    How can I connect voxl and Cubepilot?
    VOXL
    • K
      Kglee
      I'd like to connect voxl and CubePilot. But I can't get the uart messages.
      The environment is as follows.
      If I run voxl-vision-px4 -f , a warning message is displayed.
      (WARNING PX4 DISCONNECTED FROM UART)
      / # voxl-vision-px4 -f
      Enabling UDP recv debugging
      loading our own config file
      Created new json file: /etc/modalai/voxl-vision-px4.conf
      qgc_ip:                     192.168.8.60
      en_localhost_mavlink_udp    1
      en_secondary_qgc:           0
      secondary_qgc_ip:           192.168.1.214
      qgc_udp_port_number:        14550
      localhost_udp_port_number:  14551
      udp_mtu:                    512
      en_vio:                     1
      en_voa:                     0
      en_send_vio_to_qgc:         0
      en_send_voa_to_qgc:         0
      en_set_clock_from_gps:      1
      en_force_onboard_mav1_mode: 1
      en_reset_px4_on_error:      1
      qvio_auto_reset_quality:    0.000500
      en_adsb:                    0
      adsb_uart_bus:              7
      adsb_uart_baudrate:         57600
      px4_uart_bus:               5
      px4_uart_baudrate:          921600
      offboard_mode:              figure_eight
      follow_tag_id:              0
      en_tag_fixed_frame:         0
      fixed_frame_filter_len:     5
      loading extrinsics config file
      Created new empty json file: /etc/modalai/extrinsics.conf
      adding default extrinsics for imu1 to imu0
      adding default extrinsics for imu0 to tracking
      adding default extrinsics for imu1 to tracking
      adding default extrinsics for body to imu0
      adding default extrinsics for body to imu1
      adding default extrinsics for body to stereo_l
      adding default extrinsics for body to tof
      adding default extrinsics for body to ground
      The JSON apriltag data was modified during parsing, saving the changes to disk
      starting geometry module
      starting px4 monitor
      starting uart mavlink
      Successfully opened mavparser
      starting udp mavlink
      Adding manual QGC IP address to udp connection list: 192.168.8.60
      Added new UDP connection to 192.168.8.60
      starting px4 shell
      starting fixed pose input
      starting vio manager
      starting tag manager
      starting offboard figure eight
      And If I run voxl-test-mavparser ,
      / # voxl-test-mavparser
      allocating RPC shared memory
      no messages available
      ^Creceived signal 2
      joining read thread
      exiting cleanly
      Please let me know what I did wrong.
      The UART message was confirmed in the telemetry port of Cubepilot.
      Version
      system-image:    ModalAI 3.3.0 BUILDER: ekatzfey BUILD_TIME: 2021-06-06_19:28
      kernel:          #1 SMP PREEMPT Sun Jun 6 19:41:01 UTC 2021 3.18.71-perf
      architecture:    aarch64
      processor:       apq8096
      os:              GNU/Linux
      voxl-suite:
      Package: voxl-suite
      Version: 0.4.6
      libvoxl_cutils - 0.0.2
      libvoxl_io - 0.5.4
      voxl-camera-server - 0.7.1
      voxl-cpu-monitor - 0.1.7
      voxl-dfs-server - 0.2.0
      voxl-docker-support - 1.1.3
      voxl-gphoto2 - 0.0.5
      voxl-imu-server - 0.8.1
      voxl-mavlink - 0.0.2
      voxl-modem - 0.12.0
      voxl-mpa-tools - 0.2.6
      voxl-nodes - 0.1.6
      voxl-qvio-server - 0.3.1
      voxl-streamer - 0.2.3
      voxl-suite - 0.4.6
      voxl-tag-detector - 0.0.2
      voxl-tflite - 0.0.1
      voxl-tflite-server - 0.1.0
      voxl-utils - 0.7.1
      voxl-vision-px4 - 0.9.2
      voxl-vpn - 0.0.3
      • modaltbM
        modaltb ModalAI Team
        @Kglee ,
        What baud rate have you setup the TELEM port via PX4? By default, voxl-vision-px4 wants 921600 and MAVLINK "onboard mode" (102):
        https://gitlab.com/voxl-public/flight-core-px4/px4-parameters/-/blob/master/helpers/mavlink_serial_ports.params#L22
        Otherwise, voxl-vision-px4 might timeout as it's not getting data at the expected rate.
        Do you have an oscilloscope or no?
        K 1 Reply Last reply Reply Quote 0
        • K
          Kglee @modaltb
          @modaltb Thanks for your answer. I solved this problem.
          But the baudrate 921600 seems hard for CubePilot. So I set both to 115200. And Uart message is ok.
          In this case, is there a problem with voxl flight? ex) VIO
          • modaltbM
            VIO requires the tracking camera to function. I see a VOXL in your picture without any cameras, are you using a different setup than the picture?
            • K
              Kglee @modaltb
              @modaltb No, I have not a different setup. I'm just wondering if that speed(115200) is too slow for voxl to control. Because the default setting of the voxl(core) is 921600.
              Thanks.
              • modaltbM
                Although a majority of our testing is at the higher baud, we've used lower without problems, so it should be fine.
