  3. Bad Image Output using voxl_cam_ros
3 Posts 2 Posters 921 Views 1 Watching
  • Dean FortierD Offline
    Dean Fortier
    Hey Modalai Team,
    I'm trying to use voxl_cam_ros with an M0025 (IMX214) and am not getting good image quality out. Here is an example:
    I am able to use voxl-rtsp with a decent output:
    I am not getting any terrible errors when launching the ROS node except for
    ERROR: The requested frame_id(0) does not exist in the queue.
    [ERROR] [20204.856915384]: GetImageData() Unable to get Frame data for id: 0 rc: -2
    which is harmless according to this post.
    my voxl-version is as follows:
    yocto:/# voxl-version
    cat: /etc/modalai/voxl-software-bundle-version.txt: No such file or directory
    system-image:    ModalAI 3.2.0 BUILDER: ekatzfey BUILD_TIME: 2021-02-05_19:54
    kernel:          #1 SMP PREEMPT Fri Feb 5 20:03:22 UTC 2021 3.18.71-perf
    architecture:    aarch64
    processor:       apq8096
    os:              GNU/Linux
    voxl-suite:
    Package: voxl-suite
    Version: 0.3.4
    Depends: voxl-utils (>= 0.6.0), libmodal_json (>= 0.3.4), libmodal_pipe (>= 1.7.8), librc_math (>= 1.1.4), libvoxl_io (>= 0.5.4), mavlink-camera-manager (>= 0.0.1), opencv (>= 4.5.1), openmp (>= 10.0.1), voxl-camera-server (>= 0.5.6), voxl-dfs-server (>= 0.0.7), voxl-docker-support (>= 1.1.1), voxl-gphoto2 (>= 0.0.5), voxl-hal3-tof-cam-ros (>= 0.0.5), voxl-imu-server (>= 0.7.8), voxl-modem (>= 0.11.0), voxl-mpa-tflite-server (>= 0.0.2), voxl-mpa-tools (>= 0.1.6), voxl-nodes (>= 0.1.3), voxl-qvio-server (>= 0.2.1), voxl-rtsp (>= 1.0.3), voxl-streamer (>= 0.2.1), voxl-vision-px4 (>= 0.8.1), voxl-vpn (>= 0.0.3)
    Section: base
    Architecture: all
    Maintainer: james@modalai.com
    MD5Sum: e1e5bf1a125affe5036099f6ce895bed
    Filename: voxl-suite_0.3.4.ipk
    Description: meta-package for voxl-suite stable release
    Installed-Time: 13238
    Package: voxl-suite
    Version: 0.2.0
    Depends: docker, imu_app (= 0.0.6), libvoxl_io (= 0.5.2), voxl-cam-manager (= 0.2.2), voxl-docker-support (= 1.1.1), voxl-hal3-tof-cam-ros (= 0.0.2), voxl-modem (= 0.10.0), voxl-nodes (= 0.0.8), voxl-rtsp (= 1.0.2), voxl-utils (= 0.5.2), voxl-vision-px4 (= 0.6.8), voxl_imu (= 0.0.4), voxl-time-sync (= 0.0.1), voxl-vpn (= 0.0.2), librc_math (= 1.1.2), libmodal_pipe (= 1.2.2), modalai-vl (= 0.1.3)
    Status: unknown ok not-installed
    Section: base
    Architecture: armv7a
    MD5Sum: af706cd3c1ea59f274f2ed9b93141f1d
    Filename: voxl-suite_0.2.0.ipk
    Description: meta-package to install all of the voxl-suite
    Any tips would be greatly appreciated.
    Dean
    • James StrawsonJ Offline
      James Strawson
      Hello Dean,
      Starting with voxl-suite 0.3.4 (what you have installed) voxl_cam_ros is deprecated due to annoyances like this.
      Please try its replacement node voxl_mpa_to_ros. This will publish all cameras, IMU, and some other data to ROS all with one node!
      yocto:/# roslaunch voxl_mpa_to_ros voxl_mpa_to_ros.launch
      in another window:
      yocto:/# rostopic list
      /hires/image_raw
      /imu0
      /imu1
      /qvio/odometry
      /qvio/pose
      /qvio_overlay/image_raw
      /rosout
      /rosout_agg
      /stereo/left/image_raw
      /stereo/right/image_raw
      /tracking/image_raw
      /parameter_descriptions
      /tracking/image_raw/compressedDepth/parameter_updates
      Don't worry, it won't actually publish data until something subscribes to the topic so it's not wasting CPU having all those topics advertised.
      Best Regards,
      James
        Dean Fortier
        Hi @James-Strawson,
        Thanks for the tip I will try it out!
