  3. 4208x3120 resolution with IMX214 M0025-2 hires cam on VOXL 2
7 Posts 5 Posters 1.4k Views 3 Watching
  • Jeff DelauneJ Offline
    Jeff Delaune
    wrote on last edited by Jeff Delaune
    Hello Team,
    This page indicates that the the IMX214 M0025-2 hires cam was tested at full resolution (4208x3120) on the VOXL2. Unfortunately, we can't seem to access images at that resolution with the latest VOXL 2 image. Are we missing anything? More details below
    Test configuration:
    system-image: 1.4.1-M0054-14.1a-perf
    kernel: #1 SMP PREEMPT Thu Oct 13 17:48:16 UTC 2022 4.19.125
    hw version: M0054
    voxl-suite: 0.9.5
    After running "voxl-configure-cameras" and changing the "preview_width" and "preview_height" entries of /etc/modalai/voxl-camera-server.conf to 4208 and 3120 respectively for the hires camera:
    "name": "hires",
    "enabled":      true,
    "frame_rate":   30,
    "type": "imx214",
    "camera_id":    3,
    "preview_width":        4208,
    "preview_height":       3120,
    "snapshot_width":       3840,
    "snapshot_height":      2160
    Running "voxl-camera-server" throws the following error:
    ERROR:   Camera 3 failed to find supported preview config: 4208x3120
    ERROR:   Failed to start camera: hires, exiting
    We could verify that 4208x3120 is listed as a supported resolution when running "voxl-camera-server --list"
    Stats for camera: 3:
    ANDROID_SCALER_AVAILABLE_RAW_SIZES:
            4208x3120, 4096x2160, 2104x1560, 1920x1080, 1280x720,
    ANDROID_SCALER_AVAILABLE_PROCESSED_SIZES:
            4208x3120, 4096x2160, 2104x1560, 1920x1080, 1280x 720,
    • Zachary Lowell 0Z Offline
      Zachary Lowell 0
      @Jeff-Delaune said in 4208x3120 resolution with IMX214 M0025-2 hires cam on VOXL 2:
      "name": "hires",
      "enabled": true,
      "frame_rate": 30,
      "type": "imx214",
      "camera_id": 3,
      Hey @Jeff-Delaune - just tried recreating your issue on SDK 0.9 and can say that I also was unable to run the camera at 4208X3120:
      Looks like the reasoning is because there was not a supported PREVIEW config of 4208x3120 - something to note is that the --list basically hits a hal3 api that returns what it believes are the correct camera resolutions. We are currently building out a table of configurable resolutions that are 100% working.
      Anyways - please try a preview config of 4096 x 2160 (still 4k) and that will solve this issue.
      Let me know if that is not an option though.
      Zach
      Jeff Delaune _J 1 Reply Last reply
        "name": "hires",
        "enabled": true,
        "frame_rate": 30,
        "type": "imx214",
        "camera_id": 3,
        Zach
        Jeff Delaune _J Offline
        Jeff Delaune _
        Thanks for the quick reply @Zachary-Lowell-0 !
        We were planning a field test in 1 week for which the full resolution is needed => Is there any plan on your side to get the full resolution to work? If so, do you have a timeline for it?
          We are aware of the issue. It is a very time consuming task to fix Qualcomm's camera drivers. We are working on it though and hope it will be resolved in a release this summer.
          Jeff Delaune _J 2 Replies Last reply
          • Chad SweetC Chad Sweet
            Jeff Delaune _
            Copy. Thanks @Chad-Sweet and team!
              Jeff Delaune _
              Hi @Chad-Sweet,
              Would you be able to tell us what has been confirmed to work with the Qualcomm driver for the IMX214 hires cam?
              Can we get the full frame at a lower resolution?
              Which settings crop the image and which settings down-sample the image?
              We tried to explore that and now have a sense, but it would be nice if you could tell us what to expect.
              I apologize in advance if you already answered these questions to Andrew by email. He is on leave this week.
              modaltbM 1 Reply Last reply
              • Jeff Delaune _J Jeff Delaune _
                Hi @Chad-Sweet,
                @Jeff-Delaune-_
                This is a little late, but we have 4208x3120 working now. The changes weren't in the camera driver itself but the camera pipeline and camera-server... we have it available in a nightly build if you're up to trying a pre-release out!
