Voxl Cam for cleaning drone
Me and my team are building a drone for cleaning roofs, facades ect. Especially for difficult and high surfaces.
I just wonder if voxl cam will find an adhibition in this case. It is because sensors have big fov (reflected on the below image) and it will see a lance made from carbon which is 12mm diameter, and also a hot water from lance that came during the operation.
The next thing is a hose which is going directly from under the drone straight till the ground.
I guess that the arms and propellers also will be visible for the sensors.My questions is whether those things won't disturb readings from voxl cam and if the drone stays stable seeing described parts of the drone.
Can you guys fully explain what cameras consider while sensors scan the surface?
Regards,
Rafal
