transform
      Jul 21 22:57:29 m0054 bash[1709]: Loading our own config file
      Jul 21 22:57:29 m0054 bash[1709]: Loading extrinsics config file
      Jul 21 22:57:29 m0054 systemd[1]: voxl-mapper.service: Main process exited, code=exited, status=255/n/a
      Jul 21 22:57:29 m0054 systemd[1]: voxl-mapper.service: Failed with result 'exit-code'.
      What should I do to get these services running?
