    Passing external estimation input through EKF2 over mavros
    • tanguy sagereT
      tanguy sagere
      Hi! I'm passing an external estimator input (VICON or custom kalman filter) to the (Sentinel's) VOXL2's EKF2 over a MAVROS topic, but I'm not able to get the /mavros/local_position/pose to match the vicon pose.
      My Setup:
      • VOXL2
      • Sentinel
      • Base Station with VICON Poses (in PoseStamp, and PoseStampWithCovariance)
      • Turned off the QVIO on the VOXL PX4
      • I use the PX4 Flight Controller on the board (no external one)
      QGroundControl Parameters:
      • EKF2_AID_MASK
        • vision position fusion
        • vision yaw fusion
      • EKF2_EV_DELAY
        • 50 ms
      • EKF2_HGT_MODE
        • Vision
      • EKF2_MAG_CHECK
        • 0
      • EKF2_MAG_TYPE
        • None
      Process :
      • I use launch the mavros and remap the VICON Pose to the following topics with the frame_id = 'map'.
        • /mavros/vision_pose/pose
        • /mavros/vision_pose/pose_cov (with a covariance matrix of 36 zeroes)
      • If I open rviz I get the and look the the two poses :
        • /mavros/local_position/pose
      • I see that first of all the VICON pose does not get accepted by the Flight Controller (EKF2) and also that even without feeding the PX4 with the VICON pose the yaw of the Sentinel (mavros/local_position/pose) is off.
      • I suspect one of the following to be the problem :
        • Calibration
        • After Mavros start it continuously outputs the Info requesting home position. Can it be that I need to set the home position that an external pose estimation with respect to the local body frame can be set. (if so how can I set the home position on the Sentinel VOXL2 ?)
        • Parameters are wrong
        • Coordinates frame are wrong
        • I should use the Odometry topic (mavros/odometry/out)
      Any help would be much appreciated, thank you!
      • tanguy sagereT
        tanguy sagere
        Hi! Is any dev available to help out with this?
        • S
          SMRazaRizvi @tanguy sagere
          @tanguy-sagere Hello were you able to solve this?
          @Moderator
