  3. Voxl2 GPIO linux control
1 Posts 1 Posters 518 Views
  • T Offline
    T Offline
    tonygurney
    Hello ModalAI Team,
    I’m currently trying to test the output of GPIO pin 46 on the VOXL and haven’t seen any voltage change using a multimeter.
    Here’s what I’ve tried so far:
    echo 1 > /sys/class/gpio/gpio1146/value
    echo 0 > /sys/class/gpio/gpio1146/value
    I also tried using the VOXL utility commands:
    voxl-gpio -w 46 1 and voxl-gpio -w 46 0
    I have also check that the pin was set output
    In all cases, there was no measurable voltage change observed on my multimeter.
    Is there something I may be missing in the configuration, or is there an initialization step required for GPIO 46?
    Thank you for your help!
